Old 05-26-2015, 11:31 PM   #617
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
Now take a hammer and a center punch and punch the threads on the ball threads just where the nut meets it to keep it from backing off.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 05-26-2015, 11:47 PM   #618
OilnH2o's Avatar
1976 27' Overlander
Missoula , Montana
My bars, when removed, slide right back into the cardboard box they arrived in- with some duct tape reinforcement on the ends. They have lasted several years with judicious and careful use, sliding in and out carefully and store easily in the back of our Sube.
The hitch/head I simply remove, put into a card-board lined (for padding and to keep the grease from the carpet) "milk crate" that lifts easily, and fits it handily - I remove the hitch from the receiver, put it in the crate, then lift the crate into the back of the Sube. Works great, simple, handy, and if we leave the campsite, the hitch leaves with us. I like, and have seen, MeFly's well-fitted plastic conduit solution. When my cardboard box falls apart, I'll probably do what he did!
1976 Airstream Overlander International
WBCCI 1054
VAC
TAC
TCT
OilnH2o is offline   Reply With Quote
Old 05-27-2015, 10:53 AM   #619
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
I used to fret over how to store bars and head when camping. I gave it up and now store them like this. Obviously I have given up worries about theft of the bars. Also yields big benefit when hooking back up, it's all right there.
ID:	239375   Click image for larger version
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 05-27-2015, 11:21 AM   #620
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Does any know how much lower the bars go down in relation to the L brackets when you add another washer on the head? The lower the bars go down the higher you have to raise the trailer connected to the truck. I also have to clear the thickness of the bracket jacket I have on the L bars.
Kelvin
Old 05-27-2015, 01:48 PM   #621
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
That's exactly what I do.
I camped in 2012 and 2013 and part of 2014 before it occurred to me to store them that way.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 05-27-2015, 11:30 PM   #622
mefly2's Avatar
2015 25' FB Eddie Bauer
I'd chop off those cross bolts before you get buggered / ouched ...takes a while, but worth the effort.
Old 05-28-2015, 06:21 AM   #623
Alphonse's Avatar
Lower Alabama , USA
Thought about it but I have another hitch that I'll likely use soon and simply didn't want to spend the time on it.
Alan
Air #64439
TAC AL-8
2018 Canopenian
Old 05-28-2015, 08:31 AM   #624
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Finally ordered the sway jackets. This week I will add 2 washers to the hitch and move the brackets to make the bars more parallel with the frame..
I love how easy this hitch is to use.
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 05-28-2015, 09:00 AM   #625
richw46's Avatar
Lexington , Kentucky
Kelvin
I thinkered with my hitch earlier this year. As I recall, adding the washers transferred more weight to the front axle and didn't have much of an impact on how high I had to raise the TV to slide the bars on. I added two washers and went up one hole on the "L" bracket. Raise that "L" bracket a notch and that makes a big difference in how high the TV rear end has to go. I tried two notches initially, came back down one. The TV was almost off the ground and the bars had a definite bend in them.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-28-2015, 10:23 AM   #626
KJRitchie's Avatar
2008 25' Classic
I don't want to raise the L brackets as they are parallel to the frame which I believe is the recommended position. Adding a washer pivots the head down a bit and the angle of the bar sockets on the head. My Tundra sits level with the AS attached, 37" from ground to vendor on all wheels. The front clearance is about 50% returned from the unloaded position. Just wondering what would one more washer would do to the front and if it would require the power jack to work a lot harder especially at campsites with a bit of a hill so the hitch head is angled further down in relation with the trailer. Guess I can pull it to level ground then put the bars on.
Kelvin
Old 05-28-2015, 01:57 PM   #627
m.hony's Avatar
2013 30' Classic
Parallel is recommended, but I couldn't get enough lift/weight transfer or sway control until I raised the L-brackets. They are no longer parallel, but the whole towing experience is better- les bounce in the ride snd less sway when vehicles pass-
TAC #MS-10
Airforums #70955
Old 05-28-2015, 04:40 PM   #628
interstateflyer's Avatar
2017 25' International
Los Osos , California
It looks like you drilled and pinned your L Bracket retainers and abandoned the stock wire bales. Is that what I'm seeing in your photo?
Did you have a stock one with the wire bale fail?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 05-28-2015, 06:04 PM   #629
m.hony's Avatar
2013 30' Classic
That is to reduce slop and play in the L-pins, I think-
I have the ones with the flip-over wire bail at the L-pins and where the bars attach to the hitch head- much easier- the original ones with the cotter keys are in my rear bumper storage just in case I lose or break one.
TAC #MS-10
Airforums #70955
Old 05-28-2015, 06:27 PM   #630
Alphonse's Avatar
Lower Alabama , USA
No failure, that's how it came from Equalizer about 3 years ago.
Alan
Air #64439
TAC AL-8
2018 Canopenian
