11-16-2009, 08:53 PM
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville
, Maryland
Do I need sway control with my rig?
I have a 2005 F-350 4x4 Diesel Dually with the FX4 (off-road) package and have purchased a AirSafe Class 6 hitch. Does anyone think that I need sway control with this? I will be pulling a 1998 34' Excella from Arizona to Maryland.
11-16-2009, 08:55 PM
Retired.
, At Large
In a word, Yes.
11-16-2009, 08:59 PM
2002 25' Safari
Dewey
Originally Posted by overlander63
In a word, Yes.
Ditto
Richard
11-16-2009, 09:00 PM
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
Yes times three.
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
11-16-2009, 09:08 PM
1994 21' Sovereign
Tucson
If you have to ask, the answer is yes, and if you don't use it you won't know until it's too late. I remember one time I forgot to put it on and had to swerve to avoid something on the interstate, almost lost it. Cheap insurance!
11-16-2009, 11:52 PM
Silver Mist
Riverhead
, New York
Why did you get that hitch?
the specs are way over kill, can you return it or did you use it?
I wonder if that will give you a stiff ride because it is about double your needs.
But with out WD or sway
11-16-2009, 11:59 PM
Salem
, Oregon
Hi, if your truck is thirty four feet long and weighs the same or more than your trailer, then you will be OK without sway control. Otherwise you shouldn't leave home without one.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
11-17-2009, 04:54 AM
1954 25' Cruiser
Kyle
, The Republic of Texas
You have a honking big truck, but you also have a huge trailer. Do you need sway control? In a word, yes. For the safety of your family, For the safety of others on the highways, and lastly - for the safety of your rig (your Airstream AND truck). Sway can & does "get away from you & far beyond your abilities to control it" very very fast and usually leads horrible wrecks & broken bodies in some cases. Yes, you do need sway control.
I love that old time rock & roll.
11-17-2009, 07:25 AM
1984 31' Airstream310
Ajo
I'm moving this thread upstream so victorialhq notices it.
11-17-2009, 08:24 AM
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison
, Michigan
YeS,yEs,yeS, YEs, no matter how you look at it!
11-17-2009, 12:16 PM
1993 34' Excella
Estancia
, New Mexico
2,500 lbs Tg Weight
20,000 lbs GTW
I have a AirSafe class 5 which will not give you a stiff ride for the trailer but considerably reduces it. That is why I got it and is what AirSafe hitches are designed to do. I use it in conjunction with a weight distributing hitch. The AirSafe and/or WD may have a minor affect on reducing sway but will not do much in a severe sway situation without additional sway control.
11-17-2009, 05:01 PM
1972 23' Safari
Houston
Sway Bars
Are like The American Express Card, don't leave home without it!
11-17-2009, 08:04 PM
Registered User
1995 36' Classic 36
Spencerville
, Maryland
I appreciate everyones input but could really use some guidance on particular brands/models that people have actually used with success! I know, no one can say what will work best for me or which one is the absolute best period.... but all of you out there trailering with a rig like mine can give me some "real guidance." I called REESE and the person on the other end of the phone said that I had to have a weight distribution system to be able to use their "dual cam" system....
I have purchased an AirSafe class 6 hitch with a double tabs for the balls for some sort of sway system but don't know if a weight distribution system will work with it. I'm not worried about cost - I am worried about safety! Again, I want a sway system of some sort but am not sure what will work for my rig and setup. Advice?
11-17-2009, 08:11 PM
Corona
All you needed from the beginning, was a Reese dual cam 750 load equalizing hitch.
When pulling an Airstream, a load equalizing hitch is about as mandantory, as a sky diver wearing a proper parachute.
Without it, simply put, you and all your passengers, as well as innocent people, could be severely injured or killed.
How do I know? I investigated over 1000 loss of control accidents, specifically involving only Airstream trailers.
The results of that has previously been posted many times.
11-17-2009, 08:14 PM
_
...I want a sway system of some sort but am not sure what will work for my rig and setup. Advice?
there are 3 or 4 ways to TRY to reduce the potential of sway.
1. friction OUTRIGGERS (those can be added to the airbag hitch) which are the LEAST desirable approach
2. w/d bars that incorporate FRICTION sway reduction (dual cams or '4 point' friction like the equalizer) these can ALSO be added to the airbag hitch.
3. an UNDER frame 5th wheel type hitch (the 'pullrite' design) which will NOT work with the air bag hitch...
4. a projection point/4 bar hitch (pp or haha) and THESE don't work with the airbag hitches.
_______________
really THAT IS IT.
IF you REALLY want ABSOLUTE sway control buy a pp/haha and DITCH the airbag contraption.
IF you want to use the air bag see choices #1 or #2....
______________
these posts keep asking for BETTER or more specific advice.
there ISN'T any.
u have 4 choices and ONLY 2 work with airbag hitch.
NOW you've got to decided if EITHER of the friction control add ons are ENOUGH sway control 4 you.
cheers
2air'
11-17-2009, 08:29 PM
_
...Without it, simply put, you and all your passengers, as well as innocent people, could be severely injured or killed.
in actuality the "results" have never been posted, only YOUR claim of results.
and suggesting that the lack of "load equalizing" will KILL people is irresponsible.
and really not accurate either, since LOAD EQUALIZING does not EQUAL sway control...
____________
and YOUR so called PROOF is based on THIS questionnaire...
http://www.airforums.com/forums/atta...9&d=1232471897
which after YEARS of claiming to have PROOF of accident causes was FINALLY posted here...
http://www.airforums.com/forums/f464...ire-47613.html
no disrespect intended, but...
not only are the questions USELESS
the answers to ANY of them proves NOTHING.
it's a (preliminary) survey type questionnaire, based on OWNER recall of several issues.
so the recall is subject to error, and THOSE survey questions don't lead to PROOFs...
the initial statistical analysis of the answers MIGHT help develop more PRECISE questions with VERIFIABLE answers...
and THAT process might lead to correlations or "suggestions" of issues to explore FURTHER...
but there is NO PROOF of anything in those questions.
and the ANSWERS to those questions have NEVER been posted or viewed PUBLICLY either.
in THIS case statistics IS statistics and
statistical analysis leading to PROOF needs more/better data AND questions.
cheers
2air'
11-17-2009, 08:55 PM
1993 34' Excella
Estancia
, New Mexico
Airsafe with Husky WD hitch
Here is my Airsafe Class 5 with a Husky weight distributing hitch. Sway bars are not attached but I use one friction type sway bar with this combination. If a WD hitch mounts to my class 5 Airsafe I would be surprised if you can't also mount it on the class 6
11-17-2009, 09:34 PM
_
I ask you, to quit challenging...
the ONLY challenge is to the CLAIM to have PROVED what causes accidents...
85 or 90 % of the time.
based on THAT questionnaire, reportedly used 30+ years ago.
___________
there simply aren't ANY questions on that form that lead to PROOF of what did or did not cause an accident.
___________
and NOTHING in this post is directed at you personally, but you have made the claim and did post the questionnaire.
and BOTH the claim and questionnaire are HERE for others to challenge.
____________
as JUST ONE EXAMPLE of this, lets consider the "holding tank" question....
and ASSUME 100% of the accidents involved empty tanks and 100% of NON accidents reported FULL holding tanks.
that would be a STRONG indication that HOLDING TANK WEIGHT/volume has SOMETHING to do with the accidents...
but it would NOT PROVE what caused ANY accidents or WHY accidents happened or did NOT happen.
and UNLESS SOMEONE VERIFIED that the holding tanks were EXACTLY as reported by the people filling out the questionnaires...
even THAT CONCLUSION is suspect.
____________
it is a SURVEY type questionnaire and does not lead to PROOF of anything.
cheers
2air'
11-17-2009, 09:35 PM
Tom, the Uber Disney Fan
2006 30' Safari
Orlando
The simplest, and best way to answer the OP's question is for him to call Airsafe and ask their customer service people. All he needs is the weight of the trailer, the tongue weight, and a few other pertinent pieces of information and he will get the best solution to sway control for his hitch. I don't understand why he called Reese to see if their hitch was compatible. The Airsafe folks would have a recommendation for a compatible sway control system.
Family of Disney Fanatics
WBCCI# 4821
https://streaminacrossamerica.com/
