Old 08-05-2015, 07:29 PM   #729
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Originally Posted by kscherzi View Post
I don't know about the one above, but this socket definitly works.
Powerbuilt 643216 3/4-Inch Drive 12 Point 1-7/8-Inch Socket - - Amazon.com
I paired it with this breaker bar.
TEKTON 15207 3/4-Inch Drive x 24-Inch Breaker Bar - - Amazon.com
Inserted the hitch sideways into the receiver, then stood and jumped on the breaker bar. I weight about 170 lbs. At two feet that's 340 lbs of torque. Bouncing up and down a little more. So far the ball in on real tight and has not moved.
Just to follow up on this, I ordered these exact items and they worked like a charm. Thanks again.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 08-05-2015, 08:20 PM   #730
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
32 inches
Originally Posted by subfan1 View Post
32 inches from center of ball to center of L bracket max distance per install instructions
Thanks subfan1, I will be checking the distance on mine tomorrow. I think they are at 32 but I couldn't remember the exact number. I wouldn't take a plugged nickel for my Equalizer
I used it for 7 years on my previous trailer and it works like a champ on the AS.
awesome thread
Have a good one !
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 08-05-2015, 10:36 PM   #731
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Maybe you took a really sharp turn someplace and cause the ball to slide so far forward it fell off the bracket.
I meant to say bar sliding off the L bracket.
Take a look at your bars to see the wear marks. There ought to be at least an inch or two of unworn bar at the end. Thats the way mine look. If there's wear very close to the end then move your L brackets closer to the hitch.
kscherzi is offline   Reply With Quote
Old 08-06-2015, 12:08 PM   #732
richw46's Avatar
Lexington , Kentucky
That's where mine is sitting, 32". I took a sharp right turn but it's the right one that came out. Maybe right at the gas pump, the last left turn I made. It must be close and a real sharp turn must have allowed it to come out. I'll have to try a sharp turn in a parking lot and see how far the bar comes to the retainer.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-11-2015, 05:27 PM   #733
2007 19' Bambi
Park City , Utah
Bent L Pins
I've been looking through the thread but it is very long. Is it normal for the L pins to be distorted or bent? I see equalizer sells spares. Is this in case you loose one or do they need to be replaced if they bend a bit?
Chucke is offline   Reply With Quote
Old 08-11-2015, 06:38 PM   #734
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
I have not experienced any bending.
Ron
Ron
Ron A is offline   Reply With Quote
Old 08-11-2015, 06:57 PM   #735
richw46's Avatar
It never hurts to have spares. I already had a bunch of spare parts from the PO, but I got the new pins (both ends) that have a built in clip; really nice and much easier to use. Now I have 2 sets of backup pins
The pins on the L bracket have a slight bend in the metal from where it was bent to make the "L" shape. Maybe that's what you're talking about? I don't see how you could bend or warp one of those, the spring arm pressure is mostly down. There is some pressure, side to side, on turns, no where near enough to bend a pin unless maybe in an accident.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 08-11-2015, 10:25 PM   #736
kscherzi's Avatar
Images: 24
I recently noticed that my L pins have some noticeable wear from the bar.
Old 08-12-2015, 04:46 AM   #737
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Get new L-pins every 2-3 years.
I got the new style with the flip over latch.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-12-2015, 05:06 AM   #738
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, going on 11 years and still using the original "L" pins, with my roll pin modification. The early "L" pins were black, and crudely bent. They looked like they were made by a black smith instead of machine bent. Sometimes people think that the original "L" pins have bent, but they haven't, they just look that way.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-12-2015, 08:15 AM   #739
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
No bending here, but we did buy an extra set of those and the cotter pins that hold the WD bars into the hitch head. We had visions of stranding ourselves by dropping a pin and being unable to find it. So, the extra set was cheap insurance.
Rocinante is our 2014 International Signature 27FB
Old 08-12-2015, 05:06 PM   #740
m.hony's Avatar
2013 30' Classic
The pins take away the slop and play, which takes away the wear- good idea-
TAC #MS-10
Airforums #70955
Old 08-14-2015, 07:24 PM   #741
2007 19' Bambi
Park City , Utah
Bent L pins
Here's a photo of one of my pins.Click image for larger version
Old 08-14-2015, 08:27 PM   #742
m.hony's Avatar
2013 30' Classic
Mine show a little wear, but no bending.
TAC #MS-10
Airforums #70955
