Old 02-03-2010, 09:34 PM   #1
gsmithii's Avatar
2013 30' Flying Cloud
Virginia Beach , Virginia
Do we have a problem with tow vehicle or hitch?
Hello All,
As compete newcomers to Airstream and to towing we are really enjoying ourselves even though we were camping in winter last month. We have quickly put a little over five hundred towing miles on our '06 Safari 25ss and now we see an interesting development. The upper door hinge pin was protruding about a half inch at our last fuel stop and today the hinge pin showed evidence of working after only six miles under tow.
In other threads on the hinge pin subject we read posts suggesting an over-rated tow vehicle with over-stiff springs and shocks or other possibilities. Here's what we are using today - tow vehicle is a Chevy 2500HD diesel/crew cab w/long bed. Our hitch is an Equal-i-zer with 1000# spring arms. Is the tow vehicle a good match? Could the hitch be over-rated for this trailer? What else should I look at? and in what order?
In every other way our pre-owned trailer seems to have been gently used. We have been treating these initial trips as a thorough shakedown and a great time for a tune-up. Would all with experience in this area have suggestions on a logical approach to sort this through?
Skip
Speed is Life . . . guidance is optional . . .
The Traveling Circus: 2013 Flying Cloud 30A; 2006 Chevy Duramax Crew/LWB
Air #42313 TAC VA-7 WBCCI #1290
gsmithii is offline   Reply With Quote
Old 02-03-2010, 10:44 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
We use 750# bars with our 31' trailer and 2500 Silverado and Suburban. I'll beat somebody else to the punch, and tell you to have the wheel balance checked as well, all the little vibrations together can move things around.
Old 02-04-2010, 05:31 AM   #3
2008 28' Safari SE
winter garden , Florida
can't just change bars on an equalizer, they are different sizes I believe. I would suspect the hinge and not the tow vehicle as I tow my 28' with a 3/4 ton 4x4 and have not had a single problem with rough ride or vibrating anything loose. As a matter of fact I have towed over some pretty bumpy roads and things I have left on the table were still there when I got home. With that said i am sure others will disagree.
bob34787 is offline   Reply With Quote
Old 02-04-2010, 05:46 AM   #4
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Yes, you've got spring arms that are too stiff. You should have bars that are in the 500 lb range with that heavy a truck. You may have other issues as well, but I'd certainly start there and see what happens. Frankly with that 2500HD platform, you may not even need a WDH, but you still need sway control.
Roger
Old 02-04-2010, 05:54 AM   #5
SteveH's Avatar
Common Sense , Texas
I would agree with Roger. I think you have too heavy of bars on the hitch. Those are also non-tapered square bars also. They ride rougher.
I tow a 25' with a 3/4 ton GMC, but with a ProPride hitch. I like the combo, but the ProPride uses round bars.
Like mentioned above, you may have wheel/tire balancing issues too.
Regards,
Steve
Old 02-04-2010, 06:15 AM   #6
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
We have a 30' Safari Bunk and I use the Equal-i-zer with 1,000# bars and tow with an F-250 diesel. You don't have too much truck, but your bars are probably too much. I use the heavier bars because of the conditions I usually tow under. The Equal-i-zer is a great hitch and I am very pleased with it. Round bars vs. square bars for the same rating won't make any difference, IMHO.
I would recommend a set of Centramatics (SP?) to maintain balance on the wheels. That will be my next purchase when I replace my tires later this spring.
Family of Disney Fanatics
WBCCI# 4821
Old 02-04-2010, 06:37 AM   #7
gsmithii's Avatar
Thanks for the quick replies. I'll start with checking wheel balance first since my first project was to change the tires anyway. Three of the four are probably original equipment and I don't know how they were treated. They're the first to be bit of equipment to be changed. Centramatics? Will need to learn about that. Then, if necessary, on to the hitch.
Skip
Old 02-04-2010, 07:00 AM   #8
2006 30' Safari
Orlando , Florida
For quick reference, go to this page of the Centramatic's website. There are demos of how they work and how they are installed (demo is for semi, but I'm sure it is similar for trailers).
Centramatic
WBCCI# 4821
Old 02-04-2010, 07:15 AM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up accurate weights...
...you need accurate weights to determine proper hitch set-up, GCVW, tongue, vehicle axle and trailer axle, fully loaded ready for the road.
You have to know how much weight you are transfering to the steering axle.
For three seasons with the Classic I relied on the Cat and bathroom scale method of determining tongue weight, usually between 700 and 900lbs, got a tongue scale and found out that our tongue wt was actually 1175lbs. Our 1000lb bars on the haha are doing there job just fine on the 2500 Burb. Use Centramatics on the trailer, and inspect trlr wheels often for slung wheel weights, also a short ride in the trailer each Season to confirm ride quality.
Have used this on our door hinge pins with good results.
Make sure pins are clean and not binding, trailer is level and latch is lubed.
“Not enjoying the Network News Broadcasts ?…ask your Doctor." 🤪
RLC
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 02-04-2010, 07:18 AM   #10
Road Ruler's Avatar
Images: 38
After buying our 23 eight years ago we notice the front A frame was bent up slightly. We checked out the frame and found it to be solid (rust free).
The PO used a HD pick up and 750lbs bars.
We have been using the same 750 lb bars and towing with lighter weight tow vehicles.
The A frame deflection amount has not changed in all the years we have towed the trailer. (note over 300hrs of towing).
Compared with other box type trailers and 5th wheels Airstream"s are easy to tow.
Name:	A frame.JPG
Old 02-04-2010, 08:57 AM   #11
1999 25' Safari
Fairburn , Georgia
In addition to vibrations, just the action of opening and closing the door will make the pin work it's way out. My trailer has the same problem, not caused by towing.
JackMac is offline   Reply With Quote
Old 02-04-2010, 09:33 AM   #12
Originally Posted by gsmithii View Post
Hello All,
Drive the hinge pin back in place.
Drill a small hole into the hinge and thru the hinge pin.
Install the smallest drive pin, that you can find into the hole.
That should permanently keep the hinge pin in place.
Lower your hitch torsion bars down to 500 to 600 pounds and balancing the running gear and/or installing Centramatics, will offer considerable help against vibration and road shock.
Old 02-04-2010, 06:19 PM   #13
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Robert's right. Weigh your rig.
2005 25' Safari publishes 750lb tongue weight.
Loaded for travel, 950lbs wouldn't be unreasonable.
If that's the case 1000# bars are perfect.
Your TV is perfect.
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 02-04-2010, 07:47 PM   #14
gsmithii's Avatar
Boy! Oh, boy! What a wealth of useful information. We knew that we were embarking on a very technical activity when we decided to camp in a trailer. To summarize all the very helpful comments, here is the game plan. First, start with tire's, replacement ('cause they're OE) & balance, pressure, temp., etc. Then check hitch setup, etc., etc. Then (with thanks and apologies to Andy R) put a great big bloody nail through that dad-ratted (as my grandpa would have said) hinge.
Skip
New tow vehicle, now have a hitch question. dannyo Hitches, Couplers & Balls 8 05-29-2009 02:42 PM
Front hitch on tow vehicle????? popeyedoyle1 Hitches, Couplers & Balls 27 06-10-2007 06:39 PM
Tow vehicle electrical problem Boondocker Tow Vehicles 5 01-10-2007 08:26 AM
Tow Vehicle - AC Problem lebolewis Tow Vehicles 14 07-25-2006 11:27 AM
Tow Vehicle/Hitch Help Trav Hitches, Couplers & Balls 23 10-04-2005 09:42 PM
