Old 04-12-2013, 08:58 AM   #155
2009 34' Panamerica
weyburn , Saskatchewan
dzn that was a very good atricle to read. My setup right now seem good for the measurements on truck front and back but the bars are so hard to get on and off and I am use to making stuff work with force working on oil rigs and farming. I feel it might damage trailer if it takes that much force to get bars on and espically off. Is there a specal safe way to take bars off other than just pulling them sidways and making sure feet are not in the way.
Pedecanada is offline   Reply With Quote
Old 04-12-2013, 10:28 AM   #156
JimGolden's Avatar
1977 31' Excella 500
PedeCanada,
Use the trailer jack to lift the back of the truck up.
That takes the tension off the bars.
Then you can pull them off with one hand.
After they are off, lower the jack back down to where the tongue of the trailer is sitting on the ball, unhook the ball coupler, then run the jack back up, lifting the trailer off the ball altogether. Now you can pull away with the truck.
Piece of cake.
- Jim
JimGolden is offline   Reply With Quote
Old 04-12-2013, 10:32 AM   #157
dznf0g's Avatar
Oswego , Illinois
Originally Posted by JimGolden View Post
PedeCanada,
Piece of cake.
Exactly. most of the AS jacks are 3500# capacity.
-Rich-
Old 04-12-2013, 12:02 PM   #158
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Ped', I think the numbers you were giving were metric. Most of us in the US don't do well with them, but it does help if you identify that you are talking Kg. and Cm.
Note that after a while with a new hitch, the washers tend to compress a bit even though they are hardened. So anther adjustment with more washers is to be expected later.
Gene
Gene
Old 04-12-2013, 11:27 PM   #159
2009 34' Panamerica
I will try using jack to lift trailer couplted to truck to get bars off. So if you did not do this would it be very hard to get bars off or am I missing something.
Old 04-13-2013, 08:21 AM   #160
Master of Universe
Gene's Avatar
The difficulty of getting the bars off depends on whether the truck and trailer are at the same level. The higher the truck is, the more difficult. But even with both level, lifting the trailer with the jack is necessary. One bar will come off first, then lift the trailer some more to get the other off. It helps to have someone on each side to see which bar comes off first—for us, it is usually the one on the driver's side.
There is a lever provided with the Equalizer to help get them on, but is less help getting it off. Sometimes I have used a claw hammer to help move the last of the two off the L bracket.
Gene
Gene
Old 04-13-2013, 12:11 PM   #161
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
I can not even imagine trying to remove bars without first raising the truck with the jack!!!
mstephens is offline   Reply With Quote
Old 05-07-2013, 01:49 PM   #162
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
After about a month's ownership and about 1000 miles of towing I noticed the two swinging arms where the bars connected could be swiveled with ease compared to when we first got it. I checked the user manual and those nuts are supposed to be torqued to 45lbs and now I can't budge them. Probably gotta insert the bars. Do these nuts come loose frequently?
Kelvin
Old 05-07-2013, 02:45 PM   #163
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Kelvin
Hi, I think there is some slight wear on the hitch head, temp changes, and the pushing out of the grease that causes this to happen. I replaced my bolts with grade eight bolts and torque them to 80 lbs or 100 lbs depending on how I feel. [they shouldn't be able to move without the help of the spring bars] Before each trip, I take the hitch head apart to clean and re-grease the area where the spring bar sockets ride. On long trips, I try to do them once in the camp ground.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-07-2013, 03:05 PM   #164
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
I saw that Equalizer is changing their upside down L bracket to be 1 piece rather than having a loose pin at the bottom. I'm going to look into this part because I fear loosing these pins. I have not seen the part on their web site yet. I read it on RVPro
subfan1 is offline   Reply With Quote
Old 05-08-2013, 08:24 AM   #165
2009 34' Panamerica
Thanks for the help its very easy to get bars on and off now and system seems to work great.
Old 05-08-2013, 08:48 AM   #166
mefly2's Avatar
2015 25' FB Eddie Bauer
Any further details on this change ... or a link?
Old 05-09-2013, 05:35 AM   #167
KJRitchie's Avatar
2008 25' Classic
Equalizer didn't redesign their bracket pads for these brackets either. I have the newer 1 piece style where you just flip over a retaining bar and the retaining bar doesn't clear the nylon bracket pad. I suppose I could cut away some of the material but that may jeopardize the design. I think I'll return the part to eTrailers.
I tightened the end bolts of the swing arm and added some lithium grease and it seemed to help with the noise so I may just bypass the pads.
Kelvin
Old 05-09-2013, 10:22 PM   #168
TahoeStream'n
subfan1's Avatar
Sorry I delete the emails I receive from RVPro. I saw it on Monday or Tuesday's email from them. I copied the part number and tried to find it on their website but couldn't. It does not come up yet.
