Old 12-02-2011, 09:10 AM   #1
1961 24' Tradewind
Bemidji , Minnesota
Electric tongue Jack
Anybody know how to grease or lubricate electric tongue jack? When I take the cover off, everything looks pretty well sealed up.
vroom is offline   Reply With Quote
Old 12-02-2011, 09:51 AM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
If memory serves me the only thing to lube would be a nylon gear that you will see after you p0ull the motor up. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 12-02-2011, 11:25 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You should also lubricate the elevating screw. I am not quite sure how to get at that.
dwightdi is offline   Reply With Quote
Old 12-02-2011, 11:45 AM   #4
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
The owners manual specifies Lubriplate or equivalent for the gears. Remove 4 screws and wiggle the cover off to access them. You will likely find most of the grease has traveled from the gears to the inside of the cover. So far, I've just moved it back into the teeth. When reinstalling the cover be sure the wires to the switch and light are positioned so the won't get pinched or caught up in the gears. The coupling between the head and the leadscrew needs a dab of high temp grease like you would use for wheel bearings. To get to the coupling, loosen but do not lose the 2 Allen screws that secure the head to the post then lift the head off. This is also where you would connect your hand crank if needed. If you don't rotate the leadscrew you can reinstall the head without having to sync the limit switches. There is no lubrication specified for the leadscrew and the manual specifically says not to pour oil into the tube.
AIR 47751
Silver Goose is offline   Reply With Quote
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Electric Jack Not Working eberrobw Jacks, Stabilizers, Lifting and Leveling 13 03-13-2012 11:23 PM
Vintage Tongue Jack - Reese IndyAnne Jacks, Stabilizers, Lifting and Leveling 11 10-19-2011 01:32 PM
what kind of electric jack is this? Becky B. Jacks, Stabilizers, Lifting and Leveling 11 04-13-2011 04:06 PM
Need Tongue Jack - Suggestions? kj78133 Jacks, Stabilizers, Lifting and Leveling 16 02-23-2011 05:55 PM
