Old 10-01-2014, 09:05 PM   #421
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I noticed on the street side of my equalizer brackets the L bracket and the back clamp bracket have a slight bow to them. They must have been tweaked during the hitch release described above. What is the best way to straighten them or should I purchase new parts? I also discovered my old SnapOn torque wrench locking ring is stuck so I can't adjust the torque settings, its a glorified breaker bar now.
Kelvin
Old 10-02-2014, 03:48 AM   #422
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Everyone's back plate is bowed. It is a design flaw by Equal-I-zer. The metal is too thin. Equal-I-zer's solution is to turn the plate around with the bow the other direction to straighten it. When I did that, the plate bowed the other direction. I thought the simplest solution might be to get Equal-I-zer to send me a couple more of those plates and double them up (maybe weld 2 together). The bolts are long enough. These plates really should be thicker or gusseted to keep them from bowing.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-02-2014, 03:52 AM   #423
m.hony's Avatar
2013 30' Classic
If those back plates were thicker and would not bow, then we would have an easier time preventing the L-brackets from moving on the a-frame. If the plate would remain straight and contact the a-frame the entire length of the plate instead of just at the top and bottom when bowed, then it would be less likely to move on the a-frame.
TAC #MS-10
Airforums #70955
Old 10-02-2014, 03:52 AM   #424
m.hony's Avatar
2013 30' Classic
Another thing we could do is spacers along the bolts.
TAC #MS-10
Airforums #70955
Old 10-02-2014, 06:31 AM   #425
m.hony's Avatar
2013 30' Classic
Name:	ImageUploadedByAirstream Forums1412253025.142699.jpg
Name:	ImageUploadedByAirstream Forums1412253041.572424.jpg
Name:	ImageUploadedByAirstream Forums1412253053.834503.jpg
I've come to the conclusion that Equal-i-zer just ain't the one.
Too bad I sold my EazLift.
TAC #MS-10
Airforums #70955
Old 10-02-2014, 07:36 AM   #426
KJRitchie's Avatar
2008 25' Classic
OK. Sounds good. Do they get bowed when torqued to the 70lbs as shown in the user manual? My brackets didn't seem to shift the 1 1/2 years I've owned my Equalizer. I just want to make sure it doesn't impede the operation of the hitch. You wonder why they don't make the plates all the same thickness. I may purchase two back plates and put them on.
Kelvin
Old 10-02-2014, 11:04 AM   #427
m.hony's Avatar
2013 30' Classic
Yep. and they still slide back and force on the trailer frame.
Equal-i-zer is sending me new inside link plates. I'm gonna try doubling them up (the bolts are long enough) to prevent them from bending.
It is my opinion that these inside link plates should have been thicker or gusseted to prevent bowing.
My L-brackets don't appear to have moved much lately like they used to. Maybe they got the a-frame sorts roughed up so they bite better.
Also, I threw out that 70 ft. lbs. thing and just git 'em sho nuff tight. At 70 ft. lbs. they walk all up and down the trailer frame.
Actually I've thrown all of Equal-i-zer's instructions out the window. 4 washers and the bars parallel = zero weight distribution for my rig. No, my hitch ain't bent. 6 washers and the bars tapered up toward the L-brackets = weight distribution and sway control for my rig. I know everybody ain't pullin' a 30 with a Tundra. Maybe those Equal-i-zer instructions/suggestions work perfectly with some rigs, but I'm havin' to go rogue/rebel and find out on my own what works best through trial and error.
Equal-i-zer says the bent hitch head is no big deal and will not affect safety.
TAC #MS-10
Airforums #70955
Old 10-02-2014, 11:40 AM   #428
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
My 'L' brackets have been bent for 12 years on 4 different trailers with no ill affects. To stop them from moving on the frame I cut pieces of dry wall sanding screen to size to fit between the brackets and the frame then tightened 'em down. They never moved again.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 10-02-2014, 12:03 PM   #429
m.hony's Avatar
2013 30' Classic
Call them up.
They will send you new inside link plates.
Actually calling isn't necessary. An email will do.
TAC #MS-10
Airforums #70955
Old 10-02-2014, 12:05 PM   #430
m.hony's Avatar
2013 30' Classic
It is still my opinion that the inside link plates should have been thicker or gusseted. Bent inside link plates may not hurt a thing, but straight ones look better to me.
TAC #MS-10
Airforums #70955
Old 10-02-2014, 12:07 PM   #431
KJRitchie's Avatar
2008 25' Classic
Good tip. I've got some of that drywall sanding screen somewhere. My 2008 Classic 25fb is a heavy weight too. I want to add one washer but need to get a deep socket 1 1/8". I hope I can budge the bolts. Since my hitch pin incident with the head dropping to the road and dragging a few feet on the bottom of the shank that must have tweaked my head so the washers are loose on the large rivet. With the power jack broken and waiting for a replacement I've borrowed a floor jack and some jack stands to get the trailer off the TV so I can work on the head bolts. I'll attempt this on the weekend. If I can't get the shank bolts off then its off to an RV shop.
Kelvin
Kelvin
Old 10-02-2014, 12:39 PM   #432
m.hony's Avatar
2013 30' Classic
Reckon I'm gonna head on down to Ace Hardware an' git some o' dat dry wall sanding stuff y'all are talkin' 'bout.
TAC #MS-10
Airforums #70955
Old 10-02-2014, 02:38 PM   #433
dznf0g's Avatar
Oswego , Illinois
It also works well on the bottom of boards used as levelers. Keeps them from sliding on each other. I have some I used for 20 years and never slipped while backing on or been replaced!
-Rich-
Old 10-02-2014, 05:36 PM   #434
m.hony's Avatar
2013 30' Classic
Or scooting away when the tire hits them?
TAC #MS-10
Airforums #70955
