Old 04-29-2017, 01:24 PM   #1
1954 22' Flying Cloud
1967 24' Tradewind
manerba del garda , Italy
Emergency decoupling what doing
Hi folks,
what should you do in case of decoupling while towing? I know breakaway switch will slow down the trailer and chain keep the link with the towing vehicle I guess I'd feel a stroke and swerving so instinctively my foot is already going to the brake...is it the right procedure? did you face similar experience in the past?
Luca
luca16 is offline   Reply With Quote
Old 04-29-2017, 03:12 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I had a 2500 lb trailer come off the ball on the interstate. The chains held the tongue up. I eased off the gas and let the rig coast to a stop on it's own. I did not brake. Neither trailer nor truck suffered damage
CRH is offline   Reply With Quote
Old 04-29-2017, 03:20 PM   #3
2015 30' FB FC Bunk
Ayer , Massachusetts
I've always looked at the connection of the chain to the trailer frame and felt it was designed to hold the trailer if it were a mild event, like if it just dropped from the hitch, but break away entirely if the trailer went into a violent roll or flip. It just doesn't look that strong, at least it could be made much stronger.
Ted S. is offline   Reply With Quote
Old 04-29-2017, 04:10 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I would gently apply the trailer brakes, gently steer and as possible coast to a stop. When you come to a full stop exit your tow vehicle and kiss the ground.
Old 04-29-2017, 05:58 PM   #5
AirstreamJim's Avatar
2007 25' Safari FB SE
Baldwin Harbor , New York
What he said.
WBCCI 1433
Long Island, NY
Silver Meteor - 2007 Airstream Safari SE LS 25FB
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
AirstreamJim is offline   Reply With Quote
Old 04-30-2017, 08:08 AM   #6
1967 24' Tradewind
is there a rule about chain's amount or just not too short not too long? Thanks for your replies!
Luca
Old 04-30-2017, 08:45 AM   #7
2005 30' Classic
Burlington , Ontario
One point about the OP's comment on breakaway switch. I always thought that the breakaway switch should be set up such that it won't trigger unless the chains fail and the trailer is totally free from the tow vehicle. At least that is the way the length of cable on my break away switch is set up. Wonder if that is correct? I think so.
As far as dealing with the situation I agree with what others have said - if I ever sensed that my trailer was disconnected except for the safety chains, I think my course of action would be to do everything very gently in braking to a stop!
Whether I would have the presence of mind to do that in a real life emergency remains to be seen, but I do think it would be the wisest course of action!
In fact, if the safety chains are holding properly, I am wondering if the best thing to do would be to get off the accelerator and gently apply just the trailer brakes (manually) to slow the rif down as you pull over?!
Would take a lot of calmness and resolution!
Old 04-30-2017, 11:40 AM   #8
Box Elder (formerly of Center Moriches, NY) , South Dakota
"I know breakaway switch will slow down the trailer and chain keep the link with the towing vehicle"
ONLY if the cable to the breakaway switch and safety chains have been properly set up. I would want the cable to the breakaway switch to be slightly shorter than the safety chains. That way, if the trailer comes off the ball, the crossed safety chains should keep the trailer hitch from dragging on the ground and, the shorter cable should be pulled out thus activating the trailer brakes. If your trailer's brakes are properly adjusted, you shoud feel them as they activate and slow your trailer. Gently slow the tow vehicle while pulling off the road where it's safe to do so.
NY24 is offline   Reply With Quote
Old 04-30-2017, 01:21 PM   #9
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
this is the key reason to insert a cotter pin through the hole in the coupling latch. I had never thought of it but after witnessing a decoupling I now do this every time . Safe travels. jon
B00merang is offline   Reply With Quote
Old 04-30-2017, 01:48 PM   #10
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
Ok, folks. I'm not a dangerous person, just a person who has towed trailers for hundreds of thousands of miles over 40 years. With that said, I've had a trailer come off my tow vehicle four times in my towing career. Here is what you will do and what you should do . . .
My worst event was towing an 18' inboard-outboard speedboat with a single axle trailer with surge brakes. The coupler wore over time (I told you I towed alot) and popped off the ball while rounding a gentle curve with a succession of oscillating bumps in the road. Just the right combination to pop off. First thing I heard was grinding and scraping. Thinking it was a blown tire, I applied the brakes. I was immediately rear-ended by the boat dragging along by the chains. It raised the rear end of the Taurus station wagon and nearly jackknifed the rig. I hit the gas and the front wheel drive vehicle pulled the rig straight again. Then I hit the brakes lightly thinking I could slow it down faster than coasting. Got rear-ended a second time and again a near jackknife. At that point I realized using the brakes was not possible. I coasted to a stop as the trailer kept jerking around and banging into the tailgate of the Taurus. When I came to a stop, the ambulance that happened to be following me stopped to see if everyone was alright. They helped me put the trailer back on the hitch and I towed the boat about 10 more miles to my destination. Bottom line is Do Not Touch the Brakes! (but you will). The Taurus did have minor tailgate damage from the winch post hitting, but the chains took the brunt of the force. I was traveling about 55 MPH when this happened.
The other times were less eventful.
I lost a small utility trailer at about 30 MPH. One of my co-workers hooked it up and forgot to put the pin in the coupler. The only damage was the tongue jack was destroyed.
I lost a 5000# equipment trailer because I forgot to latch the coupler. No damage, just embarrasing. This was at 20 MPH.
I lost a 15000# dump trailer with an excavator. Luckily, this happened while exiting a gas station at the curb hump. I think in this case the tongue bottomed out and the ball popped off. I immediately tightened the coupler ball nut. Again, I think wear caused the ball to be loose.
So each time the trailer fell to the ground and slid under the tow vehicle as I stopped. I had surge brakes which don't apply with a switch in all but the dump trailer. I think the chains held the dump trailer short of pulling the brake switch.
On my Airstream, I loop the emergency brake cable around the chain connection on the hitch and back to the lock on the coupler. If my Airstream ever comes off, the brakes will apply while the chains stay connected. I believe you want the brakes to apply while the chains are connected. I do not believe the chains will break. They never broke in any of my experiences. So I want the brakes to engage while the chains are dragging the trailer.
Hopefully my experiences will help anyone who gets into an unfortunate situation where the trailer comes loose from the ball.
2017 Flying Cloud 25FB (Miles) 184 nights 26,850 miles
400W Solar, Blue Ox SwayPro, 16" Michelins
2017 Nissan Titan XD 5.0 Cummins Diesel 4x4
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 04-30-2017, 01:51 PM   #11
2012 30' International
Livingston , Texas
My F250 dash display tells me that my trailer disconnects all the time while driving (much info on forums). I just keep going and sooner or later it will reconnect itself.
glenrms is offline   Reply With Quote
Old 04-30-2017, 03:10 PM   #12
1996 25' Excella
Tillsonburg , Ontario
Seems to me that the chains should take up the first loss on decoupling. If the breakaway switch activates it will put full ( possible locked-up) brakes on and you will need to drag the trailer locked wheels and all off the road across how many lanes of traffic???? That i one reason the umbilical needs to be sufficiently long to remain intact if the trailer drops onto the (CROSSED) chains. You get to apply trailer brakes lightly to keep the rig in a straight line. The breakaway switch is to lock up the wheels in case of a complete loss of the trailer. I have seen utility trailers travel nearly a 1000 feet down the road once disconnected. One actually dug the tongue into the ground and did a somersault after traveling what seemed like an eternity.
JCW
JCWDCW is offline   Reply With Quote
Old 04-30-2017, 06:34 PM   #13
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I have my breakaway cable set long enough that it will not activate unless the trailer becomes completely detached from the vehicle.
This arrangement is in agreement with the directions of: The RVDA-RVIA Service Technician Certification Program
"Since the pin must be pulled to activate the brakes, the cable from the breakaway switch pin to the tow vehicle should be longer than the safety chains. This arrangement will ensure the cable is the last connection to be broken upon separation of the trailer and the tow vehicle. If the pinís cable was shorter than the safety chains, separation of the trailer and tow vehicle will activate the brakes while the tow vehicle and trailer were still connected by the safety chains. The braking action will add additional force to the safety chains and likely cause the safety chains to break."
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 05-01-2017, 06:40 AM   #14
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
Similar to AirMiles, we had a total disconnect because of a major pavement buckle, thankfully at low speed on an entrance ramp. The immediate reaction is to brake, we did, and the AS slid into the rear of the TV. Chains and emergency brake worked as designed, but did not keep the tongue jack from jamming into the pavement....had to be replaced. Were this to happen at travel speed, I would focus on control of the TV and brake lightly. It is a scary occurrence.
banderabob is offline   Reply With Quote
Clipper, Emergency Exit, Land Yacht, Emergency Ladder masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 9 03-05-2015 10:34 PM
emergency brakes PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 8 08-06-2012 06:02 AM
3 musings (refrig, brake controller, emergency supplies) casarodante Our Community 2 04-02-2003 11:23 AM
newbie doing restore hairstream Buyer Guidelines 11 12-21-2002 05:39 AM
1978 AS Sovereign and doing my own repairs JLD Our Community 2 09-05-2002 11:28 AM
