Old 02-05-2010, 03:04 PM   #15
gsmithii's Avatar
2013 30' Flying Cloud
Virginia Beach , Virginia
Oh! & for Minnie's Mate - thanks for the reference to Centramatic. Just watched the video in your link & it sure makes sense.
Skip
Speed is Life . . . guidance is optional . . .
The Traveling Circus: 2013 Flying Cloud 30A; 2006 Chevy Duramax Crew/LWB
Air #42313 TAC VA-7 WBCCI #1290
gsmithii is offline   Reply With Quote
Old 02-05-2010, 03:34 PM   #16
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
We don't seem to have any problem that I have noticed with out 30'classic /2500HD combo using Hensley with 1000# bars - I asked Hensley about using lighter ones but they said I should stick with 1000#.
I just added a set of Centramatics - not to correct any particular problem but just because I was impressed with the theory & the demo, and felt they could only help.
As for hinge pins, we bought our trailer used, and I noticed that at the top of the hinge pins, someone has taken a centre punch and popped them around the circumference at 90 degree intervals. I don't imagine they came that way from AS, and the only thing I could think was that it was an effort to stop the pins from moving.
They don't move.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 02-05-2010, 05:37 PM   #17
They don't move.
Brian.
Brian.
Keep your eyes on those hinge pins.
Historically, once the pins have been center punched, in time, they will loosen again.
Best way to stop the issue, is insert a small pin, thru the hinge and pin.
Old 02-05-2010, 05:51 PM   #18
Brian.
Out of some 300 sets of Centramatics, not a single person expressed anything but praise, to us.
Old 02-05-2010, 07:26 PM   #19
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
They don't move.
Brian.
Ours had the center punch marks when we picked it up new, dealer said it was delivered that way....worked for awhile.
Fixed it when I re-finished the hinges.
Name:	DOOR HINGE CORROSION REPAIR 007.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-05-2010, 07:47 PM   #20
Bob.
Thanks for the voice of experience.
Unfortunately, all to many owners have the same problem, but won't install the pin.
Old 02-06-2010, 06:43 AM   #21
Wingeezer's Avatar
2005 30' Classic
Originally Posted by Inland RV Center, In View Post
Bob.
Andy - per your advice I will keep a close eye on the centre-punched pins and follow your suggestion if they show signs of moving.
Is the type of pin that you suggest what is also called a roll pin? ie it is formed by rolling a piece of metal into a round shape so that it has some springiness and holds tight in the drilled hole?
I guess you'd need to drill straight across the hinge / pin / and out the other side so you could also drive the pin out if need be?
What about instead, using some of the loctite product intended for holding bearing races securely in place top prevent the race from turning?
Might be an easier solution?
Brian - looking forward to our first long trip with the Centramatics, starting out next week!
2005 Classic 30'
Old 02-06-2010, 07:41 AM   #22
The pin indeed is a roll pin.
I don't think Loctite will work, but it's easy enough to give it a shot.
Time will tell.
Please make a post, down the road, as to the results.
Old 02-09-2010, 12:32 AM   #23
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
You are more than welcome. I plan on adding them to our Airstream with the next bearing packing later in the spring.
Family of Disney Fanatics
WBCCI# 4821
New tow vehicle, now have a hitch question. dannyo Hitches, Couplers & Balls 8 05-29-2009 01:42 PM
Front hitch on tow vehicle????? popeyedoyle1 Hitches, Couplers & Balls 27 06-10-2007 05:39 PM
Tow vehicle electrical problem Boondocker Tow Vehicles 5 01-10-2007 07:26 AM
Tow Vehicle - AC Problem lebolewis Tow Vehicles 14 07-25-2006 10:27 AM
Tow Vehicle/Hitch Help Trav Hitches, Couplers & Balls 23 10-04-2005 08:42 PM
