Old 03-10-2016, 07:46 PM   #911
2015 23' Flying Cloud
Livermore , California
Agree - very personal and often emotional. We went with the Equal-i-zer!
Originally Posted by Rocinante View Post
That's a topic guaranteed to stir up a kerfuffle. Use whatever WD / Sway control hitch works best for you and your TT/TV combo. We like our Equal-I-zer, but there are plenty of folks out there who use other things.
cactusjk is offline   Reply With Quote
Old 03-11-2016, 09:53 AM   #912
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
There is no such thing as the "best" hitch. Often depends on the tow combination and your pocketbook. Spending more probably doesn't provide a linear increase in value. I tried one hitch first, didn't like it and sold it. Am content with the Equal-i-zer, warts and all.
kscherzi is offline   Reply With Quote
Old 03-11-2016, 10:33 AM   #913
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
I like the Equal-i-zer, also liked the EZ lift, hated the dual-cam, haven't tried the rest.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 03-11-2016, 11:13 AM   #914
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
[richw46 Quote:
Originally Posted by interstateflyer
Yes.....I indeed asked that question of the mechanics. They said it gives you the option of two positions, one of which (the horizontal) keeps things quieter but inhibits sway control.
......... There is still noise but I don't need to grease the spring arms, just the spring arm sockets, and that doesn't last long before they start squeaking.]
Wow, just discovered this thread. Seems I have some reading to catch up on.
We have an equalizer and our 20 tows sweet including during a recent drive down I5 at Black Butte/Castle Crags with horrendous rain & extremely gusty winds.
I realized that when I got to San Diego, that I needed to be a bit more attentive on the head grease vs just a putty knife reapplication of Marine grade grease.
I removed the sockets yesterday and cleaned everything well and started fresh on the grease I discovered that (probably during the storm above) the grease attracted a lot of grit that needed to be removed. Thanks for posting pics, as I've been contemplating the addition to the L brackets.
Longer trips I'm thinking of maybe removing the socket weekly or so to start fresh. It's really simple and I already have the torque wrench handy for the wheels, and it's the same size socket as the WH plug...which is always in my tool bag of often needed tools etc. anyway.
CruizinDux is offline   Reply With Quote
Old 03-11-2016, 11:41 AM   #915
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Bob: I take the head on our Equalizer apart at the end of each season. I see no wear on it and I only grease it because I think it must need to be done. The noise is an issue, but I close the windows. We do about 10,000-15,000 each year.
I also carry all kinds of tools, torque wrench for the wheels as well as the hitch and an extra ball as the one Equalizer uses is somewhat odd in it's very short shank.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-11-2016, 11:44 AM   #916
interstateflyer's Avatar
2017 25' International
Los Osos , California
Originally Posted by garylind View Post
About to purchase this new trailer and wondered what model is best. The dealer seems to think that a SwayPro is more than adequate.
My dealer sold us a Huskey WDS for our first Airstream. What a horrible system. That was the brand that they pushed on their customers.
I'd probably trust the collective experience of AirForum members more than most dealers, there are exceptions of course.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 03-11-2016, 12:21 PM   #917
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Do you recall, specifically was it a Husky Centerline?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-11-2016, 12:28 PM   #918
No, it was not a Centerline. It was a previous model. I've actually heard the Centerline is better. Didn't mean to pass judgment on the whole Huskey line.
Equalizer was a huge improvement over the Huskey chain style WSD that we were sold.
Old 03-11-2016, 01:11 PM   #919
dznf0g's Avatar
Oswego , Illinois
Originally Posted by ROBERTSUNRUS View Post
Hi, in position "A", in my opinion, the pads are useless. In position "B", in-which Equal-I-zer shows where they go, they are quieter. Also in my opinion, and with my experience, The sway jackets create more friction than the original metal to metal design.
I used to use an EQ, so I'l throw in my learnings. The nylon pads are supposed to be in the horizontal position with the bars riding on them. It does reduce friction a bit, but per my conversation with EQ, that area isn't the primary friction surface and does little for sway control. The primary friction surface is the head saddle area where the front ends of the bars are bolted to the head and swing in turns. That's why the torque on those bolts needs frequent attention.
-Rich-
Old 03-11-2016, 01:31 PM   #920
GCinSC2's Avatar
I've checked mine several times and the torque required to rotate the sway bar (not the bolt) varied greatly with where the bar socket is. Worn area, loose ish. Outside the primary work area tight ish. Observed quite a bit of wear on the bar socket surface of the head.
S/OS #001
Old 03-11-2016, 01:34 PM   #921
dznf0g's Avatar
Oswego , Illinois
Everything wears and eventually wears out. Especially metal on metal and under that kind of pressure.
-Rich-
Old 03-11-2016, 02:19 PM   #922
GCinSC2's Avatar
Yeah, I feel a bit worn out some days too.
S/OS #001
Old 03-11-2016, 07:16 PM   #923
I have a new Equalizer and it was next to impossible to remove the sockets since they were so tight. I was afraid if removed I would never get them back in.
QUOTE=paiceman;1760821]Bob: I take the head on our Equalizer apart at the end of each season. I see no wear on it and I only grease it because I think it must need to be done. The noise is an issue, but I close the windows. We do about 10,000-15,000 each year.
Bud[/QUOTE]
Old 03-11-2016, 09:02 PM   #924
CruizinDux's Avatar
Bud
Thanks Bud. Thanks for the feedback & experience. We're new and this was our maiden voyage (2500 miles).
Ours did show a bit of wear that I contribute to grit that I missed and didn't remove as well as not being as diligent on getting the grease in all the places it needed to be on the head. I only removed the two sockets for the cleaning and I'm expecting a bit of closer attention on the road will spread out the dis-assembly times. The noise for us isn't that bad and like you said...the windows do go up.
happy trails,
