Old 02-09-2008, 11:26 AM   #15
ScottW's Avatar
Hernando , Mississippi
My ball is 12" from the bumper. This is mounted on a crew cab, long bed TV. I've had no problems.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 02-09-2008, 03:28 PM   #16
bertro's Avatar
1971 23' Safari
Groveport , Ohio
I redrilled mine, I shorted it up 5 1/4" and It made towing alot more stable.
bertro is offline   Reply With Quote
Old 02-10-2008, 08:57 PM   #17
holland , Michigan
Originally Posted by Sean Woodruff
You're on the right track here Safari 28. When 4" makes such a difference you can only imagine what 52" does. That is the effective pivot point projection on the haha or 3P.
Interesting and the past 2 days was a good test. Ran from Banning through the high winds of PALM SPRINGS stayed on BLM land in Quartzite and wound up wth 70 gallons of combined grey and black water behind the axles all the way to APACHE JUNCTION.I only have one tank, Not seperate grey and black. I learned a long time ago not to tow with that puppy full. Let me tell you that would have been a challenge with 14.75 from the bumper. At 11.75 much more stable, also, the f150 was flexing even more on rough roads and the rear suspension had even more travel. Much smoother ride as well. Some reduction in turning radius but slight indeed. I woud like to go shorter but the shank would have to be modified big time due to lower brace. So Sean ,your product actually bring it in over 4 feet? Heading to Michigan(home) and we need to talk.
safari 28 is offline   Reply With Quote
Old 02-11-2008, 09:20 AM   #18
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
It does. Through the links the pivot point is projected 52" forward. That is, anytime there is a force on the trailer the trailer will attempt to pivot around that forward point. Just give me a call any time. My cell is 810-962-0219.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 02-12-2008, 05:25 PM   #19
Road Ruler's Avatar
Images: 38
By using a welded ball mount and redrilling the shank we have reduced the ball to bumper distance to 3 1/2".
Andy T. summed up the advantages of the shorter distances in a previous post...
QUOTE: Just to prove it to myself that it matters I once had a shank with two holes in it 3" appart so I could change the overhang without changing anything else. The wind effect was noticeably more and we lost 3 kph in the slalom. It also took a 3/8" bolt in the chain to get the same weight distribution.
Andy QUOTE:
Distance to items for sale tmartin904 Forum Admin, News and Member Account Info 2 11-09-2007 08:31 AM
Distance Between Axles joopkeizer Axles 3 11-04-2007 05:22 PM
Distance calculation in classifieds osp6179 Forum Admin, News and Member Account Info 3 07-11-2007 09:45 PM
First long distance tow... bobfowler Base Camp 1 11-26-2006 04:12 PM
Everyone Please Help put some distance into a very hard decision for us FireFighter Axles 16 10-20-2003 08:09 PM
