Old 03-06-2010, 07:16 PM   #141
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
Originally Posted by overlander63 View Post
A $60,000+ trailer, just dropped on the ball, and towed.
Anybody want to buy an '010 Flying Cloud, cheap? Sway control not included, nor was it ever installed.
Doesn't surprise me the slightest, Terry. I talk to people every week that do have sway "control" and do the same thing.
When the sway controls the situation it can be quite damaging.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 03-09-2010, 08:50 AM   #142
2007 25' Safari FB SE
Blaine , Washington
Andy;
What is the cost of the Reese?
John
Relentless is offline   Reply With Quote
Old 03-09-2010, 08:57 AM   #143
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi john, This is Andy's link. Inland RV Center Inc. Or you can just try a google search. reese weight distribution hitch - Google Search
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-09-2010, 10:51 AM   #144
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Well I just gotten thru 11 pages of this discussion and I have to admit now I'm a believer. I have a 2009 Flying Cloud 27FB towed by a 2001 F350 4WD 7.3 Diesel. It tows very well. I'm usually passing big rigs, not the other way around. None the less, the raised level of control seems worth the investment of the Reese. My WD hitch came with a friction sway control device that I knew inherently was near worthless. (I have a lot of experience with building vehicles.) Also, there seemed to be issues with very tight turns and backing up. So I never intalled it. I can't really afford the cost of a Hensley or ProPride, but the Reese dual cam seems like an affordable option. My question is: With the Reese dual cam, are there any issues with very tight turns or backing?
hhendrix is offline   Reply With Quote
Old 03-09-2010, 10:57 AM   #145
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
I've taken some very tight turns and only once, in a campground, did I have an arm "pull out" of the cam.
Backing is no issue.
biggoofball is offline   Reply With Quote
Old 03-09-2010, 11:08 AM   #146
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Skip, I believe hhendrix was refering to the "friction sway control" device that came with his hitch. They reduce the turning radius significantly. I got one for "free" with our trailer but discarded it long ago.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
newroswell is offline   Reply With Quote
Old 03-09-2010, 01:26 PM   #147
Portland , Oregon
Thanks guys, let me clarify. The device pictured in newrosewell's post is the friction sway control I was referring to. I sold it. I knew there were turning and backing issues with the friction sway control. One dealer even told me to disconnect the friction sway control when backing. In light of that, are there any limitations to backing or turning with the Reese Dual Cam sway control?
Old 03-09-2010, 01:56 PM   #148
Originally Posted by Relentless View Post
Andy;
John
John.
We are not allowed to quote prices on anything that we sell or may sell.
Old 03-09-2010, 02:32 PM   #149
SteveH's Avatar
Common Sense , Texas
ETrailer has it right now for $525.
Strait-Line Weight Distribution Hitch System 1,200lbs TW / 12,000 lbs GTW Reese Weight Distribution 66074
Regards,
Steve
Old 03-09-2010, 02:56 PM   #150
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
I paid around 750.00 for a Reese W/D with Sway control bars Installed.
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 03-09-2010, 03:01 PM   #151
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
This reminds me... my Reese dual cam has some stiff bars. It isn't bad with my spongy half-ton Titan, but I'm a little nervous about a "buckboard wagon" 3/4 ton. I'm going to have to snoop around for some lighter bars, I suppose.
hampstead38 is offline   Reply With Quote
Old 03-09-2010, 03:37 PM   #152
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
http://www.airforums.com/forums/f238...-in-17984.html
I've gone one direction and then another on this subject. The rear springs on a DODGE are truly stiff in 3/4T. But the aftermarket makes spring sets with a softer "top" to them (DEAVER; more leaves, more progressive); so keep that in mind as well.
All I know for sure is multiple weighings and a dead-accurate set of TW readings to inform any changes.
Old 03-09-2010, 03:40 PM   #153
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
The hitch salesman tried to sel me 1000 lb bars for my sway, I settled for 800lb. I drive a F250 4x4. Rides great. I did the Jump test and it actually moves up and down 3plus inches. Would like to get a set of 600lb bars and do the jump test also.
Shane
TAC ID TX-1432
Old 03-09-2010, 04:48 PM   #154
Usually Sleepy
Images: 14
I was answering for the Reese, so no, I find no limitations unless you are really really cranking a turn.
sway control? barts Hitches, Couplers & Balls 101 01-20-2010 02:57 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
Sway Control Zeppelinium Brakes & Brake Controllers 3 02-17-2008 07:14 PM
Sway Control azflycaster Hitches, Couplers & Balls 28 01-06-2006 09:47 AM
do I need sway control? soultrip11 Hitches, Couplers & Balls 5 03-14-2003 10:46 AM
