Old 10-29-2015, 02:55 PM   #855
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
New 2-1/2" shank came yesterday, made the change today and took the AS out of storage for a 20 mile run to see if I could tell any difference. I could, much better so far and it did not bind in the receiver like the 2-1/2" reducer did. So we shall see, hopefully next trip will be down south in late December or January so that should be a good test. Also, new 2-1/2" shank is much heavier.
I now have a 2" shank available if someone needs one - 3" drop.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 01-11-2016, 07:26 AM   #856
paiceman's Avatar
I took the trailer with the new 2-1/2" shank to the dealers last week and picked it up three days later for some warranty furnace work. The new 2-1/2" shank in the 125 mile round trip worked great, lots of turns and hills with lots of bumps. Shank went in without a problem and pulled out just as easily. So far very satisfied with this switch as the reducer sleeve would no longer come out at all without banging on it with a hammer. I realize the Ford installed factory receiver is probably bent, but until I get to replacing that, this seems to fit the bill. Plus the hitch seemed to be much more quite and no change in the equalizer operation. Still like the Equalizer and will continue using it as I consider it much better for me than the Reese as I can turn 90 degrees without taking bars off and I need to do that to get in my driveway at home.
Bud
SAFE TRAVELS
Bud
Old 01-11-2016, 10:14 PM   #857
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Thanks to this thread I also upgraded to the 2.5" shank. No problems at all putting it in or taking it out.
TinCan
graysailor is offline   Reply With Quote
Old 01-21-2016, 03:12 PM   #858
2016 28' Flying Cloud
The Plains , Ohio
Bars too tight
It's really difficult to move the sway bars in the hitch. Actually yesterday, the second time I unhitched, I needed my wife to help me pull the bar off the L bracket. And it looks like I can't swing the bar far enough to the left. Moving the bars is still very stiff.
I'm leaving my AS here at the Pesacola Airstream park till March, but I've ordered a torque wrench and when I come back down. I intend to take out the bolts at the hitch, lubricate the swing arm receivers, and then reinstall torquing to 45 ft.lbs.
Is it unusual for a new hitch to be so difficult to swing the arms?
Richard
whitegs is offline   Reply With Quote
Old 01-21-2016, 03:30 PM   #859
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Richard, my Equalizer moves easily as yours should also. I use a lithium grease as needed. I get the feeling you're not using the jack (while still attached to the ball) to lift the trailer high enough to take the pressure off the bars. When doing this the truck rises also & that's ok as when high enough the bars swing freely. At this point lower the jack, unlock the ball & disconnect in the usual way.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 01-21-2016, 03:42 PM   #860
The Plains , Ohio
No, I get the jack high enough and the pins easily come out of the L brackets and the arms swing off. It's just that the arms are so tight at the hitch that the bars simply don't swing easily . It's just that swinging the bar it very tight. Even after I get the bars off the L bracket, the bars are extraordinarily tight in the hitch itself.
I'm using high temp grease, but the receivers weren't lubricated by the dealer when they were installed so I only can grease the small part of the place where the bars go in that is exposed.
As I said, I think I'll have to disassemble the hitch, grease the brackets, and reinstall torquing to 45 lb.
Old 01-21-2016, 04:20 PM   #861
Kittyfeet's Avatar
2016 23' Flying Cloud
Dallas , Texas
I am thinking about this hitch. I have a question-if I am pulling a trailer that will require very little wd, since the tension bars also serve as the sway control, how do I deal with that so I have plenty of sway tension without taking off too much weight from the tv?
Kittyfeet-
I hope this day to have the opportunity to help someone in need.
Kittyfeet is offline   Reply With Quote
Old 01-21-2016, 04:46 PM   #862
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Kittyfeet - You seek sway resistance yet not much weight distribution. I don't think this is the hitch for you. Good sway resistance with this hitch is derived from friction created by lots of tension in the sway bars. Look at the Anderson hitch instead. It's anti-sway properties and weight distribution forces are mutuly exclusive.
kscherzi is offline   Reply With Quote
Old 01-21-2016, 05:40 PM   #863
Kittyfeet's Avatar
Dallas , Texas
Thank you. Thought about the need to look at another type of hitch.
Kittyfeet-
Old 01-21-2016, 05:54 PM   #864
East Falmouth , Massachusetts
Richard
Have a new hitch and one arm was real stiff and both arms were hard to take off lowered the l brackets,and sprayed penetrating oil in the joint and all is fine.Hitch has to be tuned then you'll be happy
Paul Carreiro
miskeeta is offline   Reply With Quote
Old 01-21-2016, 07:01 PM   #865
The Plains , Ohio
Originally Posted by miskeeta View Post
Richard
Paul Carreiro
I think the height of the L brackets is fine. No problem getting the bars on or off. It's the stiffness that's causing my problem. I can't really move the bars even when disconnected from the trailer. I'll try the penetrating oil but the bolts may be torqued too tight. Project for when I come back down in two months to where I'm storing the trailer. I have to head home to Ohio and I'm leaving the AS at the Airstream park in Pensacola. I'll get it worked out when I get back. Given the big winter storm, I'm not going to take any chances towing the Airstream north.
Old 01-21-2016, 07:35 PM   #866
Silver Hilton
Mark Wiltrakis's Avatar
1959 24' Tradewind
Astoria , Oregon
Whitegs -
I had an identical experience. It resolved completely using some of Equalizer's "High Performance Lubricant" and adjusting settings with a torque wrench. Now it's no effort at all. I predict you will have a similar experience.
Mark
Mark Wiltrakis is offline   Reply With Quote
Old 01-21-2016, 07:42 PM   #867
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
When my bars got loose it seemed that the sway control got less effective. I removed them, cleaned them, lubed them and re-installed, torquing to spec. Before I could move the sockets by hand. After I had to use a bar to get enough leverage and it was harder to turn, but I could do it by myself.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 01-21-2016, 07:50 PM   #868
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
After reading most of this, I will stick with my reese duel cam hitch .
