Old 04-11-2016, 06:22 PM   #505
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
No, they sell them off at about 200k miles. Just as our family did from the mid 1960s forward. Same engine and trans, with one rebuild in the latter. Dad ran into the guy he sold his last one to about five years later. Man was pulling an closed box race car trailer with it. At 240k miles, still no change in oil consumption.
Old 04-11-2016, 07:42 PM   #506
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
It takes just about as much energy to push a large truck solo as a sedan & Airstream combined. We have a variety of tow vehicles and by far the least expensive to own and operate are the sedans and front drive vans.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 04-12-2016, 07:53 AM   #507
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
30' International Serenity unit base weight: 6,400 lbs
Chrysler 300 maximum towing weight:
Weight for it...
1,000 lbs
But, this car will be around for 200,000 miles, because it's all "highway miles"....
Seriously, tho. How do these owners deal with warranty repairs? Maybe they pay out of pocket? Torque converter replacement while-you-wait like a QuickLube? I remember a Jeep dealer hassling me about warranty repair on a sheared transaxle shaft because it happened when I was rock-crawling-- an activity the vehicle was designed for.
boondockdad is offline   Reply With Quote
Old 04-12-2016, 09:36 AM   #508
N/A , N/A
Here is my observation based on posts by forum members who use such vehicles: It seems the majority of the folks towing with under-rated sedans/minivans tow infrequently, mostly locally, on a relatively flat terrain, which does not get too hot in the summer. As you can see these restrictions are too prohibitive for most, hence the very very low number of such vehicles. Even with these restrictions, it seems most users switch to a properly rated tow vehicle after a while. Though I have read a lot about sedan/minivan tow vehicles on this forum, I have never seen one in the wild.
Call me a cynic, but I don't believe sedans/minivans are rated tow much if anything more than the manufacturer recommends. Thanks to the Fast Lane Truck, you can see how most trucks/SUVs perform in Colorado grades. I would love to see how a minivan/sedan performs on a similar grade towing a similar load (or even better a J2807 test showing they are actually more capable than what the manufacturer says).
rostam is offline   Reply With Quote
Old 04-12-2016, 03:46 PM   #509
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Weight for it...
1,000 lbs
I never had to make a warranty claim with my Toyota Sienna so I couldn't say, with any certainty, what would happen. I would imagine, though, that the manufacturer has some responsibility to prove that any damage under a claim was as a direct result of what they saw as mis-use - towing over their specifications in this case. I realise, of course, that the world of auto warranties isn't about fairness or customer service, it's about how much loss the insurer (or manufacturer) can avoid. It's profit and loss, plain and simple.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 04-12-2016, 04:17 PM   #510
MrUKToad's Avatar
Chatham , Ontario
These are some pretty awful generalizations, but fairly typical of many of the ill-informed comments that crop up regularly here.
You buy your tow vehicle to suit your needs; it's that simple. Minivans and sedans have been towing Airstreams of all sizes for decades, without fuss and without the dire consequences some people like to imagine. Personally, most of my towing has taken place in benign conditions but to occasionally tow in challenging conditions isn't an issue for me; if I thought it was going to be then I'd choose my TV differently.
If you don't like the thought of towing with a sedan or minivan, or they don't suit your needs, then don't tow with one; it's not rocket science. For those that are content with sedans and minivans, they can carry on doing what they do, wherever it is they do it.
As for running a sedan or minivan through the rigours of a J2807 test, you'd best speak to the manufacturers. They are the ones that use it to market their products, that they choose not to test sedans or minivans is up to them.
Old 04-12-2016, 07:39 PM   #511
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Our extended family's cars went all over the US , Canada and deep into Mexico. Vacationers and full timers. Trailers heavier than Airstreams -- Streamline and Silver Streak -- and not quite as easy to pull (after 1963).
Focusing on weight misses the problems to be solved. It isn't central. It's a hinge for several others.
Old 04-12-2016, 11:06 PM   #512
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Even Nicky [Ricky] secretly switched from a 1953 Mercury to a 1953 Lincoln when things got tough. [255 cubic in flathead Mercury to a 317 cubic inch OHV Lincoln]
ID:	260593   Click image for larger version
Name:	The Long, Long Trailer 1953 6.jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-13-2016, 04:57 AM   #513
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
Getting back to the original question;
If you tow an AS you MUST have an eq hitch with sway conrol.
If you are one of the millions of people who pull utility, equipment, construction and box type moving trailers you just need a ball.
Ultradog is offline   Reply With Quote
Old 04-13-2016, 05:46 AM   #514
Dearborn , Michigan
Images: 21
I don't think anyone disputes that the question "do I need sway control?" correlates with vehicle (and trailer) ratings. But, which ones?
Some would believe weight isn’t a factor.
So, I ask:
What could you expect to happen if you exceeded the weight rating on your Goodyear Marathon tires?
That is some rig, Bob.
Here’s another one for ya
https://youtu.be/AyXgMal3C1U?t=13s
sway control? barts Hitches, Couplers & Balls 101 01-20-2010 02:57 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
Sway Control Zeppelinium Brakes & Brake Controllers 3 02-17-2008 07:14 PM
Sway Control azflycaster Hitches, Couplers & Balls 28 01-06-2006 09:47 AM
do I need sway control? soultrip11 Hitches, Couplers & Balls 5 03-14-2003 10:46 AM
