Old 08-12-2006, 07:24 AM   #15
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I guess I missed the photos being busy at work the past week or so...Thanks for that it does make it easier to see. I have taken off the stirrups temporarily until I can get the right ones for these bars. The bars fit the hitch no problem, but I do not have s third bar that connects them across the back forming the triangle. I do have lots of instructions now and when I can get to a local Reese dealer I can see about the parts missing to make this all right.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-12-2006, 07:32 AM   #16
jimmickle's Avatar
2000 31' Land Yacht
Alan,
The sturrups you have will work fine with the bars that you have. All you should need to get is the cams for the end of the bars. I don't understand what you are talking about with a third bar. There is no third bar. Take a better look at the photos and the reese instructions that I sent you.
jimmickle is offline   Reply With Quote
Old 08-12-2006, 12:35 PM   #17
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks JIm, yes I think the third bar is from another type set up. I spoke to someone form the forum just now, who explained that part. Duhhhh!
AIR #005
retired!
Old 02-01-2014, 07:25 PM   #18
Thornton , Colorado
additional questions
I have been searching for days and this is the only place i have found this weight distribution hitch. I purchased a trailer with this setup. The questions are these (let me know if i get something wrong):
1) Is the initial set up on the truck hitch the same as most of the others, namely level the trailer and measure the height where the ball goes - measure the truck front and back bottom of wheel wells - ect, ect?
2) Is this set up also anti-sway?
The pictures are very helpful, Thanks
paragon4884 is offline   Reply With Quote
Old 02-01-2014, 07:37 PM   #19
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
1) By etc., etc. you mean that you measure the wheel wells before the trailer is hitched and then re-measure after you've hitched and cinched the weight distribution... then yes. The procedure is the same. When you cinch the weight distribution the goal is to transfer a portion (most?) of the tongue weight back to the vehicle axles - particularly to the front wheels. I'm sure somebody will add to that if I've oversimplified.
2) If your bars have the "cam" mechanism then yes, it's anti-sway. The cams have to be adjusted properly so they are fully mated when the tow vehicle and trailer are straight. The cam mechanism relies on friction to resist sway. I like this method of sway control compared to a friction bar that some rely on.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 02-05-2014, 08:11 AM   #20
Thornton , Colorado
Thank you for the info it help a lot. If i need anything else i know where you park. lol
Old 06-28-2016, 07:42 AM   #21
Riverdale , Michigan
Looking for the stirrup
Hi all,
I've been looking for a part that I need for this setup. I managed to break the arm that the stirrup is attached to. Are these available anywhere?
Thanks for any help.
I am new to this site. I don't own an Airstream, but I do have a travel trailer.
jjjerryjr is offline   Reply With Quote
Hitch height Chuck Hitches, Couplers & Balls 20 04-09-2016 10:21 PM
weight specs for 68 Overlander 26D PeterH-Airstreamer 1969 Overlander 5 02-08-2003 03:49 PM
Hitch Setup Jabba Hitches, Couplers & Balls 2 10-04-2002 10:33 AM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches, Couplers & Balls 3 07-09-2002 03:05 PM
