Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 07-31-2006, 05:47 PM   #1
COArgosy78
Obsessed with Moonunit
COArgosy78's Avatar
Profile:  1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 45
Curt Mfg. Weight Distributing Hitch Setup
Well, as usual after surfing for answers, I realize I should come here first for information
We have the opportunity to purchase a fairly new set up for sway control. It is made by a company called Curt. Now, I have heard much about Reese & Hensley & Equalizer. But does anybody know anything about Curt?
We would be real interested in anything you know or any comparison w/Reese, which is the other we are considering. With the Curt setup, we will be able to purchase everything, including the sway control kit & they are throwing in a hitch lock. With the Reese, it will be just the weight dist. hitch & we will have to add the sway control later.
Anybody got solid info? Thanks.
Leigh (IB Aluminated)
"When a great ship is in harbour and moored, it is safe, there can be no doubt. But that is not what great ships are built for." by Clarissa Pinkola-Estes, author of ‘Women Who Run With the Wolves’
COArgosy78 is offline   Reply With Quote
Old 07-31-2006, 06:33 PM   #2
jimmickle
jimmickle's Avatar
Profile:  Marion , Iowa
Take a look at http://www.curtmfg.com/WTDist.html Looks like a copy of the Reese. No provisions for sway control like the Reese dual cam. The only thing that they show is a separate sway link, which in my experience is a pain and not nearly as effective as dual cam. Reese information can be found at www.reeseprod.com
jimmickle is offline   Reply With Quote
Old 07-31-2006, 07:41 PM   #3
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
I have the separate friction bar sway control, and if I were buying new, I would go with the dual cam, as the friction bar isn't as good as the dual cam, as well as requiring two more attaching points, and adjustment every hookup.
Old 07-31-2006, 08:35 PM   #4
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
A friend of mine has that set up on his 31' Avion. It's like the Reese, except instead of a trunion head at the hitch end of the torsion bars, their round bar is bent about 70 deg. and cams up into a socket from the bottom. His had some wear and a tendency to drop the bar out of the socket. All I know.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 08-02-2006, 06:17 PM   #5
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
iI now have the two spring bars I needed for my older dual cam set up. Can someone tell me -- these have short chains on one end and two points at the other end. What do you do with them? The hitch has the little cups on it, one on either side. The tongue has the two stirrups with chains and the thing you flip back totighten them down.
I have a freind coming over ins a few days, but I am clueless on the set up of the bars.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 08-02-2006, 06:34 PM   #6
jimmickle
jimmickle's Avatar
Alan,
Go to www.reeseprod.com and download the installation and adjustment instructions. They should answer all your questions. If you have problems, drop me a note at jimmickle@juno.com I have them on my hard drive and can forward them to you.
Jim Mickle
Old 08-03-2006, 07:09 AM   #7
ALANSD
thanks Jim, looks like I have the cam set up that fit other bar attachments.
Mine looks like this below--- and the bars are two points on one end and a short chain at the other. A member advised me to remove the cams, and attach the bars with the chain only, and find out what I need to redo my set up to fit them.
ID:	24204   Click image for larger version
My Music Site:
Old 08-03-2006, 07:10 AM   #8
ALANSD
i guess I am not yet seeing how the bars fit into the hitch ...
My Music Site:
Old 08-03-2006, 09:19 AM   #9
Excella CM
Excella CM's Avatar
Venice , California
If you have round bars, then the hitch isn't a Reese. The hitch for the round bars has a hole up from the bottom on each side and the bar is inserted up into it. Reese bars are recatangular and have a head with a trunion on each side like a machinist's hammer and fit in from the back. The two systems wont even begin to be interchangeable.
Old 08-03-2006, 12:25 PM   #10
ALANSD
no I do have a Reese set up and Reese bars, but they are not made to work together without some mods.
My Music Site:
Old 08-04-2006, 11:59 PM   #11
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Greetings ALANSD!
The photo above illustrates the older style Reese Dual Cam with the older style bars. The weight distribution bars do not have chains on them -- the saddles attach to the bars with a device that resembles a u-bolt. These saddles can be purchased separately from the Dual Cam system as they are wear parts that do need to be replaced when worn. The weight distribution bars slip into the hitch head through a slot in the upper part of the head and then are rotated into position (the starting point for insertion approaches being parallel with the tow vehicle's bumper). Based upon your photos, the only part that it sounds like you may be missing are the saddles as I noted that you mention chains on your weight distribution bars. {The hitch head on my Cadillac is a more recent Reese item, and it doesn't have the small levers that you can see on your hitch head -- the slots for the trunions, however, are almost identical.}
If you need a more close-up photo (or one from a different angle) of the Reese Strait-Line Hitch, I will be hitching the Minuet to my Suburban tomorrow morning for a trip to Wisconsin and could take some close-up photos then.
Kevin
Kevin D. Allen
AIR #827
Old 08-06-2006, 02:44 PM   #12
ALANSD
thanks, that is a help. I have bars that are different, got them seperately, and they do have the chains. I removed the stirrup/cams for now as I am cleaning up the tongue and hitch to paint.
I have been told to buy newer cams, and some hardware to make the bars work, or leave the cams off or out of the way for now, using the hitch and bars. I don't have the third cross bar at all that seems to connect your spring bars together at the back.
My Music Site:
Old 08-06-2006, 07:11 PM   #13
overlander64
Anna , Illinois
Images: 106
Reese Strait-Line
Greetings ALAMSD!
The cams that you have should need nothing more than paint. All that you should need are the saddles that fit onto your weight distribution bars. A pair of the saddles for your weight distribution bars should cost less than $50.00 -- while the cams (stirrups) will add another close to $200. One of my good friends has a Dual Cam setup that is much older than the one on your coach, and the only parts that have been replaced are the saddles on the weight distribution bars.
The third cross-bar that you are seeing is painted silver on your coach and has a slightly different profile than the one on my Minuet -- yours is contemporary to your coach, but is still functional and compatible with the new saddles -- I don't see any reason to be concerned about the stirrup/cam assembly on the coach. I know several people who are currently utilizing the stirrup/cam assembly from several years before the one on your coach. After you paint the part and are ready to reinstall them, it would be advisable to download the installation instructions on the Reese site for the Dual Cam Sway control as there are a few interesting processes that need to be undertaken to get everything adjusted so that is is mating properly. As you can see from my photos, the components on my coach all need painting -- hopefull this project will be later this fall or early next spring.
The photos attached below can be described as follows:
Photo #1: Illustrates how the weight distribution bar fits into the stirrup on the trailer. In this particular photo, the snap-up bracket is in the locked position.
Photo #2: Illustrates how the weight distribution bar slips into the hitch head. It may be necessary to manually lift the locking/retaining tab as the trunion is rotated into the head (note the angle at which the bar needs to be to the hitch head).
Photo #3: Illustrates how the weight distributionj bar appears once it has slipped into the hitch head and the locking/retaining tab has returned to the closed position. The weight distribution bar is now ready to be rotated into position and slipped onto the stirrup on the trailer.
Photo #4: Illustrates how the Dual Cam saddle attaches to the end of the weight distribution bar -- it replaces the chains which were attached with a bracket the utilized the two holes only one of which is utilized in attaching the saddle. The U-Bolt is included with the saddles. (This is the top view)
Photo #5: Illustrates how the Dual Cam saddle attaches to the end of the weight distribution bar. (This is the bottom view)
Photo #6: Illustrates how the Cam or stirrup looks when it is prepared to receive the weight distribution bar. (Street Side)
Photo #7: Illustrates how the Saddle is cradled by the stirrup when it is ready to be locked into position utilizing the stirrup and chain assembly that is "permanently" attached to the trailer. (Street Side)
Photo #8: Illustrates how the Street Side of the hitch appears when the weight distribution bar and dual cam are locked into position.
Photo #9: Illustrates how the weight distribution bar and Dual Cam assembly relate as they are about to be mated -- this is on the Curb Side.
Photo #10: Illustrates the weight distribution bar mated to the cam stirrup on the Curb Side.
Continues in a post to follow:
Kevin
ID:	24379   Click image for larger version
ID:	24381   Click image for larger version
ID:	24383   Click image for larger version
ID:	24385   Click image for larger version
ID:	24387   Click image for larger version
Kevin D. Allen
AIR #827
Old 08-06-2006, 07:18 PM   #14
overlander64
Anna , Illinois
Images: 106
Reese Strait-Line Hitch with Dual Cam Sway Control
Greetings ALANSD!
The two photos at the bottom of the post complete the photos of the Strait-Line Hitch assembly:
Photo #11: Illustrates the weight distribution in place with the chain ready to be snapped-up and locked into position. (Curb Side)
Photo #12: Illustrates the hitch when it is fully setup and nearly ready for the road (taken from Curb Side). The safety chains, break-away cable, and trailer umbilical cord remain to be attached.
From your description, I am convinced that the only part that you likely will need to complete your Strait-Line hitch setup is a pair of the saddles.
Good luck with your hitch! I am sure that you will find it well worth the effort in getting it setup!
Kevin
ID:	24389   Click image for larger version
Kevin D. Allen
AIR #827
weight specs for 68 Overlander 26D PeterH-79MH 1969 Overlander 5 02-08-2003 04:49 PM
Hitch Setup Jabba Hitches 2 10-04-2002 11:33 AM
