Old 08-27-2008, 04:12 PM   #29
richinny's Avatar
2011 34' Classic
that's why i use velcro to close my sneakers and just cross my chains once.
hawaii, it's on my list, save me some pineapple juice!
Ricky
Old 08-27-2008, 04:19 PM   #30
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I have always crossed safety chains - for the "cradle" effect. If they appear a little too long, that's o.k. in my book, because it allows a bit of extra length for a tighter turn. I suspect that the Airstream factory designers have actually given this a thought over the past several decades of trailer designing. But to deal with the "hanging too low" possibility and to prevent dragging on the pavement, I bungie them up in the middle - the bungie definitely will give way if the chains start to draw tight. (And I do it in such a way that they can't snag on the hitch in a turn. Hard to explain but easy to do!).
AirsDream is offline   Reply With Quote
Old 08-27-2008, 08:59 PM   #31
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I never thought about the chains dragging??? I have always adjusted them, But the bungi might give a little more if In tight corders. The picot point is different so I dont think even a jack nife could break um.
mustang is offline   Reply With Quote
Old 08-28-2008, 06:08 AM   #32
SteveH's Avatar
Common Sense , Texas
Don't remember which ones they are, but there are some Northern states where crossing the chains is required by law. The Southern states, however, are more realistic and just require chains.
Old 08-28-2008, 02:24 PM   #33
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Not worth a poll, but
Originally Posted by SteveH View Post
... is required by law. ...
Can ANYONE share a tale of a law enforcement representative actually reviewing ANYONE's use of proper towing equipment?
Since I seldom see an Airstream in tow while going down the road, my OTR diversion is to rant about improperly rigged SOBs encountered to my wife. She is really hoping the situation improves so that I will quit interrupting her reading material.
While I can't see how the SOB's chains (if present) are arranged, at night I can spot a lot of coons in the trees due to the SOB's lack of weight distribution.
Anyone?
Anyone?
Tom
Old 08-28-2008, 03:01 PM   #34
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I just read this thread and for one thing I've talked to a friend who is a mechanical engineer and into tools and he said for one, twisting chains to "shorten" them is a no no and can effect the strength limits of the chain.
With at least my trailer, it was very easy to move the hooks to a different link. That took care of excessive length. Finally I've been taught to cross my chains and I think the practice is safe since those chains are the same length and personally it definitely would help keep the trailer tongue from contacting the road.....especially if you are encountering some pitching of the trailer.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-28-2008, 03:17 PM   #35
Anyone?
Anyone?
Tom
Agreed.
All to many SOB haulers, tow with just a ball. When they are asked about it, the typical answer is, "Hey man, can't you see I tow with a truck?" Why do I need a load equalizing hitch? It's a waste of money!!!
Oh well, maybe he has a good attorney.
On the other hand, so I have been told, "trucks have that magic ability."
"They don't need all that towing garbage."
Ho hum, back to work.
Old 08-29-2008, 08:26 AM   #36
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Originally Posted by Inland RV Center, In View Post
I don't, as well as many other people, always agree with DOT.
During my many thousands of towing miles, I always crossed the chains.
There are two reasons for doing so.
1. The chains won't drag the pavement.
2. When a turn is made, the chains do not tighten, as they would if they were straight.
Straight chains can inhibit a tight turn.
Crossed chians, never interfer, with the tightest of turns.
Actually, Andy, the factory installed chains won't inhibit a tight turn--they will break. I know this from experience from the time I inadvertently hooked the chains up by passing them around the outside of the WD bars. (lesson learned here) When I arrived at my destination some 409 miles and one stop for fuel later I discovered my chains had snapped in the middle from the tight turns getting into and out of the fuel station at the mid-point of the trip and were dragging the ground. I also discovered what happens on a 409 mile trip when the chain drags the ground for approximately 1/2 the trip--the friction on the asphalt grinds the steel away and "eats" through the links. The links that had dragged on the pavement were worn roughly half through.
The chains I had installed are a little too long so I twist them. My 30' Safari had 12,000 lbs chains, IIRC, but the trailer shop where I took it to have new chains welded on didn't have 12,000 lbs chains, but did have 15,000 lbs chains. So that is what I now have. I can pretty much say to any other Airstream owner with confidence, "mine're bigger than yours."
Family of Disney Fanatics
WBCCI# 4821
Crossing the Great Divide Santart On The Road... 12 07-12-2008 09:40 AM
Crossing the U.S. Borders by Road herrgirdner On The Road... 2 02-19-2008 04:49 PM
Safety Chains Do Work Chaplain Kent General Motorhome Topics 4 09-01-2007 11:46 AM
Tire chains for AS jordandvm Axles 13 09-07-2004 11:26 AM
Crossing Canadian Border trumpwer On The Road... 20 07-29-2004 08:34 PM
