Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 01-21-2008, 08:57 PM   #1
Argy 78's Avatar
Profile:  1978 Argosy 27
Fenton , Michigan
Do I need a WD hitch for my TV?
I have a 04 F-150 with air bag lifts that I use when I pull my 30' boat. I was wondering if I need to have a weight distribution hitch to pull my 27' Argosy or will I be OK if I use what I have?
Argy 78
Argy 78 is offline   Reply With Quote
Old 01-21-2008, 09:00 PM   #2
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Do you have life insurance?
If you say no then you don't need them.
Yes get them.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Defendwally.org
Old 01-21-2008, 09:09 PM   #3
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
I'm certainly no expert on this and I'm sure others who know more will reply, but I personally would not feel comfortable towing our little 19' Bambi without a weight distribution anti-sway hitch...chances are your Argosy is heavier than your boat...and that will make a big difference...
TB
TB & Greg...& Cockers Annie & Sadie
AirForums #21900 . Membership Chair, 4C
Unit #3954
Inside Our Bambi: AZBambi Décors
Old 01-21-2008, 09:14 PM   #4
Kajtek1's Avatar
Profile:  1965 22' Safari
Orinda , California
I think I've seen a rule of thumb somewhere in the past.
If the TV hitch drops more than 3" under the trailer weight, you need WD.
If less, it is optional.
Than everything lays in details.
Kajtek1 is offline   Reply With Quote
Old 01-21-2008, 09:29 PM   #5
2airishuman's Avatar
Profile:
hi kajtek1 and others...
the problems with this 3 inch rule are many...
first the o.p. has airbags on the truck which will mask the drop...
next this guideline makes no mention of the front end which is really WHY we need w/d...
to reload the front axle.
also the rule doesn't suggest if the drop from other payload is part of this...
and so on.
4 me it is all about measuring axle loads and the tongue weight.
next biggie, is the issue of 'is it ok to use w/d with airbags' ?
many will say NO that's not good, while others do it and are happy.
the point is the o.p. needs to know how much the tongue weighs..
and how much the ft/rr truck axles weigh, before and after hitching up...
sure most of us would want sway control as well, but w/d and sway control are not combined on all hitches...
yes, more details are needed.
here's a thread that might help the o.p. understand the need to get measurements...
and if not, at least some of the posts are funny...
http://www.airforums.com/forums/f238...-ii-21000.html
and the first part of toasty's story...
http://www.airforums.com/forums/f464...-do-21015.html
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 01-21-2008, 09:52 PM   #6
Profile:
looks like the same question/post is in 2 threads...
http://www.airforums.com/forums/f464...-tv-39172.html
that doesn't improve your chance of good replies, since one will bump the other downward...
suggest you contact a mod and combine these into ONE thread...
don't sweat it many folks have done this b4 ya...
cheers
2air'
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches 3 08-31-2006 11:48 AM
Hitch Devoman Hitches 5 08-07-2005 02:10 PM
what is this on the hitch travel Hitches 5 03-01-2004 07:51 PM
Need HITCH help on a 59 59toaster Hitches 3 02-14-2003 10:13 PM
hitch murphy Hitches 3 10-12-2002 09:08 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
