Old 04-08-2014, 06:56 AM   #1
Mountain Home , Arkansas
Do You need one?
If your tow vehicle has a 9000# tow weight, do you need a Weight distributing hitch for a 3500# trailer?
Flyflicker is offline   Reply With Quote
Old 04-08-2014, 07:01 AM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
You may not. You probably only have 350# tongue weight.
Does the tow vehicle squat in the back when the trailer is hitched?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-08-2014, 07:14 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
A WD hitch also provides additional attachment points in addition to the ball and safety chains which is a safety factor, Depending on the hitch it also adds sway control.
Old 04-08-2014, 08:34 AM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Probably, but there's more to setting up a well performing truck/trailer combination than those numbers. Best not to approach it with "What can I get by with". Better to look for a good combination of truck/hitch/trailer.
Doug and Cheryl
Old 04-08-2014, 09:35 AM   #5
m.hony's Avatar
2013 30' Classic
Some weight distributing hitches provide additional attachment points. The Equal-i-zer doesn't.
If the trailer were to be separated from the tow vehicle, the weight bars would just slide right out of the saddles.
We never use weight distributing hitches on 7,000# GVW car trailers, cargo trailers, and utility trailers, but we do use weight distributing hitches on 14,000# cargo trailers.
It is about front axle weight. On car trailers, you can move the car forward or back to get the balance right. On cargo trailers you can load it with the weight from the front to the axles. With 1,000# or more tongue weight the rear of the tow vehicle squats down and the front is in the air- less steering control and headlights blinding other drivers. The idea is to transfer weight to the front axle and trailer axles leveling the entire combination and bringing back steering and braking control and safety.
With 350# tongue weight these situations will never come into play.
TAC #MS-10
Airforums #70955
Old 04-08-2014, 09:52 AM   #6
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Properly set up, a weight distribution system can only improve your towing experience regardless of the TV/Trailer combination. Add some sway control or elimination as cheap insurance and you're all set to go.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
https://sites.google.com/view/towedhaul/home
MrUKToad is offline   Reply With Quote
Old 04-08-2014, 10:27 AM   #7
m.hony's Avatar
2013 30' Classic
A 3,500# GVW trailer is like a 4-wheeler or golf cart trailer- single axle, 2 tires.
I have never used a weight distributing hitch or sway control on a trailer that small and never had any trouble.
No strain on the tow vehicle's suspension. No tongue weight to speak of. A small 4 cylinder tow vehicle will do it.
Your 9,000# towing capacity indicates the tow vehicle should handle a 900# tongue weight. Your trailer should have a 350# tongue weight or 1/3 of what the vehicle is capable of. There probably is no rear squat and no misalignment of the headlights and no loss of steering control or braking with a trailer that light.
I would think sway control could be an issue, at least more important or higher priority with a trailer that small.
Sway control will buy you more peace of mind than weight distribution with a rig that small.
TAC #MS-10
Airforums #70955
Thank you! Thank you! Thank you! littlebird Winter Living 0 03-18-2014 07:48 AM
Do you need a cold one? Bigventure Off Topic Forum 5 10-09-2012 05:37 PM
You Might Find One You Recognize Al - K4GLU Off Topic Forum 5 04-02-2009 09:14 AM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
One down, one to go.... Pick Axles 3 01-13-2003 10:31 AM
