Old 07-23-2010, 07:23 PM   #1
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Drop hitch me thru the goal posts of life
The floor - to top of ball measurement on my F250 is 24 1/2 inches. If I assume (havent measured yet) my AS coupler is at 18.75 inches, I will need to drop my hitch head about 6" to get near level. I have a reese 800/10,000 WD hitch for my AS with a solid hitch head. What MFR of drop shank hitch will work with the set up pictured here?
Tim
tvanwave is offline   Reply With Quote
Old 07-23-2010, 07:32 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
I'd avoid doing anything until you try it out... the 'stream may well be higher, and the truck hitch will certainly drop significantly once the tongue weight comes to bear.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 07-23-2010, 08:05 PM   #3
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Question
- Bart
New to all of this -- what I understand is the TV & TT ball/ coupler height should be as close to the same as possible before hookup. The WD hitch will level the truck load front and rear after hook up. Adjusting the ball angle should fine tune the TT leveling. OR am I getting this wrong? The ball dropped 3" w/o the WD hooked up. The F250 is the super duty version w/ tow pacakge and extra leaf spring.
Old 07-23-2010, 08:53 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
You've got two objectives. [love the title of your thread! ]
First and without exception -- get it so that your Airstream is fairly level during the final tow setup with WD bars engaged. Keep that in mind throughout.
The theoretical second objective may not be perfectly achievable. Before hooking up measure the height off the ground of your truck's wheel well surround, front and back. Any spot will do. I measure to the trim at the top of the sheet metal over the wheel cutouts. In a perfect world, after hitching & engaging the WD bars, the front and back index points should settle the same amounts. You & I have a 3/4 ton -- we're not on such a fine breaking point. For maneuverability's sake, it's good to get some of the hitch weight transferred forward to the front wheels. I've fiddled with measuring these heights and it's virtually impossible for me to overdo the WD bars so that the front settles more than the rear.
Think further -- overhitching and torquing so darn hard that you accomplish equal settling of the front & back index points will cause a very rough ride for your Airstream. Hmm... you've got a 34'er. Anybody use as little as 800# bars for a 34? How many use 1000# bars?? Giving your Airstream a softer ride will help it in the end. You've got a fairly generous rear axle weight rating. I'd accept a bit less transfer-forward with your WD setup. On very flat ground, then just how level does your trailer look with WD bars engaged? Figure how much bar drop you need from that if it's still nose high.
At least that's how I'd approach it. Your results may vary...
5 meter Langford Nahanni
Old 07-23-2010, 09:04 PM   #5
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
OK - I'll try the WD set up again and send a few pictures and measures to help ensure I understand what I am doing. The F250 is a 4x4 so the front is fairly heavily sprung. Does the set up site have to be exaclty level or more imporatant that the TV & TT are on the same plane? My drive is paved but has a very slight slope. Thanks for the help!
Old 07-23-2010, 09:38 PM   #6
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
- Bart
Thanks for the advice - I will try again. I had trouble with 9th grade algebra - is there a relationship to WD hitch installation?
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
Old 07-24-2010, 10:33 AM   #7
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Measurements TV to top of fender wells unloaded front- 39.25; rear- 40.75 inches; to top of ball: 24.25 inches; TV loaded to fender wells front- 39.5; rear 38.5
Measurement to top-inside of AS coupler - 17inches w/full water tank and 1/2 full waste tanks
As photo shows below. The AS hitch is at 17" and the TV at 24.75 so the pre loaded differnece is 7.75 inches. With the weight on the ball the difference is lessned by 2.25 inches (40.75 minus 38.5) SO I need to drop the hitch head by 5.50 inches - right?? (7.75 minus 2.25)
Tim
Air Cid
Reese WD Hitch
Old 07-24-2010, 01:24 PM   #8
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Tim
Moved the hitch head as far down the drop shank as possible and tilted the ball forward as far as possible. Now top of hitch ball is 21.75 (three inches lower than earlier). SO, if the AS weight drops the hitch by 2.25" then the coupled height becomes 19.5". This is still 2.5" higher than the AS coupler height of 17" at level. IS the drop on the hitch shank I have already the max? The measurment from the top hole in shank to bottom hole is 6.5" so I'm guessing this equates to a 5-3/4 drop shank?
ID:	107371   Click image for larger version
Air Cid
Reese WD Hitch
Old 07-24-2010, 02:15 PM   #9
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
Two choices. Go with the lowest practical settings on the drop hitch head and call it good. Or, bite the bullet and buy a different hitch head with a greater range of motion. Reese (the hitch manufacturer) makes a head with a greater range of motion, but it may not be what you need. I strongly suggest a call to Reese's engineers for guidance in this matter,
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 07-24-2010, 03:30 PM   #10
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
I have viewed the reese long-drop hitch on their website 'Reese Weight Distributing Shank, Extra Long Drop, 15,000 lbs no. 63971' but cannot tell if it provides extra drop or not compared to what I have. My tow vehicle is a plain old F250 4x4 w/o any lift kits etc and wonder what others have done with a similar tow vehicle. I'm glad to buy the right parts if I know what will work.
becoming unhitched in TN
Air Cid
Reese WD Hitch
Old 07-24-2010, 03:45 PM   #11
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
I would mount the trailer, drive for a little while, then pull up at your supermarket of preference and go inside and do some shopping for 90 minutes or so, while the suspension settles.
Then I would take fresh measurements. Given you have a 34 footer, if you measure the ground clearance at the front and back of the body of the trailer, and you see a difference of around two inches or less, I think you're golden.
This is a personal opinion.
TX-16
Dave Park is offline   Reply With Quote
Old 07-24-2010, 05:10 PM   #12
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Defintion: drop - the distance from the top of the shank to the top of the ball platform. If this is an accurate defintion of drop, then would the drop shank I have (pictured here) be providing about 2" of drop? SO, if I bought a 5-3/4 drop shank then I will gain almost 4 more inches of drop ?
Air Cid
Reese WD Hitch
Old 07-24-2010, 05:25 PM   #13
_
a 2 INCH difference front/2/back may be golden...
but it is significantly UNLEVEL and will result in UNeven loading of the tires and brakes...
and the axles which may have already settled significantly in 20 years.
looking at the profile of a 34 a 2 inch variance is obvious and too much.
_________
LONGER drop shanks (10 inches +) are widely available...
aluminum, steel, adjustable and custom fabrications.
MOST are rated to 10,000 lbs, (some made from 2.5 stock are much stronger)
while the STRONGER ones are often limited by the ball dimensions used or the tv's receiver.
SEARCH in gooogooo land and at some of the E RE tailers with detailed websites.
it's impossible to predict how much the truck will sink once connected and exactly what shaft drop is needed.
using whatever is available (even a straight bar) to hook up will provide a reasonable approximation of truck squat.
even after getting APPROXIMATELY the correct drop, only a trip to the scales can confirm proper w/d bar tensioning...
__________
my understanding is the RECeiver height is measured INSIDE the box but regardless it looks like the need is 5-7 inches.
cheers
2air'
Old 07-24-2010, 05:56 PM   #14
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
I like the reese extra drop pictuted here. Provides 5.75 inches of drop... but if I need more thene not so good. Is your recommendation to look for a 7" drop and if i need less - OK? I'm worried about some fabricated hitches not having the real rating that they advertise. Thanks for the comments.
Air Cid
Reese WD Hitch
We've finally reached our goal !!! RognChris Member Introductions 10 11-02-2009 12:23 PM
Hitch ball height drop down - dodge ram HD Ag&Au Hitches, Couplers & Balls 2 08-06-2009 03:57 PM
Deep drop WD hitch shank ground clearance? mountainboy Hitches, Couplers & Balls 5 07-20-2009 04:56 AM
Jack Drop WestMichCamp Jacks, Stabilizers, Lifting and Leveling 6 08-26-2007 09:33 PM
Hitch bar drop size for 3/4 ton trucks Silvertwinkie Hitches, Couplers & Balls 20 09-22-2004 01:37 PM
