Old 08-21-2009, 05:01 PM   #43
2009 25' SS International
Pasadena , California
i ended just doing it all myself... buy the hitch and have it installed... whatever, no wonder our auto industry is in trouble... they have an obviously failing product and are not willing to replace it with a safer and better product... oh well
flmgrip is offline   Reply With Quote
Old 08-21-2009, 05:54 PM   #44
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by flmgrip View Post
Maybe I can talk the dealer into replacing it with a better aftermarket... I'm still under warranty... What's a recommended aftermarket ?
Thanks!
I got a Reese and installed it myself on our Silverado.
Old 08-21-2009, 08:05 PM   #45
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Originally Posted by vajeep View Post
Flmgrip,
I had the same problem on our Suburban until I started using a straight hitch pin. I bet that you have a hitch pin that is curved on one end. For some reason the bent or curved end likes to "wallow" the round hole and turn in to an oval. We got our OEM hitch replaced under warranty and bought a straight hitch pin at a Tractor Supply and no problems for the last three years.
Hmmm - I have exacty the same problem on a 2008 GMC Truck, maybe i should replace the bent pin with a straight one before it gets worse
I could easily weld on a washer, but I'm never sure about welding on a vehicle and maybe messing up expensive computer stuff!!
Brian.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-21-2009, 10:14 PM   #46
catson4's Avatar
1991 34' Limited
Port Orchard , Washington
flmgrip,
I agree with vajeep, check your pin. If it is the type that is "bent over" to form the "handle" that you grab to install or remove the pin, then , yes, that type will revolve or wallow around and cause that type of wear. Get a new straight pin the correct size to solve the problem.
JMHO.
Claude
One bazillion fish
1991 34' 60th Aniversary Limited Edition #008
2007 Chevy 2500 HD Duramax/Allison
One big parade float & a 40' Wells Cargo 5th wheel trlr.
"Wake each morning & Smile at the GREAT DAY you about to experience"
www.catson4ponds.com
catson4 is offline   Reply With Quote
Hitch and receiver rattle Devoman Hitches, Couplers & Balls 53 09-09-2009 08:16 AM
Something interesting with my hitch receiver. boondockdad Hitches, Couplers & Balls 10 10-18-2008 06:19 PM
Hitch receiver plaques rangebowdrie Off Topic Forum 10 11-30-2007 02:48 PM
Receiver Hitch Bolts Davis Hitches, Couplers & Balls 2 08-04-2006 09:06 AM
Receiver/hitch weight with WD Devoman Hitches, Couplers & Balls 15 12-21-2005 07:04 PM
