Old 02-07-2008, 06:58 PM   #1
holland , Michigan
distance from the bumper
Just curious, getting out of LA today and in Banning. I have never had my hitch properly set up, just shoved the PO hitch into my truck and away we went. I have the trailer level as I had the ball raised 5 holes in the drawbar. My next question is how far the ball is from the bumber. It looks way too far out. What is the best distance? I have a guy here who will cut and redrill it. Any comments, and if way out it seems it would put stress on the truck etc.
safari 28 is offline   Reply With Quote
Old 02-07-2008, 08:35 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Ther general idea is to keep the moment arm small by keeping the ball close to the TV so that you dont bend the hitch or the TV frame.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 02-08-2008, 05:55 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If you make it too short you then risk the trailer hitting your TV when you make a sharp backing move. If you add mud guards (rock tamers) these will also need to be considered when you look at that turning distance. My ball seems to be back more then it should, but I have no fear of hitting the trailer either.
Richard
Old 02-08-2008, 06:38 AM   #4
1971 29' Ambassador
Leonardtown , Maryland
Tow Hitch
Most tow adapters have a tongue weight rating for the position of the holes. that secure it to the receiver. The further out the less tongue weight, but the further out the more flexiable your menuvering can be. Find the weight rating on the adapter and get the tongue weight on the AS and get your best balance.
dale
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 02-08-2008, 07:03 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The further back you go with the pivot point the more likely you are to have sway problems due to lateral reaction to passing trucks bow wave or other causes of lateral forces. It has always been suggested to keep the ball overhang distance to a minimum. But having it too short can cause you problems to access the back of the tow vehicle. If you have a tailgate truck, it may hit the jack motor on the trailer.
Old 02-08-2008, 07:32 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Your profile says Ford but your avatar pic is a Chev. My Reese stinger has 2 holes for variable placement. If you have a GM I'd suggest reasonably short. I think I have to put mine on 'long' when I've got the Enkay on there. Get out and check when backing to understand your setup the best. Nothing like pinching the tow vehicle and Airstream to ruin your day. See:
http://www.airforums.com/forums/f464...les-34603.html
http://www.airforums.com/forums/f238...elp-37434.html
It's hard to know if there has been any substantial redesign to their receiver. I know my '06 looks pretty wimpy. Who will know except 3-4 years down the road? Anybody heard for sure?
5 meter Langford Nahanni
Old 02-08-2008, 08:03 AM   #7
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Equal-i-zer Discussion
We have been discussing this with respect to the Equal-i-zer on this thread: http://www.airforums.com/forums/f464...ort-34484.html
The discussion starts after post 45 on page 4.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 02-08-2008, 08:06 AM   #8
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Cut and drill what? Most hitches to not tak well to being altered. My ball is about a foot from the truck bumper. Do you have a weight distribution hitch? if not due to the size of the trailer you need one.
Michelle TAC MT-0
Sarah, Snowball
Old 02-08-2008, 02:07 PM   #9
Airstreamer67's Avatar
Several inches won't make a big difference.
Mine is long enough to let my tailgate down for easy assess.
The weight transfer bars help make up the difference anyway, relative to added leverage from a slightly longer hitch bar.
I think most standard factory hitch bars are not going to be too long in any case. I don't like the idea of drilling extra holes.
Airstreamer67 is offline   Reply With Quote
Old 02-08-2008, 03:50 PM   #10
Road Ruler's Avatar
Images: 38
Moving the ball in even a couple of inches can make a significant difference on many combinations.
As far as optimal handling and minimal stress on the receiver the closer you are to the back bumper the better. Yes... redrill the shank to shorten the distance. Andy T. talks about the advantages in this article....
RV Lifestyle - Hitch Hints
Old 02-08-2008, 05:04 PM   #11
holland , Michigan
I am almost ashamed to tell all of you for over 12k miles i have had a distance of over 143/4 inches center of ball to bumber. Other than it looking a little wierd, the big hassle is out west I was constantly hitting botom going into gas stations and the like, with or without the A/S.
I had the shank redrilled and now at 113/4 inches, normal according to the local trailer guy here. He said it was a good test for the truck, and the reese dual cam that I did not feel uncomfortable with the wiggle that seemed to be in mainly cross wind. Ignorance is bliss.
I hook up tomorrow, will tst to see how the distance and tight turn issue has changed. It should be more stable in high cross winds as well. I noticed a huge difference when we leveled the trailer out, raising the ball 5 holes. Let this be lesson to all that so called dealers who are experts that I had look at the unit are well, not so expert.
Old 02-08-2008, 05:10 PM   #12
holland , Michigan
I just read that article by Andy T, and 4 inches is what really makes them handle great. This is very interestng indeed, and I wonder if it is a reason the haha is so popular to offset big distances from the bumber.
Old 02-09-2008, 06:14 AM   #13
I concede that the closer to the bumper the better it is as a general principle. However, with my F250 I have found it possible to use a shank that is a bit longer than it could be, which allows me to open my tail gate and maneuver in the camp grounds better without pinching anything. I have never had any hint of crosswind instability or any problems with passing 18-wheelers, etc. Of course, this is the advantage of having a trailer that is very stable to begin with and a heavy tow vehicle. Nothing marginal there.
And I use the dreaded friction sway bars to boot, but I do have an AirSafe hitch, which is buttery smooth for both the tow vehicle and the trailer compared to solid hitches.
Each rig must be evaluated on its own, and marginal ones have to rig the particulars differently than those which allow leeway in the adjustments and equipment. Such principles apply to many things in life.
So many choices.
Old 02-09-2008, 11:22 AM   #14
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
You're on the right track here Safari 28. When 4" makes such a difference you can only imagine what 52" does. That is the effective pivot point projection on the haha or 3P.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Distance to items for sale tmartin904 Forum Admin, News and Member Account Info 2 11-09-2007 08:31 AM
Distance Between Axles joopkeizer Axles 3 11-04-2007 05:22 PM
Distance calculation in classifieds osp6179 Forum Admin, News and Member Account Info 3 07-11-2007 09:45 PM
First long distance tow... bobfowler Base Camp 1 11-26-2006 04:12 PM
Everyone Please Help put some distance into a very hard decision for us FireFighter Axles 16 10-20-2003 08:09 PM
