Old 09-28-2013, 04:26 PM   #1
1969 27' Overlander
St. Louis , Missouri
Crappy coupler?
I've got a 1969 overlander, when I tow, a check trailer alert goes off in my truck, I'm pretty sure it's because the original coupler sucks. Should I buy a simple coupler replacement or replace the entire tongue to a different style coupler?
Noco is offline   Reply With Quote
Old 09-28-2013, 05:15 PM   #2
dznf0g's Avatar
Oswego , Illinois
What kind of TV? I don't think your TV can diagnose a coupler. An ITBC, however can diagnose a bad electrical circuit in the trailer brake system.. That's all I can think that you are experiencing.
-Rich-
Old 09-28-2013, 05:33 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
That is the electrical connection (connector) not the coupler giving that indication. Shoot some electrical connector cleaner or WD 40 in and on it. Try again.
Old 09-28-2013, 06:11 PM   #4
1969 27' Overlander
I've got an 06 ford powerstroke. Ya my electrical cable is pulled out of the socket on the trailer end. I've got a replacement for it so I'm hoping that will solve the check trailer warning issue. But there is a lot of play in the coupler, I believe it's called a Melvin coupler??? I'd like to make sure it's good to go too. I've replaced all runing gear and just wanna make sure it's safe to tow
Old 09-28-2013, 09:13 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Probably a Marvel coupler, you can purchase a rebuild kit from Vintage Trailer Supply and other vendors.
Bill
Just my personal opinion
Old 09-28-2013, 09:40 PM   #6
1974 Argosy 20
Kooskia , Idaho
If you do need a new coupler, remember that it has lasted 45 years to date. It is hard for me to call that a "crappy coupler". Everything wears out. I found cracks in the one on my '74 Argosy, and had it removed and a new one installed. It was a 2 hour job and total cost including the coupler was in the range of $225.
But, like the others mentioned, it sounds like you are getting an alert for your brakes, as no tow vehicle cannot check the coupler as far as I know.
Old 09-28-2013, 09:49 PM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
A new coupler can be welded on your existing tongue, or you can rebuild some couplers. I'd replace one that's seen a lot of wear over almost half a century. I do however agree that it's probably your emergency brake cable that's sending the check trailer light.
Paula
Old 09-29-2013, 05:10 AM   #8
1969 27' Overlander
It's been a great coupler, but after half a century, it's now crappy and requires fixing. Thanks for the help
