Old 07-12-2010, 04:47 PM   #85
Airstream01's Avatar
2008 25' Safari FB SE
Land of fruits and nuts , California
If you are getting sway, it has to be in the hitch itself. Tires causing a little wandering feeling is not sway.
Airstream01 is offline   Reply With Quote
Old 07-12-2010, 06:20 PM   #86
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
What puzzles me is: if it's the hitch, I can't believe this is an isolated incident.
boondockdad is offline   Reply With Quote
Old 07-12-2010, 06:32 PM   #87
Central , Mississippi
It's not, the rest of us that spent the bucks are in denial...
Denial - Wikipedia, the free encyclopedia
I'm bettin on the new sidewalls being flexy, and hopin' it's something easier...
Keep us posted!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-13-2010, 10:08 AM   #88
Dearborn , Michigan
Images: 21
denial, eh?
isn't that a prerequisite for owning an airstream?
<wink>
Well, I can keep it at 55mph at all times, and it seems to do OK... but then- I could have bought a $50 hitch for that
Old 07-13-2010, 12:44 PM   #89
Airstreamer67's Avatar
Quote: "It was like I was using the Reese/friction anti-sway bar, set-up. That is to say: WHITE KNUCKLED. It was BAD." End quote.
WOW, Joe. If the trailer was regularly white-knuckling you with a classic Reese setup, then you might look closer at your trailer.
I'm surprised that the "best-handling trailer on the planet" would be so unstable. I am still using friction sway bars, and have done so with an old 1976 Ford sedan, a 1983 Chevy pickup and now, for the past 14 years, a 1996 F250, from coast-to-coast, and have never had a white-knuckle event yet.
Is it possible that something about your trailer is sporadically going awry?
Airstreamer67 is offline   Reply With Quote
Old 07-13-2010, 05:48 PM   #90
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville , Tennessee
Sarge,
The first thing I noticed, when this sway began, was the ‘head’ was not pivoting like it used to. I mentioned this earlier in the thread. Watching it on my ‘burb back up camera, it used to pivot back and forth, constantly. Now, it is MUCH less… pretty much settles to one side.
‘Jumping’ when in a turn, only happens if I’m ‘slaloming’ (I’ve only made that maneuver at parking lot speed). I’ve noticed that phenom since it was new, and operating correctly.
A ‘push’ in a turn, only happened before I got my brakes properly tuned. I discovered the dealer hadn’t bled the brake system during their new unit ‘prep’. After bleeding myself, and tuning the P3 gain/boost, I don’t get that.
Thanks all.
I noticed that you said you had bought the hitch new, so I believe you have a warranty on it. When I bought this trailer I have now I was experiencing many of the same problems you mentioned, unfortuanatly Hensley transfered the Hitch to my name then Hensley told me that under warranty they would have repaired it for free for the original owner. I have since pulled the Hensley and put my sway bar set up on the trailer and all problems disappeared even the sway from semi's. When taking the Hensley off is when I was able to clearly tell that the bearings Hitch & bars was worn to the point where it was allowing the extra play to occur in turns and driving down the road. Right now I dont have the finances to pay for a new one until I get my GMC & 76 Sov sold or until tax time.
Sarge
SARGE/AF is offline   Reply With Quote
Old 07-13-2010, 06:02 PM   #91
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
Joe,
Is the hitch centered when you are towing down the road?
Also, when you say "jumping" do you mean it feels like it is spring loaded when you rotate the bottom of the hitch head from side to side? If it feels like it is spring loaded then you have a bent link. That may cause the hitch to not center properly. When the hitch does not center while towing down the road the effective pivot point is rearward and off-center in relation to the centerline of the combination.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 07-15-2010, 03:55 PM   #92
Dearborn , Michigan
Images: 21
Originally Posted by Sean Woodruff View Post
Joe,
Hi Sean,
The box head has never been centered when pulling.
I always assumed there was a slight crown to the road, or something.
The orange head is as close to square to the tongue as it's going to get.
The 'jumping' I was referring to is while towing... say an "S" maneuver, at low speed... the hitch will bump from one side to the other... I can hear and feel it, but it's done this since it was new, and I simply chalked it up as normal (and a minor nuisance).
The box head pivots very smoothly when unhooked.
I was thinking it may be a failure in the bearing(s) that only binds when it's loaded with the weight distribution.
Tx,
Joe
Old 07-17-2010, 01:06 PM   #93
ProPride, Inc.
Tx,
Joe
Well, the links aren't bent.
I doubt it's a bearing failure but I suppose it is possible. I've never heard of bearings being a problem.
I would guess that something, a weld or bolt somewhere, is the culprit.
ProPride Hitch
Grand Blanc, MI
Tu ne cede malis
Old 07-18-2010, 07:56 AM   #94
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The devil is in the details . . especially the ones I overlook, ignore or short-shrift.
Old 08-30-2010, 08:03 AM   #95
Dearborn , Michigan
Images: 21
Viewing via bumper camera, while underway, there is no "pivoting" action of the 'hitch box' under the 'main hitch assembly'
This is the ONLY (substantial) difference, that I have been able to identify (on the overall rig), from when it performed perfectly and its current performance (sway, wiggle, push).
The 'hitch box' pivots smoothly and freely when unhitched.
Is the non-pivoting behavior systemic of the sway/wiggle/push?
Has anybody experienced/noticed this?
Old 08-30-2010, 08:18 AM   #96
_
no pivoting?
r u suggesting the hitch doesn't bend at the articulation when turning now ?
hang the video on utooob or someplace we can view it.
cheers
2air'
Old 10-14-2010, 11:10 AM   #97
Dearborn , Michigan
Images: 21
No, the Arrow articulates, and pivots nicely. I’m saying the receiver box, doesn’t pivot back and forth under the orange head while heading straight down the highway- like it used to. When it was new, you could see it pivoting back and forth constantly, while driving a perfectly straight line, down the highway.
Which would prompt the kids asking: “Dad, why is it doing that? Is it supposed to? Is it going to fall off? If the hitch is moving, why isn’t the trailer? Why is the hitch orange? If I cut my arm off here on earth, will it be waiting for me in heaven?”…. and so forth
So of course, I tell them: “get on airforums" or "google it”
We’ll be pulling her out for some New Year’s camping, next. I’ll plug the camera feed into my cam for video, then.
Old 10-16-2010, 05:43 PM   #98
Dearborn , Michigan
Images: 21
For a mere $22.50 shipping (discovered after the fact), Hensley graciously agreed to honor their lifetime warranty, and replace the torsion bar brackets, that had wallowed out.
This time, before swapping out the brackets, I removed the hitch, and broke it down in the shop.
What I found was, at the very least, alarming.
Note: This Arrow was installed, factory new, in April 2008. I would estimate roughly 12,000-14,000 miles logged on it, with manufacturer recommended regular maintenance.
diesel performance norbert Tow Vehicles 15 01-04-2010 07:23 PM
Improving brakes performance femuse Brakes & Brake Controllers 27 12-07-2009 10:18 AM
Performance changes using the new diesel Stream 1529 Off Topic Forum 19 12-24-2006 03:35 PM
Power Available vs. A/C Performance JimGolden Furnaces, Heaters, Fireplaces & Air Conditioning 11 07-13-2006 07:10 PM
performance exhaust systems wb13798 Mechanics Corner - Engines, Transmission & More... 6 07-07-2003 06:54 PM
