Old 04-03-2013, 08:53 PM   #141
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by KJRitchie View Post
We would never travel with 39 gallons of water, maybe 10 gallons.
Kelvin
Kelvin
Isn't that a bit sloshy ... hard even on models with baffles in the tank ...
Old 04-04-2013, 06:37 PM   #142
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I would think that is 195 lbs for me, 157 lb for the wife and the tech 160 lbs plus a full water tank (39 gallons) when the hitch was installed.
Kelvin
Kelvin
Kelvin Kelvin, does your wife read these posts about her weight?
If the answer is yes, contact your lawyer soon.
Gene
Old 04-04-2013, 06:47 PM   #143
steverino's Avatar
2010 27' FB Flying Cloud
Ivins , Utah
I'm sorry, I find this hard to believe. With all the over-hitching threads and others, you'd think these units are so fragile we should wrap them in bubble wrap and park them in a (climate-controlled) garage!
Edit: OOPS - No, no, no, bubble wrap would mar the finish. Swaddling cloth, then :-)
steverino is offline   Reply With Quote
Old 04-10-2013, 12:13 AM   #144
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Large drop for Suburban/Tahoe/Yukon?
Hello again,
I'm still waffling about what hitch to get for my soon-to-arrive 25FB Flying Cloud. I have a 2010 Yukon Denali with auto-leveling rear air shocks. The top of the receiver on the Yukon is 24 inches off the ground. I found a calculator on the Equal-i-zer web site that tells you what shank you need for given values of receiver height and trailer coupler height. For my case, it says " we were unable to determine the right shank for your needs". An earlier poster on this thread mentioned a problem with the drop needed for his Suburban. Is there a reasonable solution? Or should I write off Equal-i-zer and look to another brand?
Steve
SSquared is offline   Reply With Quote
Old 04-10-2013, 12:51 AM   #145
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
There are plenty of shanks out there. You need to go to an RV parts store and get what you need from them. My truck is only 20" to your 24" but I know there are longer shanks then what I use. The EQ hitch is a good and common system. You will have similar issues with other systems because its not the WD hitch, it's the shank drop.
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
RUMSHIP is offline   Reply With Quote
Old 04-11-2013, 12:08 PM   #146
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
Originally Posted by SSquared View Post
Hello again,
Steve
I have a Suburban with an Equalizer. I use a drop shank supplied by the hitch folks and it adjusts just fine to the proper height for the trailer.
On another note: Be cautious about the GM autoride, or level ride feature when towing heavy trailers. I blew out two air compressors in 12 months on my Sub. Those are $700 each repair. I have decided that towing with a big trailer places too much duty cycle on the compressor, and so I am converting my suspension to a passive system. IMO, the autoride was meant to level the car when carrying passengers in the third seat and probably works fine for that.
mstephens is offline   Reply With Quote
Old 04-11-2013, 08:33 PM   #147
2009 34' Panamerica
weyburn , Saskatchewan
I have a problem setting up my e2 on my 2010 dodge 3500 diesel single axle to a 2009 airstream Panamerica. I have 1000 pound bars. To get my truck to lift back end back up and lower front the bars are hard to get on even with hitch lifted up and to get bars off is even worse even with hitch off ball this is my measurement. front back
2 holes showing at top empty truck unhooked 105 145
trailer weight on truck no e2 hooked up 115 100
trailer weight on truck e2 hooked up 110 105
3 holes showing at top empty truck unlhooked 105 145
trailer weight on truck no e2 hooked up 110 100
trailer weight on truck e2 hooked up 105 115
My hitch heifgt is 22 on top of ball and trailers all for corner are the same and level. I have 6 spacers in since my truck is a mega cab and is long. Only problem is getting bars on is hard and getting off is worse even with lifting hitch of trailer off ball. Bars are even with frame. Thanks for any help.
Pedecanada is offline   Reply With Quote
Old 04-11-2013, 08:41 PM   #148
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
6 spacers is giving you a lot of angle on the bars. I think I'm using 4. Your #s look a little light on the back after hook up. I don't under stand the more spacers because you have a long truck. Sorry just rambling.
With a 1 ton you should be able to use less spacers transferring more weight to the rear end and giving you a better or less angle on the bars which would give you an easier lift on and off with the bars. Understand?
2/12/68 - 8/18/92
Old 04-11-2013, 09:36 PM   #149
2009 34' Panamerica
Sorry about last post was in rush. I though I read in manual for longer vehicle use more spacers but what you are saying makes sense. The truck back end drops 45 with trailer load with no e2 with e2 hooked up and two hole showing on top of frame bars it drops 40 and font rises 10 with trailer load and with e2 hooked up front comes back down 5. Bars are not bad to get on but need trailer off hitch and helper bar to get on and off. With 3 holes showing on top it very hard to get bars on and very hard to get off. It raises back of truck 15 and lower front 10 back to unloaded height. Trailer hitch height and levels are good why are bars so tight. Will putting in less spacers like 4-3 make it easier to put bars on and off seems like front of truck is getting lower faster than back is rising. Thanks for help.
Old 04-11-2013, 10:17 PM   #150
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
Less spacers will take the angle out of the head and put more weight on the back of the truck. The bars should go on easier at that point.
2/12/68 - 8/18/92
Old 04-11-2013, 10:26 PM   #151
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
http://youtu.be/LaLJEJ2-HSo
Here is a link that might help with hooking up.
2/12/68 - 8/18/92
Old 04-11-2013, 10:42 PM   #152
2009 34' Panamerica
I will try 3-4 spacers next time and see how it works. Thanks
Old 04-11-2013, 10:49 PM   #153
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
Here's a better vid that shows just hitching up. I think you will be happier with less spacers.
No problem have fun.
http://youtu.be/O-Wztf_C-Q4
2/12/68 - 8/18/92
Old 04-12-2013, 07:22 AM   #154
dznf0g's Avatar
Oswego , Illinois
However, read this, relative to head angle. I find this to be a great article, even if I don't agree with other "Andy" methodologies.
Installing_Hitch_by_Andy_Thomspon.pdf
-Rich-
