Old 09-28-2004, 09:28 PM   #1
Smile Equal-i-zer
Has anyone out there had any experience with the " Equal-i-zer" brand hitch. I have ordered a 2005 Bambi 19 with LS pkg, and part of the deal was an Equalizer. I haven't heard of them up here. Any good/bad news?
G&TMTrails is offline   Reply With Quote
Old 09-28-2004, 09:46 PM   #2
ardenrj's Avatar
I just bought a new '04 19 foot Bambi with the same setup. Iv'e only had it out a few times for very short trips and it seems to work well. I also bought a Reece friction anti- sway bar for it. Problem with that though is that you cannot tighten or loosen the friction pad with the lever as the propane cover gets in the way.
ardenrj is offline   Reply With Quote
Old 09-28-2004, 10:32 PM   #3
JohnG's Avatar
I use the Equal-i-zer
An excellent hitch. No problems and I loive that you don't have the chains to tighten up and let back down. I also have an added on sway control bar. This is mounted to the side of the AS frame and the side of the EQ hitch. I have had no problem using it.
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 09-28-2004, 10:35 PM   #4
JohnG's Avatar
You could try to mount it over the small balls with the sway bar being loose and then remove it carfully and tighten it then place it back on the balls and pin it. Or you may have to shorten the bar and use a wrench to tighten it up once it is in place.
John G
Old 09-28-2004, 11:47 PM   #5
1975 29' Ambassador
Reno , Nevada
An Equal-i-zer brand hitch does not need any additional sway control device. Sway control is built into the design of the hitch. But many confuse this hitch brand name with 'equalizer' load leveling hitches such as those made by Draw tite or EAZ lift.
The Equal-i-zer is on a par with the Reese Dual Cam as far as sway control. This is better than the most typical friction bar that needs the extra little ball. It isn't quite in the league of the Hensley Arrow or Pullrite.
The Equal-i-zer hitch runs about $400 and has an advantage over the Dual Cam in that it is a simpler design, doesn't require drilling holes in the trailer A-Frame, doesn't conflict with propane bottle mounting, and is easy to install and adjust.
The biggest complaint I have heard is about noise when not greased as suggested in the instructions. As far as usage and operation it seems to get very good reviews on the boards.
i.e. the Equal-i-zer brand integrated load leveling and sway control hitch is a highly recommended mid to low cost option for trailer towing.
Old 09-29-2004, 06:46 PM   #6
I have an Equalizer, and am very pleased with it. I wanted a Reese Dual Cam for my 22' CCD, but had problems mounting it on a smaller frame. So I ended up with the Equalizer, and I think I was lucky. Just returned from a trip to Alaska, and it worked great. To eliminate the noise, just follow the lubrication suggestions in the manual.
Tom
Tom
2004 22' Intl CCD
2003 Toyota Tundra SR5 (Std Cab)
Equalizer
temcotom is offline   Reply With Quote
Old 09-29-2004, 07:09 PM   #7
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
I was recently at the largest RV dealer in the state of Montana, Bretz RV, located in Missoula, MT, and the only Airstream dealer in MT. I think they have something like 26 service bays, and found it rather strange that their service manager told me they had never seen or heard of a Reese Dual Cam. He claimed that everyone in their part of the world uses Equalizers, and it is so common that most locals use the name Equalizer in a generic sense similar to calling all tissues "Kleenex"...it crossed my mind that maybe he was just pulling my leg about never seeing a Reese Dual Cam while he charged me $95 for making a 5 minute adjustment to mine!
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 09-29-2004, 09:02 PM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
After using a Reese dual cam sway control for over 6 years I switched to an Equal-i-zer with the 2004 Classic. Both hitches are great choices. From my experience, the Equal-i-zer is easier to hitch.
My reason for changing was the fact that the Reese dual-cam that I owned had clearance issues with the propane bottle carrier on my SOB and on my '01 Safari. The newer dual-cam unit required drilling into the A-frame of the trailer. The Equal-i-zer was a bolt on with no drilling or clearance issues with the propane bottles.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-29-2004, 09:44 PM   #9
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
I have same problem. I set the length between balls without the locking pins and then tighten to the desired position. Then reattach with locking pins.
I had to test the tightness setting two or three times until I reached the desired sway control. After that it is just a matter of duplication each time.
wingfoot321 is offline   Reply With Quote
Old 10-01-2004, 12:16 AM   #10
Dan&Barb 25'Safari FB/SE
CaliforniaStreamin's Avatar
La Mesa , California
Images: 33
We just brought our Bambi home from Eugene Oregon to San Diego using the "Equalizer" brand hitch and it works great, pulling straight without any movement at all behind our Tundra. The dealer suggested this and we are very happy, as even on the 2 lane roads with some big trucks we never had a tense moment. It does make this "groaning" sound so I will get out that manual as we didn't know there was a fix! Here's a few pics of the hitch set up.
BTW, congratulations on your new Bambi...we love ours
Barbara
ID:	8943   Click image for larger version
CaliforniaStreamin is offline   Reply With Quote
Old 10-01-2004, 08:33 AM   #11
Elgin , Texas
Images: 164
Thumbs up Equal-i-zer OK for me!
I purchased a an Equal-i-zer the day I bought my Airstream and have to say it seems to work great and is a breeze to set up and connect.
bake315 is offline   Reply With Quote
Old 10-01-2004, 09:44 AM   #12
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Stupid Equilizer trick....
Greetings.
I am also in the Equilizer camp. I tow with my VW Eurovan our 19' CCD. I was real scared at first, but found that I actually had less sway and such from big rigs on the expressways, than I did when there was nothing being towed! Needless to say, I drive cautiously, and am really happy with the Equilizer set up.
When I took delivery of my AS last May, I practiced hooking and un-hooking the trailer in the dealers parking lot where I "camped" a few nights to check all systems.
The first thing I wondered was how anyone could possibly lift the hitch assembly any more than one time before needing a good chiropractor. The thing weighed a ton, was ackward, and where the hell do you put it when you store it.
As it turned out, I was doing it all wrong. I thought that the two heavy "spring" bars had to stay attached to the hitch/ball assemby. After contemplating life with a perpetual hernia of everything, an RV cleaning person who worked after hours at the dealership, watched me in dismay wrestle with the Beast-U-Lizer. She told me it might be easier if the "spring" arms were detached from the hitch/ball assembly. Before I could catch my breath to say something rediculous, she pulled the cotter pins on arms, and my lifting was now cut in half. I told here not to tell anyone, or I would have to kill her, but also thanked her much. DOH!
I store the arms in the trunk of the AS, and the main hitch/ball thing sits in front of the CCD door on newspaper. I keep it there so it is easy to get at, and that I don't forget to use it before pulling away
Good luck with your Bambi. We absolutely love ours, warts and all, and are sure that you will love yours as well.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 10-01-2004, 11:18 AM   #13
Images: 59
Originally Posted by crazylev
Greetings.
. . . and the main hitch/ball thing sits in front of the CCD door on newspaper. I keep it there so it is easy to get at, and that I don't forget to use it before pulling away
Jonathan
Ha Ha
You've convinced me. I think I will get an Equal-I-Zer.
Old 11-24-2004, 01:21 PM   #14
B25guy's Avatar
2003 25' Safari
Yakima , Washington
Images: 20
anti-sway or not??
I've towed my 25' Safari SS cross-country once with my Equal-I-zer and have to say that sway and weight distribution were great...or were they?
I did notice that the 5/8" square head bolt would loosen, not enough to fall out or allow the L-bracket to drop. However, even when I tightened the bolt (about 35 ft-lbs), there was still noticable movement at the bottom of the L-bracket, to the tune of about 5/8". This frustrated me because I thought how could the moving bracket (rocking back and forth within the pocket of the side plate) provide any anti-sway?
Being an engineer by trade, I ran some numbers (gotta love that!) and figured at roughly 2 degrees of "sway" (difference between trailer and tow vehicle), the bars would move approximately 1/8", at 4 degrees of "sway" the bars would move about 1/4" and at 6 degrees, the bars would move just shy of half an inch. Finally, at 10 degrees of "sway", I computed the bar's movement would have just exceeded the "slop" of the moving bracket!!
I found this to be extremely odd given that 10 degrees of sway is squarely in the realm of "white-knuckle" handling qualities.
I've contacted the manufacturer about this for their comments and they said that they were aware of the movement but didn't think it would adversly affect the anti-sway. But what about the numbers?
I've since found a "different" way of hooking up the side plates and L-brackets and have bounced it off of the manufacturer and they don't see a problem with my set up.
Just wondering if anybody else ever sat there and wondered why those dang L-brackets were so loose!
B25guy is offline   Reply With Quote
One Elec Brake not Equal to Other Three wingfoot321 Brakes & Brake Controllers 1 04-24-2004 03:01 AM
original sway control Charming Wino Hitches, Couplers & Balls 15 03-27-2004 09:01 PM
"_Balancing Tires_" Silvertwinky Tires 15 02-22-2004 11:33 AM
davenport iowa bike rally john hd Other Rallies & Events 29 09-02-2003 11:54 AM
LPG furnace vs elec. space htr. Astrodokk Airstream Motorhome Forums 4 06-25-2003 08:11 PM
