Old 08-21-2008, 06:11 AM   #1
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
Crossing Chains
Should chains be crossed? If so, why, where, and, how many times?
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 08-21-2008, 06:14 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
If yer talkin' about the safety chains, I take the curbside and connect it to the driver's side connection on the tow vehicle and the streetside chain connected to the passenger side of the tow vehicle.
So to me, one cross. I do it because it takes up a little slack. If in fact there is a breakaway from the hitch, less slack gives the chains less ability to build kinetic energy until they bite, allowing them to take hold sooner than later and less stress on the base connector on both the trailer and tow vehicle.
Old 08-21-2008, 06:16 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
One cross as stated above. Basically make an "X". The theory is that the crossed chains will catch the tongue if it breaks loose from the ball and prevent it from digging into the road.
Richard
Old 08-21-2008, 06:42 AM   #4
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Like Azflycaster says the crossed chains make a "craddle" for the tounge to fall in, in case there is separation (and let's hope that never haoppens to anybody).
Just make sure your chains are not too long. If they are too long and would allow the tounge or hitch to hit the pavement / ground then crossing the chains would be pretty useless.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 08-22-2008, 08:57 PM   #5
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Crossing Chains
Crossing the chains under the hitchhead is both sound practice and, I've heard, in some states may be a requirement. We see some trailers dragging their chains on the asphalt, bad for the chains and no help in supporting the trailer coupling if the trailer uncouples or the hitch fails. Also we ran into one fellow crossing his chains above his hitch so his chains wouldn't get greasy. No, no. Under the hitch.
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 08-22-2008, 10:19 PM   #6
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
I can attest to another reason to cross the chains. Mine seemed to be too long and they dragged the asphalt on a 400+ mile trip. When I arrived and was ready to unhitch, my chain link had been ground in about half way through. Also, it is imperative that you make sure they are not crossed on the outside of your weight distribution bars. In turns you will put too much tension on them and snap them when you enter or leave fuel stations. I found this out the hard way. I now have a new set of heavy duty chains on my Airstream. Yes, I had a long learning curve when I first started towing and I am glad to share my experiences so someone else can avoid the mistakes I made when I was new to towing. Live and learn, and I learned a lot that first year.
Family of Disney Fanatics
WBCCI# 4821
Old 08-22-2008, 10:35 PM   #7
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Crossed YES. But never never twist them to take up the slack. Have them shortened to the proper length.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 08-22-2008, 10:35 PM   #8
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
If your chains are too long you can twist a chain around and around to shorten a chain. Each revolution takes up at least a full link distance.
Comes in handy if more than one TV pulls the trailer with different length drawbars.
Best bet is the correct length as Randy stated.
Garry
Old 08-23-2008, 05:05 AM   #9
Images: 59
You should cross the chains. The reason is that the "outside" chain will be too short if you make a hard turn left or right. It's one of the Laws of Geometry.
Don't ask for proof.
Old 08-23-2008, 05:08 AM   #10
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
http://www.airforums.com/forums/show...7&postcount=49
Old 08-23-2008, 07:58 AM   #11
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
Definitely cross the chains (once). Last year I had the misfortune of popping the tongue off the ball in a really bad campsite (very bad approach angle). The crossed chains caught the trailer and kept the tongue off the ground. SCARY!
94Tri is offline   Reply With Quote
Old 08-23-2008, 08:17 AM   #12
63Silver's Avatar
1963 28' Ambassador
Smiths Grove , Kentucky
Images: 43
94Tri,
If I had a rig as large and as expensive as yours, I would rap the chains in velvet!! But we can't all be school teachers. 94's right the chains can also be a safety latch even when not heading down the road. My trailer rolled off it's block and pushed the wheel blocks while I was unhitching. Thankfully the chains "crossed" helped to hold and steady it until I could get it under control. 94, can't wait to see you next weekend, we'll have dinner ready.
63silver
63Silver is offline   Reply With Quote
Old 08-26-2008, 04:11 PM   #13
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Here is a good argument. DOT has informed us at work that crossing chains is not a safe practice, and to discontinue doing so. Now that being said. The yard men Which I someitmes am, Are instructed NOT to do it. however many of us drivers when leaving the yard Do it! I always crass them for the cradle effect if god forbid she comes apart. I dont know there reasoning behind it, and everytime I ask one they dodge it.
mustang is offline   Reply With Quote
Old 08-26-2008, 05:30 PM   #14
zamboni's Avatar
"DOT has informed us at work that crossing chains is not safe practice" ...their reasoning may be that if the chains are not equal lengths, and IF the trailer becomes separated the one longer chain may "throw" the trailer around to the other side of the tow vehicle causing further unstability in a very tense moment. DUH!Still doesn't make sense...the trailer isn't supposed to become separated while traveling anyway (IF we are doing things RIGHT!).
zamboni is offline   Reply With Quote
Crossing the Great Divide Santart On The Road... 12 07-12-2008 09:40 AM
Crossing the U.S. Borders by Road herrgirdner On The Road... 2 02-19-2008 04:49 PM
Safety Chains Do Work Chaplain Kent General Motorhome Topics 4 09-01-2007 11:46 AM
Tire chains for AS jordandvm Axles 13 09-07-2004 11:26 AM
Crossing Canadian Border trumpwer On The Road... 20 07-29-2004 08:34 PM
