Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 10-17-2003, 10:41 AM   #1
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
Do I need to grease WD bars?
I have an EZ Lift type hitch with weight distributing bars. I'm wondering if i'm supposed to grease where the bars snap into the hitch head. That part of the bar is getting pretty gouged up with use. Since I bought the hitch second hand it didn't come with instructions. Is wear there just a normal part of use, or should I be doing something else?
Stephanie
Our family photo blog
In honor of Alki and her battle with cancer we will be participating in the 2008 American Cancer Society Relay For Life. Please click here if you would like to see her page and donate to the cause: Donate
Old 10-17-2003, 11:07 AM   #2
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Grease them.
Only thing on the hitch they recomend not to grease is the cams on the Dual Cam Reese. On that use Vasaline. Needs the friction. Same with a Friction type sway control. Leave the slide dry.
I loaned my hitch to a buddy. Last thing I told him before he left was to grease. He didn't and gouged everything up.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 10-17-2003, 11:24 AM   #3
Stefrobrts's Avatar
Darn it, and I've been using it all summer like that! Well, I'll definitly start greasing it now. I suppose the ends of the sway control where it fits on the ball should be greased too?
Stephanie
Old 10-17-2003, 03:12 PM   #4
MaShep's Avatar
Profile:
Stephanie: If it helps you feel any better. Ours didn't come with any mention of greasing the bars, and the dealer didn't do it when he hooked us up either. When we pick up our rig from C&G, I'm going to ask them. If I learn anything different, I'll be sure and post.
MaShep is offline   Reply With Quote
Old 10-17-2003, 08:02 PM   #5
Profile:
I have the EZ and I lube the WD bars regularly.
If you have a Reese, I think you will find small holes in the top or side where the spring bars attach. Reese has a small plastic bottle of lube that can be squeezed to lube through the small holes .
wingfoot is offline   Reply With Quote
Old 10-25-2003, 09:38 PM   #6
MaShep's Avatar
Profile:
I verified today with C&G... we have an EZ, grease the bars. The dealer did not tell us and we have the marks to prove it. Not a lot necessary to do the job.
Old 10-25-2003, 11:52 PM   #7
dscluchfc's Avatar
Profile:  1984 31' Excella
Abernathy , Texas
Grease
You only grease the bars where they fit into the hitch head.
I have the Reese Dual Cam and Saddle. You don't grease the cam and saddle because the friction is the anti-sway control mechanism of the cam and saddle.
On friction anti sway mechanisms you do not grease the friction slide.
You do grease all weight distribution bars where they fit into the hitch head however.
dscluchfc is offline   Reply With Quote
Old 10-26-2003, 06:54 AM   #8
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
One additional word on grease. You need to keep the area clean. Grease will attract dirt and grit which does its own damage. So be sure you attempt to keep the greased areas clean prior to applying additional.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Pingbacks are On
Hensley Hitch Grease Princer Hitches 3 04-12-2004 03:57 AM
Wheel hub leaking grease? rluhr Axles 13 01-19-2004 07:33 PM
Grease Gun for MH?? 1985air345 Mechanics Corner - Engines, Transmission & More... 11 01-02-2003 06:27 PM
Grease seals, hub trouble Silver Annie Axles 10 11-03-2002 11:46 AM
SEO by vBSEO 3.1.0
