Old 03-17-2010, 01:56 PM   #1
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Does hitch add tongue weight
Am at my limit for tongue weight on my 06 Tundra, but want to install a ProPride hitch.
Does the hitch add tongue weight, when determining the trailer tongue weight, or does the hitch add to the payload of the truck?
This has been referenced here before like everything else, but I can't find the answer.
Old 03-17-2010, 02:25 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Realistically, it adds to the tongue weight, because it adds to the stress on the hitch components.
You can get a Valley hitch that will support a tongue weight of 1000 pounds. They're cheap and easy to install.
Trailer Hitch Instructions For DrawTite, Reese, Hidden Hitch & More - etrailer.com
Old 03-17-2010, 02:33 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Any non-OEM equipment on your truck subtracts from its payload. Specs for a vehicle originally sold without a Class III/IV receiver must have the weight of the receiver added to loading on the vehicle. The hitch bar and ball are added load. The WD/antisway gear on the A-frame almost all is carried at the hitch. Ditto LP in the tanks. So either way, these loads do translate into extra weight on the TV.
I've done the figuring tow loads by brute numbers. This can get all of us into using a lot of rigid suspension 3/4 ton trucks. There are proponents for tuning your rig and reviewing the safe history of large family cars towing RVs back in our parents' days. Looking for answers won't be a short quest. You could start looking for posts by Andrew T or bryanl (related links: 1 & 2) in any hitch subforum thread. I remember lewster commenting on all the family-car-towed RVs he witnessed arriving safely in FL with Canadian plates.
5 meter Langford Nahanni
Old 03-17-2010, 03:23 PM   #4
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Why would you want a ProPride hitch for a 20' Safari - got a lot of money you want to waste? This is gross overkill for that size trailer. Get a Reese Dual Cam Anti-sway hitch with 600 lb bars - or ,maybe even 400 if they make'em. All you will need.
Al - K4GLU is offline   Reply With Quote
Old 03-17-2010, 03:48 PM   #5
dkottum's Avatar
Well that's it in a nutshell, if it all comes to numbers Bob (Go Twins!).
There is an interesting article in the Spring "Airstream Life" by Can-Am's Andy Thomson about the role of t.v. height, suspension, wheels and tires, t.v. overhang and receiver length, as well as some guidance on w.d. bars. Makes quite a case for his smaller vehicle rigs.
But we have got the Tundra, plenty of payload, at tongue load limit, and we like it. Can we use the ProPride without modification?
Old 03-17-2010, 03:58 PM   #6
dkottum's Avatar
Hi Al - '
It's because I just talked to the guy who left here in Tucson last year with his 30' Airstream, Reese dual cam, and 3/4 ton diesel Ford and very strong side wind started sway he could not correct. It all rolled three times.
It's the extreme condition that we may get into.
Old 03-17-2010, 04:25 PM   #7
Images: 59
Don't consider the weight of the Propride as part of the tongue weight. The tongue weight doesn't include anything foward of the ball.
Tongue weight is a number that represents where the center of trailer mass is located. Location of the center of mass is what determines the speed at which trailer oscillation will become uncontrollable. So don't adjust your trailer tongue weight to compensate for the weight of the hitch.
The weight of the hitch gets assigned 100% to the tow vehicle payload, like Bob says.
Old 03-17-2010, 04:59 PM   #8
That's the Andrew T cited in my post.
Go Gophers! <trash talk deleted by mod staff> Xavier!!
Old 03-17-2010, 05:13 PM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I understand the fact that the hitch would be considered part of the payload, not tongue weight, but it is the total weight of the tongue and the hitch resting on the tow vehicle's receiver. I think this factor could over load the capacity of the receiver. My receiver weight limits are not the same as my tow vehicle's tow rateing. I also believe that a Ha Ha or P P would put me over my receiver's limits.
Trailer tow rating.............8,900 lbs
On receiver label:
Max gross trailer weight.________________________ Max tongue weight.
Weight distributing...........8,850 lbs_________________________885 lbs
Weight carrying...............5,000 lbs_________________________500 lbs
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-17-2010, 05:27 PM   #10
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
I have a few questions, if you don't mind.
May I ask how you know it is overkill? And, what exactly is OVERkill? Isn't something, trailer sway in this case, just KILLED? How can it be more than killed? Ever towed a ProPride equipped trailer?
A Reese Dual-Cam, as noted in the post above, IS an example of UNDERkill.
Yes, my tonality is sarcastic here.
I take offense to people that don't know what they are talking about stating that I spend my life manufacturing and selling a product to people that don't need it. That is the message you send when you come off with your ignorant, arrogant statement, "got a lot of money you want to waste?"
If that isn't your intention then I'd like to suggest you check your premises.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 03-17-2010, 05:42 PM   #11
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Hi Al - '
So you're making some significant assumptions... foremost that a different hitch would have changed the outcome; then that the driver was competent; that the Reese was set up properly; that the trailer was loaded properly; and that all the OTHER equipment (tires, shocks, axles etc.) were performing properly.
All trailers will exhibit sway at speed. The key is to make the speed at which onset occurs higher than you'll ever drive. The extreme conditions don't cause sway. An unbalanced weight distribution issue will, and if that occurs with some other extreme condition, it'll cause you to crash regardless of the hitch. If the trailer can exhibit enough sideways force on the rear axle of the tow vehicle you lose control.
All of the sway-control hitches on the market will do their job if set up properly, and I'm not convinced that the expensive hitches do anything but mask the other causes of sway. The Hensley and Pro Pride are excellent hitches and perform as advertised, but they cost four times that of the Dual Cam or Equal-i-zer; both of which have hundreds of thousands of successful tow miles without incident.
I had issues with my 34' tri-axle and my Excursion with a Reese Dual Cam. The tri-axle is reputed to be one of the most stable trailers on the road, yet I had a scary case of "the wiggles" when being passed by trucks with the Excursion. I attributed it to the hitch, hitch shank length... a whole variety of things, until I figured out it was the spring stack on the Excursion that was unstable, causing rear-axle steering. Once I took care of that AND set my Dual-Cam up properly, AND carried 80psi in the tires, it tracked like it was on rails.
I'm not trying to dissuade anyone from buying the hitch that catches their fancy; merely pointing out that the hitch is NOT a panacea for all towing ills. If you're having issues, you need to track them down one at a time and correct them, and THEN add sway control... not use the sway control to try to cover up for other towing issues. That's merely masking the problems until the problem becomes severe enough to overcome what the hitch is capable of masking... and then you're in trouble... probably exactly what happened to the guy you spoke with. There are literally thousands of Ford F250s out there successfully towing all sizes of trailers with a dual-cam. I'd be curious to find out exactly what he didn't know about his rig in particular.
Roger
Old 03-17-2010, 05:50 PM   #12
_
the "does it count against tongue..."
has been asked and answered.
and again in this thread.
but here's the real issue...
Am at my limit for tongue weight on my 06 Tundra...
u need to rethink this AND explain exactly what u mean...
since there is no "tongue weight" limit for a tundra or any other truck.
PAYLOAD limit...yes
RECEIVER limit...yes (with or without w/d since most have 2 ratings)
if it's the receiver that's maxed out move UP in class or get the weld'n sticks and melter thing out...
but tongue limit?
wazzzz dat?
cheers
2air'
Old 03-17-2010, 05:50 PM   #13
ProPride, Inc.
There are some significant assumptions here.
1. All sway control hitches will do their job if set up properly.
In all instances? A lane change at 70MPH? Cresting a hill at 65MPH with a side wind gust?
2. The Hensley and ProPride are equivalent to the Dual-Cam and the Equalizer.
Not even close. The only similarities are that they all connect the tow vehicle to the trailer.
3. The expensive hitches "mask" causes of sway.
If the "other causes of sway" DO NOT cause sway they are not "causes of sway" when "masked." That's just logic.
ProPride Hitch
Grand Blanc, MI
Tu ne cede malis
Old 03-17-2010, 06:01 PM   #14
Salem , Oregon
Images: 18
Originally Posted by ROBERTSUNRUS View Post
On receiver label:
Originally Posted by 2airishuman View Post
PAYLOAD limit...yes
but tongue limit?
wazzzz dat?
cheers
2air'
Hi, somewhere you lost me; This is exactly what my receiver label states. Two ratings for trailer weight and two ratings for tongue weight. Wouldn't you consider this the same as tongue limit?
2005 Safari 25-B
Too much tongue weight? TCM1 Tow Vehicles 22 08-14-2009 09:11 PM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Hitch tongue weight capacity of 1990 250 Lotatin Hitches, Couplers & Balls 0 04-16-2008 03:31 PM
Tongue weight ? LI Pets Hitches, Couplers & Balls 5 01-06-2008 08:26 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
