Old 01-21-2008, 09:06 PM   #1
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
Do I need a WD hitch for my TV?
I have a 04 F-150 with air bag lifts that I use when I pull my 30' boat. I was wondering if I need to have a weight distribution hitch to pull my 27' Argosy or will I be OK if I use what I have?
Argy 78
Argy 78 is offline   Reply With Quote
Old 01-21-2008, 09:13 PM   #2
_
hi argy'
if the trailer tongue weight is greater than 500lbs, with lpgas and loaded...
most receivers (not all) are only rated to 500 lbs without a w/d hitch.
unless you have a receiver on the truck that is rated higher without w/d.
smaller trailers with bigger tow vehicles may not, but a 27 with a 1/2 ton sure seems like a combo for w/d...
cheers
2air'
Old 01-22-2008, 12:08 AM   #3
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Personally I wouldn't tow that trailer without W.D.
Dave
Fyrzowt is offline   Reply With Quote
Old 01-22-2008, 06:52 AM   #4
1971 29' Ambassador
Leonardtown , Maryland
WD Hitch
There is an excellent article in Trailer Life issue February 2008. Helps to answer your question.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 01-22-2008, 07:03 AM   #5
Aluminum Addict
Gastonia , North Carolina
The air bag system does an excellent job of raising the rear of the vehicle to "look" level. However, It does nothing to transfer the added hitch weight to the front of the tow vehicle, as an equalizing hitch will do. My vote is NO.
---AIR # 17817---
DJ
Heirstreamer is offline   Reply With Quote
Old 01-22-2008, 08:02 AM   #6
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
You should a have WD hitch for both. If you need to level your truck with airbags towing you may be overloading the rear axle.
Michelle TAC MT-0
Sarah, Snowball
Old 01-22-2008, 09:43 AM   #7
Kajtek1's Avatar
1965 22' Safari
Orinda , California
Than the most critical for weight distributing is rear overhang and suspension stiffness.
Car with 2' of overhang will take heavy tongue weight differently, than pickup with 5' overhang.
Our Mercedes drops about 1" under 500 lb tonque weight. Never used WD bars with several heavy trailer. Never experienced fishtailing or any other problems and I usually tow at 65 mph.
Kajtek1 is offline   Reply With Quote
Old 01-22-2008, 10:22 AM   #8
_
same question, same poster...
http://www.airforums.com/forums/f464...-tv-39171.html
true hitch mass is magnified at the rear axle using this calculation...
http://www.airforums.com/forums/f464...sis-19236.html
IF you aren't weighing the axles or using this formula, it's all guesstimation
cheers
2air'
Old 01-22-2008, 12:17 PM   #9
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
You didn't mention what tow package, if any, you've got on the 150.
The Expedition I pull with has the HD tow package and the air suspension. (Go figure?) If I remember right the hitch has a max. tongue weight of 800#. The GT was already fitted with the WD hitch and I saw no reason to abandon it.
As a personal preference I like the extra margin of safety the WD hitch provides.
The owner’s manual describes the procedure for setting up the hitch and it only took a half-hour to adjust the hitch to the new rig. You could try turning off the air and seeing how far the rear end drops. This will give you the idea of how much the extra the system has to work.
Technically you may not need it, but after using one I wouldn’t go without.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 01-26-2008, 10:23 PM   #10
holland , Michigan
I am no expert, but have over 10k miles of towing since oct ina 08 f150 4x4 with all the heavy dut packages including snow plow they offer.
Towing an a/s high speeds in all conditions including mountains I offer this advice. The f150 allows a good weight distribution system to work perfectly. You can load more weight to the front axle, and still have over 4 inches of suspension travel left in the rear. This give almost a glue like feeling on the road, and lets the a/s float on rough roads. If your truck is set up like ours then dump the air bags, get a reese dual cam and let it do its magic. I agree with Michelle, you should have the same set up on your boat. But then again I suspect your boat towing is probably local??
safari 28 is offline   Reply With Quote
Old 01-26-2008, 10:35 PM   #11
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I would not feel comfortable towing any trailer over 3500# without a WD hitch system of some sort.
SuEllyn & Brian McCabe
Old 01-27-2008, 08:26 AM   #12
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Yes, you do and should also have the horseshoes on the boat.
If your boat pushes the rear of your F150 enough to need airbags, your 27' Argosy will most likely be at or near 500lbs of hitch weight... yea, you need WD....period.
Old 01-28-2008, 10:28 AM   #13
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
Thanks for all the information. As I am new to towing a travel traler, I just want to have as much information as possiable before spending the money for the W/D hitch. As for my boat, it weighs in at @9,500 lbs with a hitch weight of 800+. I haven't had any trouble, other than the tail drop with the HD suspention and as I have disc surge breaks on my boat trailer, I haven't found a W/D hitch that would work with this type of set up.
Now the $10 K question - Which hitch system work best with my situations & what are your thoughts on disc breaks on this trailer?
Thanks again to all of you for providing all of us such important information.
Regards,
Argy 78
Old 01-28-2008, 11:04 AM   #14
Fyrzowt's Avatar
2000 25' Safari
Images: 8
That's a whole 'nuther can of worms ....and there are multiple threads on that subject.
I did a quick search and found several, here is a sample.
Dave
http://www.airforums.com/forums/f464...ion-38230.html
Do I need a WD hitch for my TV? Argy 78 Hitches, Couplers & Balls 5 01-21-2008 09:52 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
Hitch Devoman Hitches, Couplers & Balls 5 08-07-2005 02:10 PM
what is this on the hitch travel Hitches, Couplers & Balls 5 03-01-2004 07:51 PM
hitch murphy Hitches, Couplers & Balls 3 10-12-2002 09:08 AM
