Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 06-01-2011, 06:47 AM   #1
2017 27' Tommy Bahama
Treasure Island , Florida
Equa-li-zer 6000 lbs for 25' CCD international
Anybody could tell me if a 6000 lbs Equa-li-zer would work on a 25'CCD International?
danyfr67 is offline   Reply With Quote
Old 06-01-2011, 06:52 AM   #2
I have one for a 25 Safari, 6000 gvw.
handn is offline   Reply With Quote
Old 06-01-2011, 09:52 AM   #3
Road Ruler's Avatar
Images: 38
All depends on.....
Type of TV, and wheelbase of the TV.
How heavy the tongue weight when ready to travel.
Old 06-02-2011, 06:23 AM   #4
it's a 2006 Ford F150, not sure about the tongue weight.
Old 06-02-2011, 06:24 AM   #5
Handn, is your equalizer working for you? what type of TV do you have?
Old 06-02-2011, 06:49 AM   #6
SteveH's Avatar
Common Sense , Texas
If the bars are 6000 lbs, that sounds about right. However, if the gross trailer weight of the hitch head is 6000, you will be past the max once loaded to travel.
Regards,
Steve
Old 06-02-2011, 09:06 AM   #7
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I have an equalizer 6000# for my TW. The bars are 600lb. The tongue weight on my TW is over 500 so you might check your tongue weight before you buy. If you need assistance the customer service folds at Equalizer are first rate, give them a call.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 06-02-2011, 10:28 AM   #8
You should use bars rated at 600 pounds, AND, also a "sway control".
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-02-2011, 01:07 PM   #9
I have a diesel Excursion.
My Equalizer has worked fine for me for the 6 1/2 years I have had the trailer. It functions as a sway control. No sign of wear.
I have to adjust the support brackets from time to time as they are bolted to the trailer frame and have a tendency to "walk" on the frame.
I have to be careful going over whoop de doos and vados or the hitch will bottom out.
2002 Airstream International CCD eBay Watch Airstreams on eBay 0 05-25-2011 06:00 PM
2002 Airstream International CCD eBay Watch Airstreams on eBay 0 04-08-2011 10:50 PM
2004 Airstream International CCD 16' Bambi eBay Watch Airstreams on eBay 0 03-06-2011 05:00 PM
2003 Airstream International CCD 22' Camper No Reserve! eBay Watch Airstreams on eBay 0 03-03-2011 03:40 PM
2009 Airstream 16 BAMBI INTERNATIONAL CCD eBay Watch Airstreams on eBay 0 01-06-2011 08:50 AM
