Old 09-11-2015, 12:09 AM   #813
Originally Posted by Ron Gratz View Post
Al,
The WDH and bars, in effect, become part of the truck.
They add to the mass of the truck and cause the center of mass to move slightly rearward.
The WDH and bars do cause a slight reduction in load on the front axle and a slight increase in load on the rear.
However, since the CM has moved slightly rearward, the effect of decreased load on the front multiplied by increased distance to CM tends to be balanced by the effect of increased load on the rear multiplied by decreased distance to the CM.
In short, it is neither necessary nor desirable to restore/remove the axle loads which are subtracted/added by the weight of the WDH and bars.
The added mass of the WDH and bars automatically compensates by moving the center of mass of truck and cargo rearward.
The "TV Only" weight should include everything which is going to be in/on the TV while towing.
The WDH and bars are part of the TV's cargo.
Ron
Over 45 years ago, it was determined by various tests that the following is the best way for utilizing a travel trailer with a load equalizing hitch,
For example, assume a 900 pound tongue weight.
600 pounds should be transfered to the tow vehicle and 300 pounds should go back to the trailer. Further, the 600 pounds going to the tow vehicle should be equally divided to the 4 wheels, or 150 pounds to each wheel.
If there is an adequate trunk or rear end load placed in the tow vehicle, then some of it's weight can also be transfered to the front tow vehicle axle.
To remove weight from the front axle, will deem the steering wheel to become progressively useless, which in turn simply means your asking for a loss of control.
Old 09-11-2015, 07:54 AM   #814
Livingston , Texas
As I attempted to explain in response to Al's question about the weight of the WDH and bars:
Any mass added to a TV behind the rear axle will cause load to be removed from the front axle.
The added mass also will cause the TV's center of mass to move rearward.
The load on the front tires is reduced, but the distance from the front tires to the CM is increased.
Since the length of the moment arm (distance from axle to CM) is increased, the front tires can cause the same amount of steering torque.
The steering ability of the front tires does not become progressively worthless, because the tires are exerting their force over a longer moment arm.
Now, if you're talking about load removed from the TV's front axle due to the downward force on the ball resulting from "tongue weight" -- you're talking about a completely different situation.
The reason it's different is because the "tongue weight" removes load from the TV's front axle, but doesn't cause a rearward movement of the TV's center of mass.
Ron
Ron Gratz is offline   Reply With Quote
Old 09-11-2015, 08:31 AM   #815
Livingston , Texas
Andy,
Someday I would like to see some documentation of the "various tests".
Perhaps that would help me understand why your conclusions are in disagreement with results of a scientific study conducted for DOT-NHTSA.
Results of the DOT-NHTSA study are discussed in Post #3 of http://www.airforums.com/forums/f464...ml#post1524036.
Ron
Old 09-11-2015, 03:55 PM   #816
Livingston , Texas
Your rigging is within 100 pounds of being PERFECT
Find something else to worry about.
Andy,
Are you referring to the front and rear values for "WD On" -- (4760# versus 4660#)?
Are you implying that a "PERFECT" WDH adjustment would cause those values to be equal?
Al's scale numbers indicate the front axle LOST 200# (4760-4960) while the rear axle GAINED 1160# (4660-3500), giving a TV gain of 960#.
So, the distribution of the 960# added to the TV was:
Front axle = -20.8%
Rear axle = 120.8%.
In another post you stated the best way to utilize an equalizing hitch was to adjust it so the load added to the TV's front axle was equal to the load added to the TV's rear axle.
Clearly, -200# is not equal to +1160#.
There seems to be a significant disagreement between
1) "PERFECT" rigging in one post, and
2) the "best way for utilizing a travel trailer with a load equalizing hitch" in another post.
Ron
Old 09-11-2015, 08:07 PM   #817
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Say, what size socket does one need to tighten the bolts in the EQ hitch head to 45 ft lbs? Can we achieve that with just a torque wrench, or do we need another wrench on the other side to hold everything in place while tightening?
Rocinante is our 2014 International Signature 27FB
Old 09-11-2015, 08:26 PM   #818
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, on my eleven year old Equal-I-zer the socket bolts enter from the bottom of the hitch head. There is a hex built into the hitch head which holds the head of the bolts from turning while torqueing the nuts. I believe that the newer ones work the same way, but the bolts enter through the top and the nuts are on the bottom. Mine uses a 15/16" socket for the nuts.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-12-2015, 06:43 AM   #819
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Ron
And this is the part i dont understand. Why is 900# of tongue weight any different from a 900# weight sitting on the hitch?
Taken to the limit, no matter how far aft the weight is, if it lifts the front tires off the ground, they won't provide any steering force. Not trying to be argumentative, just want to understand.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-12-2015, 06:50 AM   #820
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
After 10,000 miles on this hitch, used Reese for 45 years, the ball has wear on the back side, ie the side facing the trailer? It took me a while to get used to his hitch, finally while out I downloaded a dealer video and worked it all out as far as hitching and unhitching. Still not sure I like this hitch enough to keep it. Bolts holding bars to the heads have loosened so I'll tighten them to the 45# as recommended. But now looking at anderson. I DO like the fact I can back into any location without taking bars off of the Equalizer
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 09-12-2015, 12:49 PM   #821
Al
Al.
They are the same.
But, keep in mind what those hitches are called.
LOAD EQUALIZING.
That means exactly that, namely equalize the weight transfered to the tow vehicle tires, all four.
No biggie.
Old 09-12-2015, 07:14 PM   #822
Livingston , Texas
Al,
Since our discussion is not specific to the Equal-i-zer Hitch, I think it would be better to move it to This Thread -- Posts #23 & 24.
I have attempted to answer your question there.
Ron
Old 09-12-2015, 07:29 PM   #823
Andy,
Front axle = -20.8%
Rear axle = 120.8%.
Ron
Ron
While trying to make the most of my R & R in Hawaii, I did not read that chart as well as I should have.
Never reducing tow vehicle front axle weight when towing a trailer, using a load equalizing hitch, is what I was taught using math, Physics and personal thousands of miles towing.
Sorry for the confusion.
Old 09-13-2015, 01:17 PM   #824
Livingston , Texas
Al.
They are the same.
No, they are not the same.
There is an important difference.
Discussion can be found HERE.
Ron
Old 10-11-2015, 12:39 PM   #825
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Need hitch help in Indy !!
An AS newbie who lives on the north side of Indy has bad hitch problems. Has had the trailer about 3 months. Already spent more than the hitch is worth for having it "adjusted" by a shop who made it worse.
Anyone in the Indy area know of a shop that actually knows how to properly set up an Equalizer hitch ??
2015 Dodge Ram 1500 pickup.
Thanks for recommendations.....
'01 16' Bambi --- Swee' Pea
'13 23D International --- Trixy
'09 Silverado --- Big Bertha
Adoptee -- '78 Argosy 24' Moho -- Big Girl
tinbender is offline   Reply With Quote
Old 10-11-2015, 02:45 PM   #826
paiceman's Avatar
Tinbender: Suggest you go on line, read the equalizer set up instructions then on youtube there are pretty good videos on set up and use. I have looked at both and set my own up and like the way it works. My only issue so far is the bolts holding the bars to the head loosened up on our trip this summer (10,000 miles) and we just returned from a two week quick trip and I found the ball had come loose. I have the tools to tighten all, but in 40+ years of Reese, nothing every came loose.
SAFE TRAVELS
Bud
