Old 10-11-2015, 04:52 PM   #827
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
paiceman,
I appreciate your suggestion but it's not for me. It's for a fellow, brand new Streamer who lives in Indy and quite frankly is not the mechanical type. Hence, asking for info from anyone who may live in that area.
'01 16' Bambi --- Swee' Pea
'13 23D International --- Trixy
'09 Silverado --- Big Bertha
Adoptee -- '78 Argosy 24' Moho -- Big Girl
tinbender is offline   Reply With Quote
Old 10-11-2015, 08:54 PM   #828
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
If I was near him, I'd go over to his house and do it for him, but I'm in Mississippi.
Surely there is a 'Forums member near him who can help.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-17-2015, 09:09 AM   #829
paiceman's Avatar
Upper St Clair , Pennsylvania
QUESTION: For all long time Equalizer hitch users. I tow with a Ford Super Duty, F350 Diesel and therefore need a receiver sleeve so the equalizer head can fit into the larger Super Duty receiver. We've towed about 10,000+ miles with the hitch this past summer and a little more this fall. After about 6,000 miles when I took the head out the sleeve did not come out, in fact I now have to pry it out with something and I've noticed rub marks on the sleeve. If I put in an extra sleeve I carry and put it part way in and pound it with a hammer the sleeve will then move in and out easily for about 700 miles then starts to bind again. Ideas or suggestions would be appreciated. Never had this issue with a Reese, so not sure what is going on.
SAFE TRAVELS
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 10-17-2015, 11:23 AM   #830
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
Equal-i-zer Hitch Thread.
I had the same problem. Replaced it with a 2 1/2" unit. I had to replace the rock Tamer collar as well but problem solved. Less slop all the way.
With the adapter there was enough movement that a locking hitch pin bent!
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 10-18-2015, 11:50 AM   #831
paiceman's Avatar
Thanks, same issue with lots of movement and slop and I did notice lots of unusual wear on the hitch pin. I'll order the 2 1/2".
SAFE TRAVELS
Old 10-19-2015, 09:21 PM   #832
casarodante's Avatar
2012 31' Classic
Visalia , California
After over a year of towing with a reducing adapter I got a 2 1/2" stinger for my F250. First time out it was nice. Didn't have to align extra holes while sliding that beast in!
However, I could not get the unit out! I had to twist, shake, wiggle it for about 10 minutes to get it out. I contacted Equal-i-zer and they had never heard of it. Their recommendation was to grind the stinger down a bit.
I had to grind it 3 times before I can remove it easily.
But it is better than a reducer.
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
Visalia, CA (between Fresno & Bakersfield)
2012 31' Classic - Nuestra casa rodante
Blog: http://www.casarodante.org - Old Airstream slides: http://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 10-20-2015, 02:31 PM   #833
paiceman's Avatar
So, Equalizer lies. I called them last week and again yesterday and they said they had never heard of this situation. If your case becomes my case I am going to bag the Equalizer Hitch and move on. I think the hitch in some cases is distorting the inside of the receiver as I have three reducer sleeves and if the one I am using binds up inside, when I get it out the other two will not go into the receiver. You ground down the 12" stringer or "shaved" it?
Bud
SAFE TRAVELS
Old 10-20-2015, 05:46 PM   #834
Senior Member
sheriff1's Avatar
Sparks , Nevada
Mine wouldn't slide in at first. Took some paint off the edges and works fine now
Old 10-21-2015, 06:31 AM   #835
paiceman's Avatar
The wear on the sleeve is on the top, not the sides, which leads me to believe as stated it's actually distorting the receiver, not the sleeve. I've ordered the 2 1/2" and will see, but unfortunately not until we take the AS to Florida in late December or January.
Bud
SAFE TRAVELS
Old 10-21-2015, 08:07 AM   #836
2014 27' Flying Cloud
Stowe , Vermont
I have been reading all the threads about Equalizer hitches and just wanted to add a positive note about them. In 2008 we purchased a new 2007, 25 ft. AS Safari, and add to that a new 2007 Ram 2500 w. diesel engine. The AS dealer installed the Equalizer hitch for the Safari and we put 52,000 trouble free miles on it. In 2013 we upsized to a new 2014, 27ft Flying Cloud. The dealer only needed to make a couple of minor adjustments to the Equalizer on the trailer side. This year, 2015, we traded in for a new Ford F250 diesel. This change required full adjustments to the Equalizer done by a local RV dealership who sells the Equalizer. The FC now has 26,000 trouble free miles. I keep looking in the mirror to see if the trailer is still there, whether it be clear, windy or rain, passing 18 wheelers, or being passed by them. The Equalizer has been awesome. It has been perfect for our high speed interstate highway driving.
VT Wanderer is offline   Reply With Quote
Old 10-21-2015, 10:41 AM   #837
Senior Member
sheriff1's Avatar
Sparks , Nevada
I don't think it's an equalizer issue. I think it's the 2" to 2 1/2" adapters that are the problem. For my purpose the equalizer brand works quite well.
Old 10-21-2015, 09:49 PM   #838
2012 31' Classic
Bud
Here is from an email conversation from 5/28/15 with Equal-i-zer:
I have never seen this before, so I talked to my manager about it. He said that the best thing to do is sand the sides down just a hair, and it shouldn’t take much. Apparently our shanks have a 1000th of an inch tolerance, but we cannot speak for the receiver. It might be that the receiver is a little more rounded on the corners which is causing the tight fit. I hope that helps! If you have any more questions or concerns please let me know!
-Austen
I ground mine down with a Makita. First time just taking the paint off. Next couple of times a bit more. 3 grinding sessions in all.
Old 10-22-2015, 06:14 AM   #839
chaseav's Avatar
2015 25' FB International
How much 'wiggle' up and down is considered normal in the hitch receiver? Mine was a pretty tight fit but after about 6,000 miles of towing, there is some play to the hitch within the receiver. I've actually put a very small wood shim in there just to keep it from moving.
chaseav is offline   Reply With Quote
Old 10-22-2015, 06:39 AM   #840
paiceman's Avatar
Do not have the 2 1/2" shank yet, but towed the trailer 63 miles back to storage from our AS dealer where it was having some warranty work done on the furnace. Reducer sleeve was stuck in the receiver, again. This is an issue that was not there the first 5,000 miles, then developed and continues, which is why I ordered the 2 1/2" shank.
I am not confident it will work as I believe the receiver is now bent. The reducer sleeve has deep marks on it in the back as well as top and two sides. I cut one reducer to be the exact length of the 2" shank I now have, did not resolve the problem at all.
Other than this issue I like the hitch.
SAFE TRAVELS
