Old 08-07-2016, 03:58 PM   #953
DarrellT's Avatar
Longview , Texas
Help with bar selection
We're waiting on arrival of our 2017 FC26U. We'll be towing with a F-250.
The dealer is a 'bigger is better' advocate.
What bar rating should we be using?
DarrellT is offline   Reply With Quote
Old 08-07-2016, 05:07 PM   #954
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, no more than 1,000 lb. bars and no less than 600 lb. bars. Hopefully someone towing with an F-250 will chime in.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-09-2016, 09:30 PM   #955
steverino's Avatar
2010 27' FB Flying Cloud
Ivins , Utah
Yep, 1000 lb bars are working well on my 27FB and F250. Adequate weight transfer to the steer axle, and a smooth ride. Well except on California freeways, but that's no fault of the hitch ;-)
steverino is offline   Reply With Quote
Old 08-10-2016, 07:06 AM   #956
Coaster's Avatar
Saint Augustine , Florida
When I bought my used airstream in 2012 the hitch came with it. I always thought the the hitch was racked, one side was lower he the other. It was also sloppy, so sloppy when I brought it to ford they replaced the receiver. Long story short the service manager gave me a spare shank. The original shank was unlevel a lot and the new shank was level. I hope that this will make a difference I always thought that one bar was carrying most of the load.Click image for larger version
Name:	ImageUploadedByAirstream Forums1470834286.159909.jpg
ID:	268692Click image for larger version
Name:	ImageUploadedByAirstream Forums1470834314.875187.jpg
ID:	268693Click image for larger version
Name:	ImageUploadedByAirstream Forums1470834336.736174.jpg
ID:	268694Click image for larger version
Name:	ImageUploadedByAirstream Forums1470834380.955051.jpg
Coaster is online now   Reply With Quote
Old 08-10-2016, 07:35 AM   #957
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
An "anti-rattle" device or hitch tightener will solve that.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-10-2016, 08:39 AM   #958
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Yep, 1000lbs bars here. 30' Classic, F250. I did go with the larger 2.5" hitch rather then use the reducer.
TinCan
graysailor is offline   Reply With Quote
Old 08-10-2016, 09:24 AM   #959
Coaster's Avatar
I do have a stowaway hitch tightener. The L brackets were at the same level but I had to raise the tounge to get the other bar on.
Old 08-13-2016, 04:16 PM   #960
2016 26' Flying Cloud
Southlake , Texas
Just got our 26u a few months ago and have been following the Equil-i-zer thread. Just went out to see if my L-brackets had moved on our just completed 2,000 mile trip. No movement at all BECAUSE now there is no space between the upper and lower bolts and the A-frame and there is a second (even thicker) steel plate on the outside of the A-frame. I guess the hitch guys have been listening!
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
WBCCI
Bgibbs is offline   Reply With Quote
Old 08-13-2016, 05:19 PM   #961
m.hony's Avatar
2013 30' Classic
When I had the problem of the L-brackets moving Equal-i-zer sent me some new link plates.
TAC #MS-10
Airforums #70955
Old 08-31-2016, 09:13 PM   #962
abone's Avatar
2017 27' International
Richmond , British Columbia
I picked up our '17 Airstream 27FB on Monday and ran across the scales. Appreciate any feedback on the #'s.
TV - 2014 Ram 1500 Laramie Limited, 3.92, 4X4, short box, air suspension, crew cab.
Equal-i-zer 90-00-1000
Tow vehicle - full fuel, wife and me, no camping gear:
Front axle - 3608 lbs
Rear axle - 2816 lbs
Total wgt - 6424 lbs
Trailer left factory @ 6025 lbs but the dealer filled the water tank so 6350 lbs approx, otherwise empty.
Tow vehicle and trailer, with WDH:
Front axle - 3322 lbs
Rear axle - 3960 lbs
Trailer - 5390 lbs
GCVW - 12,672 lbs
I like where the GCVW ended up but need to move some weight forward.
The AS dealer installed the hitch, and it was just slap it on and hand me the keys. I do see he installed 4 spacers.
Any suggestions for dialing this in for more weight on the front axle? Add 1 or 2 more spacers first? Adjust the bars second? What about moving the hitch shank closer to the truck? I posted in my Ram forum and that's what I've been told to try.
Appreciate any comments and suggestions.
2017 27FB Intl Sig
2017 F350 Super Duty
abone is offline   Reply With Quote
Old 08-31-2016, 10:29 PM   #963
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
How is it that your rear axle load (without trailer attached) is measuring ~800# lighter than you front axle load (2816# rear vs 3608# front)?
Do you have those numbers backwards or do you haul around a pallet of bricks on the front hood of the truck?
wulfraat is online now   Reply With Quote
Old 08-31-2016, 10:31 PM   #964
Salem , Oregon
Images: 18
Hi, I would add two more washers. My magic combination is with six and a half washers.
2005 Safari 25-B
Old 08-31-2016, 10:49 PM   #965
abone's Avatar
Here are the scaled weights at the factory as per the VIN decoder, no fuel, no Bak-Flip tonneau, no passengers:
Front - 3313 lbs
Rear - 2489 lbs
Total - 5802 lbs
The Ecodiesel engine is heavier than the Hemi, and an empty pick-up truck box is light. Anyone that has weighed these trucks empty have similar ratios front to rear.
2017 27FB Intl Sig
Old 08-31-2016, 10:50 PM   #966
abone's Avatar
Dumb question but when you say 1/2 a washer, you mean a thin washer?
2017 27FB Intl Sig
