Old 12-25-2013, 07:15 AM   #1
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
Do I need a sway bar?
I am going to pull a 31 with a M2/106 Freightliner. Do you think I will need a sway bar? If so what one. Do not want to push to much into the trailer from the truck. I will also be using an airsafe hitch.
beetlebob is offline   Reply With Quote
Old 12-25-2013, 07:30 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A sway bar would be a good thing. With what you will be using as a tow vehicle, a simple friction sway bar will suffice. They usually run about $50, and are cheap insurance.
Old 12-25-2013, 08:23 AM   #3
2003 25' Safari
Riverside , California
I doubt you will need any sway control.I don't know the weight or cab and wb config of your truck.I have pulled one with my truck without and was fine
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 12-25-2013, 08:58 AM   #4
1981 31' Excella II
New Market , Alabama
The trailer can sway no matter the size of the tow vehicle so it would be a good idea to have sway control. If you keep it under 60 you will probably be ok without it. You can take it out for a test run and see how it responds to lane changes. If it tends to wiggle a little the sway control would be a good idea.
Perry
Old 12-25-2013, 09:44 AM   #5
Tom and Phyllis
Lucky Tom's Avatar
2009 23' FB Flying Cloud
Tuscaloosa , Alabama
Sway control. . . I think I use my friction sway bar too tightly adjusted. This is what happens. I have no sway whatsoever but when a big truck approaches from the rear in the left lane it pushes the AS to the right but steers the TV to the left. Think "solid coupling" with no articulation. Is my thinking off on this? Have others felt like you used too much sway control?
Lucky Tom is offline   Reply With Quote
Old 12-25-2013, 09:50 AM   #6
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I'm currently using a FL60 to drag my EB around (see gallery).
2 1/2 hauls Morro Bay to Parker & back and one to Yosemite, no issues of sway.
My truck weighs 11,630. trailer less than max @ 7,800. Speed tops out @ 73 on the truck, sweet spot @ 65.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 12-25-2013, 09:55 AM   #7
CDONA's Avatar
hentom, my 40' Alfa @ 18,000#s has a 12' overhang from the wheels to the back bumper. This has the leverage to push my truck as you describe. I've seen this happen to MH's and loaded semis, but not the AS so far, , ,
Old 12-25-2013, 10:12 AM   #8
Tom and Phyllis
Lucky Tom's Avatar
On my next trip I will leave the sway bar less tight. I have only made one trip since I purchased my 23ft FB AS, to the beach in Nov. I may have been using more sway control than I needed. What is the most high-tech form of sway control?
Old 12-25-2013, 05:13 PM   #9
1988 32' Excella
Robbinsville , New Jersey
The most high-tech form of sway control would be a trailer sway control module.
http://www.airforums.com/forums/f238...le-114178.html
The most high-tech sway control hitch would be a ProPride pivot-point-projection hitch.
Old 12-25-2013, 07:13 PM   #10
StreamNTyme's Avatar
2007 25' Safari FB SE
Carolina Low Country , South Carolina
Images: 27
Also, Hensley is excellent and has been around a long time. We have a Hensley and found a HUGE difference in towing. No sway. Ever. The truck and trailer work as a unit.
StreamNTyme
StreamNTyme is offline   Reply With Quote
Old 12-25-2013, 09:10 PM   #11
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The same can be said about the Andersen with the right TV/trailer combination.
MICHAEL
Old 12-27-2013, 02:45 AM   #12
Airstreamer67's Avatar
QUOTE: "Sway control. . . I think I use my friction sway bar too tightly adjusted. This is what happens. I have no sway whatsoever but when a big truck approaches from the rear in the left lane it pushes the AS to the right but steers the TV to the left. Think "solid coupling" with no articulation. Is my thinking off on this? Have others felt like you used too much sway control?"
I use two classic sway bars on my 27 footer and have no sway whatsoever.
However, if the bars are not tighten up enough, I can sometimes feel approaching heavy trucks and buses as they pass me up. But, if I tighten the bars as they are designed to be used, I feel no such push/pull sensation, at least none to write home about.
In my experience, you don't want the vehicles articulating in the middle when being passed by the tornados otherwise known as trucks and busses. You want a solid unit that may still be affected a bit by the passing storm, but it's not flexing in the middle which will make the push/pull effect worse.
Airstreamer67 is offline   Reply With Quote
grey bar and red bar compound capt ken Cleaning, Stripping & Polishing 4 10-02-2013 11:17 PM
Airstream newbies need help please - sway bar noise lynnrae General Repair Forum 15 11-12-2012 11:14 PM
Sway bar help Diana Langley Hitches, Couplers & Balls 13 06-10-2008 05:02 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
How essential is the sway bar? 63overlander Hitches, Couplers & Balls 25 11-03-2004 06:11 AM
