Old 06-04-2011, 04:40 PM   #1
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
equa-li-zer model 90-100-1000
tounge weight 1000 klbs....trailer weight 10,000 lbs.....this is what i have been using...what the dealer recommended for my 08 25fb safari gvw 7300......set up incorrectly, i believe at the onset by the dealer and soon i began to get dangerous and study the instructions and set it up the way i thought was correct.....and there it stayed for about 25000 miles with no problems other than the travel on the frame...
it was then, last october when i ask cc II in buda to help and replace the bolts that hold the unit to the trailer frame......they did and it was not long after that that the bolts began to shear off the frame about 1000 miles ...and the last time this happened they sheared my propane line.......and i was able to make it back to ccii and they discovered (by accident) that the head of the hitch was cracked and they contacted the mfg and the head was replaced free....additionally they included a new set of bolt plates to hold the bars........and of course the dealer competely set the hitch up again....completely different than it had been the previous 25000 miles...
and then the hitch receiver twist completely OFFFFFFFFFFFabout 6000 miles down the road.......
WTF OVER
ID:	131509   Click image for larger version
ID:	131511   Click image for larger version
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 06-04-2011, 04:57 PM   #2
WTF OVER
Your anger will not go away until you make some changes in your hitch.
First of all, the Equalizer brand bars have very little give, or bend, which in turn, transfers much more road shock to the trailer as well as the ball mount.
With the trailer and tow vehicle you have, you should be using no more than 600 pound bars.
But, if you wish to further improve the issue of failures, I would suggest you look into a Reese 600 pound full sway control hitch. Those bars offer much more flexing than the Equalizer could ever give you, as well as a far superior torsion sway control.
Old 06-04-2011, 05:10 PM   #3
WTF OVER
Perhaps this article will help you.
The Hitch Torsion Bar Story
Old 06-04-2011, 05:15 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs down Sad but true....
I have retired from the Chevy store but as of two years ago this was still a concern..http://www.airforums.com/forums/f464...les-34603.html
When we got our 06 Burb the first thing I did was install a Tow Beast...45008 - Reese Titan® Class V Receiver - RedTrailers.com
Go thru the entire thread...'yer not alone...
Name:	3 REESE CLASSV.jpg
ID:	131523   Click image for larger version
Name:	2006 Suburban OEM reciever 003.jpg
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Bargman L-77 thumb lever model?????? alumi-zen Doors & Locks 3 08-04-2014 12:34 PM
Hot Water not working, 1991 Excella 1000 34' jbbaldwin Water Heaters, Filters & Pumps 8 06-01-2011 10:50 PM
93 Airstream Excella 1000 34J rear bed side bath 3 axle eBay Watch Airstreams on eBay 0 03-22-2011 02:20 PM
'1989- 32' EXCELLA 1000 AIRSTREAM excellent condition eBay Watch Airstreams on eBay 0 02-10-2011 10:10 AM
