Old 10-19-2016, 01:40 PM   #1023
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Give that thing some grease on the ball and the moving parts of the hitch head.
Get Sway Bracket Jackets.
The noise will pipe down considerably.
When it begins to get noisy again, grease again- for me about once per year.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-19-2016, 05:31 PM   #1024
sb55's Avatar
2018 30' Flying Cloud
South Hero , Vermont
I recently got the "new" L pins. They also helped to quiet down my hitch. After 850 miles, I never heard it once!! Nice😀
On an island in Vermont
sb55 is offline   Reply With Quote
Old 10-20-2016, 08:20 AM   #1025
2016 16' Sport
Miami , Florida
What do most of you guys end up with for a ground clearance? (From the bottom of hitch to the ground)
Shiny16 is offline   Reply With Quote
Old 10-20-2016, 12:09 PM   #1026
m.hony's Avatar
2013 30' Classic
Not much.
I'll measure it when I get home.
TAC #MS-10
Airforums #70955
Old 10-22-2016, 12:11 PM   #1027
Cispook's Avatar
2017 27' Flying Cloud
Chillicothe , Ohio
I was at the dealership and while there the Lead Mechanic told me my Equalizer hitch should have approximately a 3 degree pitch.
He adjusted same and photos are enclosed. I spoke with a factory rep who stated all the hitches should have a "slight" angel.
Didn't impact the level and I'm still within the requirements.
Anyone else encounter this?
Name:	ImageUploadedByAirstream Forums1477159869.226484.jpg
ID:	273977Click image for larger version
Name:	ImageUploadedByAirstream Forums1477159884.240889.jpg
ID:	273978Click image for larger version
Name:	ImageUploadedByAirstream Forums1477159898.841483.jpg
Cispook is offline   Reply With Quote
Old 10-23-2016, 04:46 AM   #1028
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
Attachment 273977Attachment 273978Attachment 273979
Sounds like this Lead Mechanic doesn't understand exactly how this hitch works. If they all need 3 degrees of pitch, they would all be made that way and not be adjustable. Tell him to read his Equal-I-Zer product description.
Just my $0.02 worth.
jimfa440 is offline   Reply With Quote
Old 10-23-2016, 05:43 AM   #1029
Gainesville , Florida
Rearward tilt ofthe ball is a good idea on most hitches. The tech was correct.
Old 10-23-2016, 06:46 AM   #1030
Cispook's Avatar
Chillicothe , Ohio
After posting this I went back and started reviewing the Equalizer video streams from the factory. Low and behold each one shows small amount of tilt that is basically the top elongated bolt hole.
I went back through the installation guide and it doesn't address the use of tilt.
So I have arrived at the conclusion that my first set up was not 100% correct; only 97%.
Live and learn.
2017 27FB FC
Old 10-23-2016, 07:01 AM   #1031
m.hony's Avatar
2013 30' Classic
Rearward tilt of the ball is correct, but...
How many degrees of tilt depends on other things...
1/2 ton, 3/4 ton or 1 ton? 1/2 ton will need more tilt. 1 ton will need less tilt.
Tongue weight? More tongue weight will need more tilt, less tongue weight will need less tilt.
Hitch receiver height? Seems like higher would need more tilt.
"Take" of vehicle? Does it sit level? Does it sit lower in front?
Every rig is different.
TAC #MS-10
Airforums #70955
Old 10-25-2016, 03:12 PM   #1032
abone's Avatar
2017 27' International
Richmond , British Columbia
I've still not got this hitch to transfer enough weight to the front axle. Just returned from a trip and experienced a light front end, particularly on rough road.
My last trip across the scales, full fuel, me, wife, empty tanks, loaded for camping:
front axle: 3586 lbs
rear axle: 4048 lbs
trailer: 5896 lbs
GCVW: 13,530 lbs
TV unhitched: 6424 lbs - Ram 1500 EcoDiesel c/w 3.92, factory air suspension, short box, AWD.
TW: 850 lbs
I am at 6 1/2 spacers, wheel well measures are spot on, hitch height correct.
The bars have tension as they are not parallel to the trailer frame, but have some upwards angle.
Will going to 8 spacers really do it for me, or should I try another hitch?
2017 27FB Intl Sig
2017 F350 Super Duty
abone is offline   Reply With Quote
Old 10-25-2016, 03:19 PM   #1033
m.hony's Avatar
2013 30' Classic
It seems harder to transfer weight on a 1/2 ton.
TAC #MS-10
Airforums #70955
Old 10-25-2016, 04:05 PM   #1034
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
I don't have this exact system, but similar and I was always instructed to use stiffer bars than the TW suggests on a truck to compensate for the difficulty in transferring weight.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 10-25-2016, 04:18 PM   #1035
m.hony's Avatar
2013 30' Classic
I have 1,200# bars rather than 1,000# bars.
TAC #MS-10
Airforums #70955
Old 10-25-2016, 05:51 PM   #1036
2016 25' Flying Cloud
Holly Springs , Mississippi
That's why CanAm Andy suggested to me that I use 1400# bars on my FC25FB. I thought it would be overkill, but he was correct. I'm glad I followed his advice.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
