Old 07-19-2015, 12:34 PM   #1
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Eaz Lift Performance
I have replaced my Hensley with an Eaz Lift and after my first couple of trips have noticed no performance changes. I tow a 30' Signature with a Jeep GC Diesel. There is a little more weight transfer to the vehicle and the Airstream was a bit lighter, but then it was only loaded for a weekend visit to the lake. I now have 1000 lb spring bars in lieu of the 1400 lb bars that were with the Hensley. I think the Airstream rides a bit smoother. The biggest change was in the hook up procedure which now seems really complicated due to the addition of a couple of sway bars and the endless insertion of pins to the whole contraption plus the sway bar tightening levers. I already miss the simplicity of hooking up the Hensley. The weight of the Hensley stinger and the Eaz Lift hitch head is about the same so the physical part of getting ready to hook up is equal. My electric drill provided the effort for the Hensley jacks where I now work the chain levers with a bar. I really beat up the Hensley and I think the Eaz Lift may be tougher. Time will tell. Jim
Jim Flower is offline   Reply With Quote
Old 07-19-2015, 12:56 PM   #2
Gainesville , Florida
Have had no problems with my eazlift. Prefer it to blue ox or equalizer, have owned both.
avionstream is offline   Reply With Quote
Old 07-20-2015, 08:58 AM   #3
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Thanks for the feedback. I will get better at the hookup procedure with practice. Jim
Old 07-20-2015, 09:18 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Jim, is this their new model with the bars above the frame?
MICHAEL
Old 07-20-2015, 02:41 PM   #5
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
No, it is not. Just the regular old one with two Husky friction sway bars. I was very pleased with it's performance. Jim. Click image for larger version
Name:	ImageUploadedByAirstream Forums1437421237.084959.jpg
Old 07-20-2015, 03:24 PM   #6
2010 25' FB Flying Cloud
Fall City , Washington
Eat lift
Ive got over 30,000 mi and 5 years on my eaz lift and it works great. 25' FC so only one sway bar.
NWGreyhound is offline   Reply With Quote
Old 07-20-2015, 03:30 PM   #7
AWCHIEF's Avatar
Images: 33
I was hoping it was the new design. Waiting to hear how they are performing.
MICHAEL
Old 07-20-2015, 04:43 PM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I had the standard ole round taper bar EazLift before my Equal-i-zer.
Absolutely no complaints.
Easy installation, setup, user-friendly, and performs wonderfully for weight distribution and sway control.
Very effective, moderately low-priced hitch.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-20-2015, 05:48 PM   #9
2007 25' Classic
Hutto , Texas
I inherited an ezlift hitch with 1000 lb bars from my dad 25 years ago. Have towed 3 different 25 ft trailers over 100k miles and have hitched and unhitched over 600 times. The hitch still works great.
Wanderer2604 is offline   Reply With Quote
Old 07-20-2015, 08:06 PM   #10
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
After I took the photo, I replaced the stinger with one that had additional drop in order to get the Airstream perfectly level. It was off by half an inch. Since the Jeep has a self levelling air suspension, it achieves the same attitude regardless of load. The best achievable weight distribution on the axels is determined at the scales by adjusting the links as required which I have now done. Jim
Old 07-26-2015, 06:58 PM   #11
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Another trip, more questions. Where does one store the WD bars and hitch head when storing the Airstream! I am tempted to leave it all attached to the Airstream like the Hensley so I can avoid having to lug it all around and get myself and everything else I come near all covered with grease. I could just add some chain and lock it to the coupler lock that would also be securing the hitch head and shank. What do others do? So far I have placed all the stuff inside the Airstream but this creates more cleanup issues before departure than I like. Jim
Old 07-26-2015, 08:25 PM   #12
m.hony's Avatar
2013 30' Classic
I used to store my weight bars in the outside storage compartment under the bed.
TAC #MS-10
Airforums #70955
Old 07-26-2015, 08:32 PM   #13
2007 25' Classic
Hutto , Texas
I pull the head from the TV and then put it back in the hitch. Put a padlock on the hitch. Put a locking hitch pin in the head shank. This is a little more secure than a bare hitch but not by much.
I built a wooden case for the bars, tool, grease, etc. It is slightly bigger than the two nested bars. I put a 3/4" wooden skid on the hinged spine to slide it under the trailer behind the rear axle.
An old garage door handle makes it like a clunky violin case. Before you put the handle on, put the bars in and roll the case along a large dowel or pipe until it balances. Put the handle at the balance point, which is not the center.
The mess is contained.
I always put the curbside bar in the case first and take it out first, swapping left and right with each hookup to even out any wear. I know. I know. I'm ocd.
Old 07-26-2015, 09:47 PM   #14
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Storage...
For the head and shank: I normally carry a portable propane grill. It lives in a large plastic bin. I carry a second bin of the same size. The two nest together so the second one doesn't take up any space. When I want to remove the head and leave it at the camp site, I put the second bin on the ground where I want it, drop the head in, and put a lid on the bin to keep the head clean and dry. The bin is not sturdy enough to carry when the heavy head is in it. I don't do anything to lock it up.
For the bars: I made an open top box from a piece of plywood and some 2x4s. The box is about a foot square, with an opening in one side. I keep the box in my large outside compartment. I lay the bars in the compartment with the curved greasy ends in the box. I have a lid that covers the box so nothing else gets greasy.
The box is lined with some semi-rigid plastic material I had around the house. This makes it easy to wipe the box interior clean, which I do once in a while.
SSquared is offline   Reply With Quote
eaz-lift dcribbins Towing, Tow Vehicles & Hitches 2 04-15-2012 01:01 PM
EAZ-Lift WD Hitch washers, need some rbs Hitches, Couplers & Balls 2 12-14-2011 03:56 PM
eaz-lift hitch, is it all here or not? G1obetrotter Hitches, Couplers & Balls 8 07-01-2010 08:18 AM
Dear new owner of my EAZ Lift weight distribution hitch pageclot Hitches, Couplers & Balls 4 05-11-2010 09:17 AM
Eaz lift ardenrj Hitches, Couplers & Balls 2 12-30-2004 08:03 AM
