Old 07-29-2015, 09:11 AM   #1
Gordon
2014 30' International
Scarborough , Ontario
Eaz Lift Elite Round Bar Alert
Make sure you hear a click when inserting the bar into the hitch!
My bar fell out yesterday and dragged along the road for some time - I suspect I'll have to buy a new one as it has considerable wear!
The problem was that the blind rivet had failed. This rivet keeps the spring taut that keeps the locking pin protruding into the tube that the bar inserts into. As a result no locking pin in place, no click when inserting the bar and once the stress is released by a tight maneuver or backing up, the weight distribution bar will fall out, and you may not hear it.
A new blind rivet costs nothing and is easy to replace, so maybe keep a spare or two.
But most importantly, listen for the click!
Gmoore is offline   Reply With Quote
Old 07-29-2015, 09:32 AM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I'd be tempted to see if I could find a stainless steel rivet for that.....
Older Eaz Lift- spring bar popped out when backing DJW Hitches, Couplers & Balls 1 05-28-2013 11:00 PM
Right amount of spring bar bend for eaz-lift hitch DJW Hitches, Couplers & Balls 4 05-18-2013 10:17 AM
eaz-lift hitch, is it all here or not? G1obetrotter Hitches, Couplers & Balls 8 07-01-2010 07:18 AM
Dear new owner of my EAZ Lift weight distribution hitch pageclot Hitches, Couplers & Balls 4 05-11-2010 08:17 AM
Eaz lift ardenrj Hitches, Couplers & Balls 2 12-30-2004 07:03 AM
