Old 06-11-2010, 09:33 PM   #71
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
Originally Posted by SARGE/AF View Post
Just recieved the email from Ron @ Hensley and they do not make the 2.5.
So this question has been answered, I took it because I was asked that they do make it but that was an assumption that I made and should not have, easy for one to do.
Now for all you commedians, go ahead with the tease me on the word assumption.
Sarge
I thought that was probably the case. It's really more on them than you. It makes no sense for them to ask that question unless it was just to be able to tell you they don't have a 2.5" bar if you responded that you DID have the 2.5" receiver. It would be like me asking if you preferred orange or black. I'm CLEARLY not making any orange hitches so why ask the question making one assume that I do make orange hitches when I have no intention of EVER doing it? (that is, unless customers start asking for orange. )
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 06-26-2010, 04:55 PM   #72
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
. . . U p d a t e . . .
Here's the alignment print out from the shop in Buffalo, I had done at the beginning of my woes... for any rack wonks out there
Here's where I'm at:
Our last outing, back on the freeway, I found the same 'twitch and wander' at highway speeds, just not as pronounced.
Took it in to my local Chevy dealership.
They said the front end was fine.
They said airing the front to 80psi was not helping (specs recommend 50 front/80 rear)
(But, they're not going to let money walk out the door)
They found blown seals on rear axle, bad rear brake rotors, bad hubs.. on one side, 1/2" of play, 1/4" on the other. (Also found, unrelated to thread topic, bad 4WD sensor, switch, and actuator... this would explain why earlier that week, I buried the drive axle in soft sand when it was supposed to be in 4LO)
Rotated tires, aired the fronts to 50psi
Rides much better (but lost 1/2 a mpg- lol)
Hoping to escape on the 4th, so we'll see how she tows...
But, from the feel of things so far... I'd say Airstream01 takes down the pot
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 07-04-2010, 04:13 PM   #73
Dearborn , Michigan
Images: 21
Getaway didn't pan out this weekend
So I did the next best thing: maintenance.
Found some pretty good 'wallowing' out on the strut posts, and brackets
Occured only on the 'inside' (facing 'A' frame) surface, of both assemblies
I removed the pair of bolts holding the brackets to torsion bar, rotating them and posts, until I decide whether to order new parts, or replace the whole darn hitch with a Pro-Pride.
Old 07-04-2010, 06:00 PM   #74
_
Originally Posted by finalcutjoe View Post
...until I decide whether to order new parts...
hi fc'
the stretch/deforming of the U brackets holes on the w/d bar ends...
is common.
several pix of that in my old hitch thread from >1 poster.
those U brackets can also crack at the 90d bend, yours look UNcracked.
the holes on the jack extensions can also do this and that MAY be one of the reasons NOT to use the last hole.
those parts SHOULD be replaceable under warranty.
my guess is the home office will ask for PICTURES
then claim the stretching is normal and the parts are FINE...
...or replace the whole darn hitch with a Pro-Pride.
looking back at your thread "title" this is EXACTLY how i solved the performance issue.
cheers
2air'
Old 07-10-2010, 05:35 AM   #75
Dearborn , Michigan
Images: 21
I'm at a loss here.
I serviced the Hensley. Everything is greased and torqued. Yeah, there's some wear on the brackets, but that cannot be what is causing my sway. Truck tires are 80 rear, 55 front, trailers are 65. Tongue weight and CAT scale readings are optimal.
Took a five hour trip north.
It was like I was using the Reese/friction anti-sway bar, set-up. That is to say: WHITE KNUCKLED. It was BAD.
Trucks been serviced.
The only change in the equation is the tires.
Is it possible "E" load Michelin tires can introduce this much sway??
Argh.
Old 07-10-2010, 08:28 AM   #76
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Can you swap tires/ rims with someone and check the tow performance again?
Marc
Old 07-10-2010, 09:40 AM   #77
_
... Truck tires are 80 rear, 55 front, trailers are 65. Tongue weight and CAT scale readings are optimal...
without reading the numbers this may be way OFF...
but 55 psi at the front after w/d for a 30 SLIDE seems low.
with 1200 or 1400 or MORE on the A frame...
and knowing from some of your previous payload reports...
they u and the family tend to travel AT or slightly over the payload and gvwr...
it would seem the fronts need 70 psi +/- ??
i realize the dealer said "air doesn't help" in those front tires,
but they are only E rated when properly INFLATED (poetry to help remember this)
and doesn't the alignment change a TINY bit on these burbs when MAXIMALLY loaded?
does the recent alignment ACCOUNT for FULLY LOADED?
i know u r thinking 'bout the next hitch apparatus, but the mule may need to be swapped first...
cheers
2air'
Old 07-10-2010, 08:27 PM   #78
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I'm at a loss here.
Argh.
With close to the same setup and exact same tires, I am using 75 in rear and 65-70 front.
I wonder how many miles are on your tires now. Mine are about at 10,000 and I still notice a little wander compared to the OEM Goodyears that came on the truck. However it is nothing like they were for the first few thousand. As I mentioned before, I never tried to tow the trailer when they were acting like that, because I put them on in the fall. I do know the truck handles better with more pressure in the front . Maybe you ought to try 80 on all four. I don't see how that could hurt anything.
Good luck,
Ken
Old 07-11-2010, 11:35 AM   #79
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville , Tennessee
I'm at a loss here. I serviced the Hensley. Everything is greased and torqued. Yeah, there's some wear on the brackets, but that cannot be what is causing my sway. Truck tires are 80 rear, 55 front, trailers are 65. Tongue weight and CAT scale readings are optimal. Took a five hour trip north. It was like I was using the Reese/friction anti-sway bar, set-up. That is to say: WHITE KNUCKLED. It was BAD. Trucks been serviced. The only change in the equation is the tires. Is it possible "E" load Michelin tires can introduce this much sway?? Argh.
I would like to ask you a few questions before you run out and buy tires and rims.
1) when you are driving does the hitch seem to move side to side or is your side to side seem to be more than normal?
2) when you turn do you notice that the hitch seems to jump from one side to the other?
3) in a curve and you apply breaks do you seem to get a sudden side push?
If you could please answer these questions, the answers may tell me if you had the same problem I had and if so I have the answer to your problem.
Sarge
SARGE/AF is offline   Reply With Quote
Old 07-12-2010, 10:00 AM   #80
Dearborn , Michigan
Images: 21
‘Air,
80 in the front, is how I’ve been rolling for the past 40k miles. The last 5k miles, I’m getting a ‘wander’ in the steering. I've had three different shops look at it.
FREY TRUCK aligned it, and says: "toe was out, everything else AOK."
Les Stanford Chevy airs front down to 55, and says: "front end suspension and steering AOK."
Fuoad (my local mechanic), says front end is: “جيدة “, which is to say “fine”.
With the fronts at 55, it doesn’t wander.
Haven’t discussed “fully loaded” alignment… How do they manage that?
Ken,
I was rolling with 80 at all corners, when this whole ordeal started…
First, I thought it was air. Verified 80 on tow, 65 on trailer. Still getting nasty sway.
Then, I thought it was hitch. Found ‘slop’. Corrected that. Still getting nasty sway.
Then, Les Stanford repaired bad hubs on drive axle (excessive play). Thought that would solve it. Nope. Still nasty sway. This weekend, I was passing a semi, on a down grade, heading north on I-75. Was cruising at 65mph, got in left lane, as I was passing I was creeping up to 70mph- started getting squirrelly… when I hit about 72mph, the trailer was all over the place! It actually pushed the ‘burb onto the shoulder. I’m sure it looked as bad as it felt, because the semi, backed waaay off.
W T F
Did 65mph, on the nose, all the way home. Getting nasty ‘push’ and sway the whole way.
If this is the performance I got out of the box, with the Hensley, I would have been returning it in a NY minute. This performance is WORSE than my old Reese/sway bar.
What’s killing me is, I had ROCK SOLID operation since installing the Arrow in April 2008. It only turned sour since heading out in March of 2010 (roughly 12k miles of outstanding performance).
Sarge,
The first thing I noticed, when this sway began, was the ‘head’ was not pivoting like it used to. I mentioned this earlier in the thread. Watching it on my ‘burb back up camera, it used to pivot back and forth, constantly. Now, it is MUCH less… pretty much settles to one side.
‘Jumping’ when in a turn, only happens if I’m ‘slaloming’ (I’ve only made that maneuver at parking lot speed). I’ve noticed that phenom since it was new, and operating correctly.
A ‘push’ in a turn, only happened before I got my brakes properly tuned. I discovered the dealer hadn’t bled the brake system during their new unit ‘prep’. After bleeding myself, and tuning the P3 gain/boost, I don’t get that.
Thanks all.
Old 07-12-2010, 10:05 AM   #81
Dearborn , Michigan
Images: 21
Marc
This is going to be my next step, because if it doesn't solve it- Hensley is replacing my hitch.
Old 07-12-2010, 11:14 AM   #82
RossFam05BH's Avatar
2005 30' Safari
Pfafftown , North Carolina
Hey All,
BTW, Hensley performance is seriously diminished if the 2" inch riser stinger is put in to the tow vehicle receiver up side down.
Ask us how we know this.
We drove in this configuration for 150 miles before our 13 year-old son instantaneously noticed the wrong hook up at a rest stop. No alcoholic beverages involved during hookup (it was 8:00 o'clock in the morning afterall). This is the first time I have done this in over 25000 miles of using the Hensley. While driving, I thought we were driving an SOB with extra weight hanging off the back. Unhitched at the rest stop, turned the stinger over, and everything was back to normal.
Bye,
Paul
2005 30' Bunkhouse "Nedapedalua"
2002 Ford Excursion 7.3L Diesel 2WD
WBCCI #5182
AIR # 6050
RossFam05BH is offline   Reply With Quote
Old 07-12-2010, 02:42 PM   #83
Livingston , Texas
Joe,
Have you looked for possible sources of yaw angle "play" in the various connections between tow vehicle and trailer? The operation of the four-bar linkage can be adversely affected if there is yaw slack in the system.
Some possible sources are:
Yaw slack between receiver tube and drawbar
Yaw slack between drawbar and hitch opening (is there any wear on the wedges or looseness of the OCLs)
Looseness between ball and ball coupler
Looseness between ball and hitch head (IIRC the ball is welded to the head)
Loose struts or frame brackets
Hitch head not aligned perpendicular to trailer longitudinal axis
Have you checked the bearings on the linkage pins?
Based on your symptons, it sounds as though something is loose somewhere.
Ron
Ron Gratz is offline   Reply With Quote
Old 07-12-2010, 03:54 PM   #84
_
the thread that's GOING in circles...
no doubt the hitch internals may be at issue...
we covered much of this WAY back in post #18?
since u r SO CLOSE to the orange factory,
take that sucker IN for inspection...
and REfirb/replacement...
while there is still time...
cheers
2air'
diesel performance norbert Tow Vehicles 15 01-04-2010 07:23 PM
Improving brakes performance femuse Brakes & Brake Controllers 27 12-07-2009 10:18 AM
Performance changes using the new diesel Stream 1529 Off Topic Forum 19 12-24-2006 03:35 PM
Power Available vs. A/C Performance JimGolden Furnaces, Heaters, Fireplaces & Air Conditioning 11 07-13-2006 07:10 PM
performance exhaust systems wb13798 Mechanics Corner - Engines, Transmission & More... 6 07-07-2003 06:54 PM
