Old 04-04-2012, 04:14 AM   #1
1976 31' Sovereign
St. Petersburg , Florida
Equal-i-zer + add on sway control?
Prior to taking possession of our "new" '76 31' LY, I ordered a friction sway control, along with a class IV hitch for my E350 PowerStroke van. When I got the unit from the PO, I realized that the WD hitch was the Equalizer brand.
My question is, is it overkill to use an add on friction control with this hitch. I've been reading great comments on this forum about the Equalizer brand, and am thinking it might be unnecessary, or possibly a negative, to add the friction unit.
We've been crossing the country every summer in a '74 GMC, towing a little Tracker. We've encountered wicked winds on almost every trip. I don't mind spending a little extra if it's going to be of help, but if it's totally unneeded, or there is a down side, I'd like to know.
Also, I've seen mention of some slip on pads that are now available for this brand. I'd like to know the consensus of opinion about these.
All comments will be appreciated.
Thanks all.
NewbieAndy is offline   Reply With Quote
Old 04-04-2012, 06:22 AM   #2
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
I have an Equalizer brand hitch that I used on my old trailer. It worked fine for me for weight distribution and sway control. I did not use the noise pads. I would not use a friction bar with the Equalizer hitch. One of the benefits of the Equalizer hitch is the freedom to back up without the concern of the angle you put the friction bar into. When the wind is too much for the Equalizer hitch, it's time to get off the road.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 04-04-2012, 06:40 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We've owned and towed with an Equalizer brand hitch for over 18 years and 5 different trailers, including bringing Little Girl home from Mississippi, a 1300 mile trip. Never felt the need to add any additional sway control on any of the trailers. 6 or 7 years ago, we added the nylon slip pads, and that did quiet the hitch down considerably, without a loss in sway control.
Chris
Old 04-04-2012, 06:47 AM   #4
dznf0g's Avatar
Oswego , Illinois
IMO, it is unnecessary. If you keep the socket bolts on the EQ torqued down to 60LB/ft, you will need no additional friction control. I'd return the friction bar.
-Rich-
Old 04-04-2012, 07:11 AM   #5
JFScheck's Avatar
Rockville , Maryland
Images: 33
Sounds like the Equalizer is not really enginerrred to utilize sway control as its an aftermarket bolt on?
Just curious to know...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-04-2012, 07:16 AM   #6
2004 16' International CCD
Orem , Utah
Sounds like it maybe e2 setup with round tubes
My local dealer offers both e2 an e4 how are they that much different.
starcraft is offline   Reply With Quote
Old 04-04-2012, 11:12 AM   #7
1976 31' Sovereign
Thanks to all. I appreciate the help, and the comment about getting off the road when it's too windy for the Equal-I-Zer.
Old 04-04-2012, 07:14 PM   #8
Minno's Avatar
1972 31' Sovereign
Our experience has been that the built-in sway control of the Equilizer works very well on it's own. We have never felt the need to add any other sway control to the unit. BTW, slowing down even just 5 MPH in very windy conditions vastly increases your control of your rig. From what we've seen on our many travels, the people who are fish tailing down the road are traveling WAY too fast. The joy is in the journey.
Kay
Old 04-04-2012, 07:24 PM   #9
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Minno's Got it Right...
... as do the others who have posted to this thread.
It would be a mistake to add friction control and could have unintended consequences. Otherwise, as Minno suggests,
Know when to slow down.
Know when to get off the road.
Operator error can overcome even the best hitch set up.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 04-05-2012, 03:13 AM   #10
1976 31' Sovereign
Thanks again.
The friction unit is, already, on it's way back. Great forum, great advice.
I'm sure it will not be long before I'm back with another question as we ready this unit for our spring migration to Oregon.
Old 04-05-2012, 03:22 PM   #11
mcintoshMD's Avatar
2012 20' Flying Cloud
Hopewell , Virginia
I love my equalizer, I have a toyota 4runner as the TV and the 2012 , 22' Flying Cloud, I just purchased a Toyota Tundra, the 4 runner is still on the premise. Question is , do I need to go through the whole nine yard of tweaking the equalizer before heading out?
I plan to keep both TVs for different purposes.
mcintoshMD is offline   Reply With Quote
Old 04-05-2012, 03:56 PM   #12
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
I would do the measurements on both vehicles. You might get lucky and have them both close enough that you won't have to tweak it every time. You might get lucky.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 04-05-2012, 05:15 PM   #13
mcintoshMD's Avatar
Hopewell , Virginia
They both measured 16 " from the ground to the lower edge of the tow hitch, i.e. the ground clearance is exactly the same.
Old 04-05-2012, 05:21 PM   #14
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Suspensions May be Different
In theory, if the suspension systems on the two trucks are identical, you shouldn't have to change a thing...
But are they identical?
Remember you are decompressing the rear suspension and transferring the load (compressing) to the front.
Ken L
1966 Tradewind 24
1965 Globetrotter floor on restoration REDSLED88 Repairing/Replacing Floor &/or Frame 80 01-17-2016 06:20 PM
TX Veteran Designation on Drivers License Bluto Off Topic Forum 43 06-27-2012 12:31 AM
Looking for advice on possible purchase chiefbrody 1975 Overlander 12 04-09-2012 08:12 PM
How important is the electric brake control vanster Towing, Tow Vehicles & Hitches 18 04-06-2012 12:57 PM
Basic noobie question - add shelves? akroyd General Interior Topics 12 04-04-2012 08:50 AM
