Old 03-27-2006, 04:24 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Easy question: ball size
What's the ball size need for a 1979 31' Landyacht?
wacnstac is offline   Reply With Quote
Old 03-27-2006, 04:31 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
2 5/16"
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-27-2006, 04:31 PM   #3
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Never had one, but...
I'd say 2 5/16 ball, but I've never had one to say for sure.... Good luck!
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 03-27-2006, 04:32 PM   #4
robandzoe's Avatar
Plymouth , New York
Posted at same time
Great minds think alike!
Plymouth, NY 13832
Courtesy parking
Old 03-27-2006, 04:35 PM   #5
Images: 43
Couldn't find it spec'd anywhere. Need to tow next Sunday. I thought it was 2 3/8......
Old 03-27-2006, 04:42 PM   #6
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Just towed my 25' home night form storage.... 2 5/16 will be a perfect fit!
www.balrgn.com
Old 03-27-2006, 05:14 PM   #7
Images: 43
Along the same line of questioning, what do you guys use to lock the tongue down? Can a small padlock be used or do you just use some sort of cotter pin?
Old 03-27-2006, 05:44 PM   #8
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
You can use a hitch pin which local RV stores and even some auto parts stores carry. I use a padlock, just to slow down the casual thief.
Bill
Just my personal opinion
Old 03-27-2006, 06:40 PM   #9
Images: 43
I'd rather use a small padlock as well, just didn't know if it fit through there.
Old 03-27-2006, 06:47 PM   #10
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I believe that it is a 1/4" hole, so most padlocks should fit.
Bill
Old 03-27-2006, 06:53 PM   #11
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
I use a extended shank Padlock. Feel better bout it, more secure....
www.balrgn.com
Old 03-27-2006, 07:19 PM   #12
65glbtrotter's Avatar
1965 20' Globetrotter
Yakima , Washington
Images: 31
I too use a small padlock just for a little piece of mind.
Cory Harrington
http://65airstream.tripod.com/
Alumineyezed
AIR 7834 WBCCI 2105/VAC
65glbtrotter is offline   Reply With Quote
Old 03-27-2006, 07:28 PM   #13
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I have a latch lock, from Master. The way it is built, there is virtually no lock shaft exposed to be cut, so a would-be thief would have to have a Modo-sized set of bolt cutters to remove it. It keeps the latch locked while towing, too.
awning polycord size sovereign Awnings 5 04-23-2012 11:38 AM
Ball Size on '70 Caravel? MattyBoy Hitches, Couplers & Balls 3 01-06-2003 08:03 PM
tow ball size iguana Hitches, Couplers & Balls 2 10-03-2002 11:39 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Old CB ball mount davidz71 Phone, CB & Ham Radio 2 05-28-2002 06:54 PM
