Old 09-25-2013, 02:44 AM   #1
Ely , Minnesota
Different Truck...same hitch
Hi Folks...
I purchased a new different truck and my trailer is not level when I hitch it up the same way I did on the previous truck. It is lower in the back. On the previous truck I put the chain in the fourth link to raise the bars. Should I experiment with different links until the trailer is level? Does changing the link I use affect the trailering in any other way? Thanks.
bertheep is offline   Reply With Quote
Old 09-25-2013, 04:14 AM   #2
Air-Texas's Avatar
2004 34' Classic S/O
Waldorf , Maryland
What hitch are you using, and is the hitch adjustable? I have a Hensley Arrow and when I bought a new truck, I had to get a new hitch bar with a lower drop.
Mike, Miho &
Dallas the Bourbon Boxer
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline   Reply With Quote
Old 09-25-2013, 06:04 AM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yes, you need a longer drop on your hitch- all brands make them. Then you need to go through the initial set up of the WD for the new vehicle.
Old 09-25-2013, 06:04 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
I wouldn't experiment with different "links" first.
As noted above you need a draw-bar with more drop.
You want the nose low with no tension on the WD bars, then return to level with WD tension. Hard to say how much drop you need without hitch height measurements and weights. Our 2500 Burb is about 4" low with no WD and level when WD set.
On a dead level parking lot....
Un-hitch, move TV forward a little, level the trailer and measure. That will get you a workable number.
I added 2" for our rig, which gives me enough WD adjustment for different loads, 4" to 6" drop.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-25-2013, 09:42 AM   #5
Ely , Minnesota
cok...More details. I have a Reese Hitch. My old TV was a 2004 Silverado. My current truck is a 2007 Silverado 2500 HD. You guys lost me with all of the lingo I am not familiar with. With my old truck I used to put the chain on the 4th link. What do I do now. Will I damage anything if I do the same thing on the new truck? When I bought the trailer the dealership installed the hitch, so I don't know how to make adjustments or what kind of adjustment to make. If I take it to a dealership for help, what is the best way to hook up? Same a always. Possible damage to either truck or trailer?
Thanks.
Old 09-25-2013, 09:56 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Bert, message sent
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-25-2013, 10:02 AM   #7
2011 27' FB Classic
Masontown , West Virginia
Try This
RV.Net Open Roads Forum: Towing: Travel Trailer Hitch Set-up Procedure
While still a bit difficult, this takes the process step by step.
You have to start right to end right...............
Good Luck
Bill & Dorothy Reeves
Betsy the Beagle
2011 27FB
2016 F250 6.2L
TAC # WV-2
MountaineerStreamer is offline   Reply With Quote
Old 09-25-2013, 02:19 PM   #8
Thanks.
If the rear of the trailer is low/dragging with weight distribution bars set at 4 links, use three and see how much it raises. You need a draw bar,(the thingy with the ball on it), with more drop, the ball lower, rear of the trailer up^.
Once the trailer tongue is lower you can tension the weight distribution bars to bring it back to level.
PFC
"Tahawus"
RLC
