Old 02-09-2015, 02:14 PM   #533
1998 30' Excella 1000
Livingston , Texas
Mefly, thanks for the info. The cost to change out shanks was exactly why I'm trying to pin that down.
Anyone else out there that has a 20" receiver height and can share their specific shank model?
Siegmann is offline   Reply With Quote
Old 02-09-2015, 08:17 PM   #534
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, the top of my receiver is also 20"s high; I asked George Sutton RV to order a new shank for my new F-150. I haven't received it yet and don't know the part number. Since this dealer sets up Airstreams with Equal-I-zer hitches, I trust that they should know which one to use.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 02-09-2015, 09:56 PM   #535
Livingston , Texas
Robert, when you get it, and assess the resultant hitch ball height, please post again, or send me a PM. Thanks--
Old 02-15-2015, 06:20 PM   #536
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
Has anyone changed their shank out to the 18" long one vs. the standard 12" model? I ordered one and installed it today to be able to lower my tailgate (2015 F150) while hitched up. I got it set up with everything looking pretty good. Front of TT about 1 lower than back of trailer, and front of TV about 1/2" higher than when unhooked. I have not towed any distance with it but was just curious if others have done this and what their towing experiences have been, positive or negative with the extended shank.
silverlabs is offline   Reply With Quote
Old 02-15-2015, 08:39 PM   #537
Livingston , Texas
Silverlabs, I asked the same question not too long ago and got no replies. I would assume that anything that moves the trailer pivot point further from the TV rear axle would reduce the towing stability. But I do not know if 6" would be significant.
Old 02-15-2015, 09:00 PM   #538
silverlabs's Avatar
Waxahachie , Texas
Siegmann, thanks for the response. I installed it today and just drove it back to storage. Seemed fine but that was short distance. Leaving next week for a 3-4 week trip so I will get some time on the road with it. Bringing other shank along and will change back if I don't like it. Thanks again.
Old 02-27-2015, 10:08 PM   #539
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Traded TV, machine 1000# bars?
I just traded my 2006 F150 for a 2013 Ram 2500. As has been stated here, the ride is somewhat stiffer and I'm considering machining the bars on my hitch. My trailer came from the PO with a 10000/1000 hitch. Since the trailer GVWR is only 6300#, one could argue that the 6000/600 hitch might have been a better choice for him (and for me). I am concerned about the shock being transmitted to the trailer, and am thinking about machining the bars to be equivalent to the 600# bars. I am assuming that I will still need/want some weight distribution, but i can't hook it up to measure yet because my hitch has a Class IV shank and the new truck has a Class V receiver. While i address that problem, I'd like to get ready to machine my bars.
Questions:
1. If you are towing with a recent (2007-2015) Ram 2500, how much weight are you shifting to the front axle?
2. Can anyone provide me with the height and width of the 6000/600 bars?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 02-27-2015, 11:59 PM   #540
Salem , Oregon
Images: 18
Hi, Siegmann; This is where I'm at right now. And I will post some pictures.
(1.) This is the shank that was recommended and later returned.
(2.) With this new shank in my receiver, It looks like I could plow a field with it.
(3.) I use a 4' stick with blue masking tape to mark fender heights; This one is my front fender unloaded.
(4.) This is my front fender when hitched; It is up 1/4".
(5.) This is my rear fender unloaded.
(6.) This is my rear fender when hitched; It's down 7/8".
(7.) This is the trailer connected using my cut-off Lincoln shank. I dropped the hitch by one hole on the shank.
(8.) This is my new Equal-I-zer brand standard shank. It is all set-up, greased, and torqued.
(9.) This is the side view. I later greased the ball and put my hitch away.
(10.) This side view shows the new shank attached in the same place as my test with the cut-off Lincoln shank; One exposed hole on top.
ID:	233274   Click image for larger version
ID:	233276   Click image for larger version
ID:	233278   Click image for larger version
ID:	233280   Click image for larger version
ID:	233282   Click image for larger version
2005 Safari 25-B
Old 02-28-2015, 12:24 AM   #541
Salem , Oregon
Images: 18
New shank continued.
Hi, My truck and trailer were on my RV pad and it has a very slight slope to it. I believe that when on totally level ground That 1/4" up in front might become zero, or back to unloaded height. Also during this test my trailer frame was 15 1/2"s high in front and 15 1/2"s high in rear. I believe this is as close as it gets on a RV pad set-up.
(1.) Front of frame.
(2.) Front of frame at 15 1/2"s high.
(3.) Rear of frame.
(4.) Rear of frame at 15 1/2"s high.
ID:	233284   Click image for larger version
ID:	233286   Click image for larger version
2005 Safari 25-B
Old 02-28-2015, 12:34 AM   #542
Salem , Oregon
Images: 18
Hi, I also wanted to mention that during this test set-up, I used the same 6 1/2 washers adjustment that I used with my Lincoln.
2005 Safari 25-B
Old 02-28-2015, 10:57 AM   #543
mefly2's Avatar
2015 25' FB Eddie Bauer
Questions:
Al
Do a search as I detailed the process you are describing for using the 1,000 EQ hitch with a 25 AS ... much smoother ride for the AS after I tapered the bars - when we went from an F150 to a Ram 2500.
Old 02-28-2015, 04:59 PM   #544
mefly2 - Thanks. I found a post that explained how to do the taper based on moment of inertia calculations but it didn't have the dimensions for the 600# bars. I don't think it was yours. Sounds like you did exactly what I want to do.
S/OS #004
Old 02-28-2015, 05:01 PM   #545
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
What dimensions do you want from the 600# bars. I have them and can measure.
Edit - Oh. I see now. Will measure.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 02-28-2015, 05:07 PM   #546
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
1-1/4" x 1-1/4"
