Old 10-13-2011, 06:26 AM   #211
SteveH's Avatar
Common Sense , Texas
Originally Posted by perryg114 View Post
They say not to use the friction sway system in the rain. I wonder why?
Perry
Don't know for sure, but I suspect it is because when the thing gets wet it sticks, pops, and groans.
Regards,
Steve
Old 10-13-2011, 06:34 AM   #212
SteveH's Avatar
Don't know about the rest of you, but I have a lot of money tied up in my rig, for a retired blue collar worker anyway, and I've used both types of the Reese Dual Cam hitch, both older and new....I've used two different styles of the Eazylift hitches with the friction sway devise. All this considered, and considering my family and I ride in this rig, and from my experieces with all these hitches, $2500 for the ProPride hitch is absolutely THE BEST money I have ever spent on RVing.
After using the ProPride for two seasons now, and approximately 35,000 miles, I would never go back to the lesser type WD hitches.
And, not like some on here, I do not sell hitches, nor am I in any way affiliated with ProPride other than being a happy customer.
Regards,
Steve
Old 10-13-2011, 10:03 AM   #213
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
I would absolutely LOVE for someone to put together independent testing on ALL the hitch designs available.
I WILL pay my share of the costs. If you can get Reese, Equalizer and/or ANY of the others we can all pay an equal amount of the testing and reporting costs. I will even pay to host the data for the entire world to see and read.
Who has the pull with these other manufacturers to make this happen?
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 10-13-2011, 10:07 AM   #214
cms4140's Avatar
Birmingham , Alabama
Seems like you might be the best candidate, Sean .
I'd love to see this information too - would even pay to see it.
-Chris
cms4140 is offline   Reply With Quote
Old 10-13-2011, 10:09 AM   #215
ProPride, Inc.
-Chris
I have NO PULL with any of them...
I'm not sure they want the truth to be known...
ProPride Hitch
Grand Blanc, MI
Tu ne cede malis
Old 10-13-2011, 10:09 AM   #216
dznf0g's Avatar
Oswego , Illinois
Dunno, would RVIA be interested in that? NHTSA perhaps? IIHS maybe? Somebody will have to probably force the issue for all to participate.
Old 10-13-2011, 11:29 AM   #217
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Driving with the haha or ppp...
It's almost impossible to explain to others what it's like to drive a rig that is not plagued with sway....I gave up trying.
But I have let three fellow campers drive our rig,(all 3 SOB owners), with me along. "well yours is an AS and that tow's well to begin with", how will mine react. Very impressed but still skeptical.
You just don't know how it feels 'til you try it, kind'a like sex, once you try it you'll never do it the "other way" again
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-13-2011, 01:43 PM   #218
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Same as drum brakes or bias tires being adequate, when disc brakes and radials are much superior. Some don't want to hear it.
Old 10-13-2011, 01:58 PM   #219
1981 31' Excella II
New Market , Alabama
Well Sean you could start by testing your hitch compared to on the ball towing and that might get the ball rolling. If you have data to support your claims about added stability then maybe you can shame the others into doing the same or at least take their customers.
You could do slalom tests with and without your hitch. You could also do wet braking tests and intentional skid tests. You could start with a used SOB trailer and get some test parameters down and then use other trailers like Airstreams. I would also have a small tow vehicle and large one. I expect you are going to see the most benefit with the small vehicles and big trailers. What happens when you start a skid? Does the hitch help or hurt. Does it prevent the onset of skid or oscillation?
Perry
Old 10-13-2011, 02:12 PM   #220
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Let's try another way of looking at it:
Which can get through the slalom faster: a pickup truck or a sedan?
If the trailer is an A/S it'll be faster behind the sedan.
If weight and size were the determinant we'd pull 40' park trailers, wouldn't we? But they've poor performance, to say the least. High COG, non-existent aero, etc, etc. However, it's weight makes it resistant to problems . . and then it isn't.
So why should the TV be any different?
Most folks tend to think the trailer is the weak link . . but reality is that a high COG, crudely-suspended TV is or can be more of a problem.
Greater TV weight only delays problem onset for a moment longer. A lower COG TV with better suspension doesn't run into the same problems . . and if it does, is better able to move on down the road without incident. Incidents -- tripping hazards especially -- that will upset the larger TV.
Folks also tend to believe that a 5'er is more stable. The high COG and huge sail area are not overcome as a huge disadvantage. A TT with a VPP hitch replicates the 5'er hitch advantage, and an A/S is far better able to negotiate problems a 5'er never could. Run rings around it, in fact.
Any TV performs better with a VPP. But it will be the (worst case) 4WD pickup that benefits the most.
A/S? Travel at high speed!
Pickup? Travel at slow speed!
The potential performance margin is reduced by the choice of an inferior performing TV (for our actual travel speed matters little given reasonable prudence).
The safest trailer for the worst performing vehicle -- a pickup -- is an Airstream. Be a good idea to have the best hitch while one is about it.
Old 10-13-2011, 03:30 PM   #221
1981 31' Excella II
Messed this one up sorry
Perry
Old 10-13-2011, 03:34 PM   #222
1981 31' Excella II
Granted the pickup may not do that well in the slalom but it is the combination that counts. 4x4 trucks have a higher than necessary COG and that hurts them. A truck also has mass and that is going to control the trailer better when it starts to wag. A truck is great at holding a straight line and that is what we want. I don't have a 4X4 because the one time in two years you really need it you have to put up with all the down sides the rest of the time.
Panic braking is responsible for a lot of accidents trailer or not. If you are not moving in a straight line when you lock up the brakes or even hard braking you are in for trouble. I know not to push my pickup hard in the rain because it has no traction and it will break loose in a heart beat.
Perry
Old 10-13-2011, 07:29 PM   #223
When friction type sway controls get wet, the moisture acts as a lube, and therefore the friction is gone.
Same as wet regular brakes on a car or truck.
Old 10-13-2011, 08:03 PM   #224
SteveH's Avatar
I know how wet brakes work, and the friction anti sway bar does not work like that. If it did, it wouldn't matter if you used it in the rain.
The thing sticks when it's wet. Brakes loose their effectiveness when they get wet. If you had actual experience with one of these sway control systems, you would know that.
Regards,
Steve
sway control? barts Hitches, Couplers & Balls 101 01-20-2010 02:57 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
Sway Control Zeppelinium Brakes & Brake Controllers 3 02-17-2008 07:14 PM
Sway Control azflycaster Hitches, Couplers & Balls 28 01-06-2006 09:47 AM
do I need sway control? soultrip11 Hitches, Couplers & Balls 5 03-14-2003 10:46 AM
