Old 06-23-2019, 12:41 PM   #1
2019 28' International
Murphy , Texas
Coupler won't allow the ball to seat
On our first trip coming back, hooking up I could not get the shoe coupler to seat all the way around the ball... It appears the shoe coupler is getting in the way of the ball just slightly... I tried moving back and for while hitched to see if it would properly seat...but still it would not seat all the way. I put silicone spray on it to see if it would help...but again no. Can you adjust the shoe coupler??
I have a 2019 International Sig 28 RBQ
Jkreis is offline   Reply With Quote
Old 06-23-2019, 01:47 PM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
The hitch coupler works best if the trailer coupler is a little behind the ball. With a little lube, it should slide forward as it comes down.
If the trailer is a little too far forward, the connection is very difficult.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 06-23-2019, 02:03 PM   #3
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
This may seem silly but I had the same problem starting out. When you lift up on the ball latch you then push the latch toward the trailer. It will move 3/4 of an inch and carry the tongue below with it.
If this isn't it, then I am the only one to have this problem!!
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Got Connect? Turn off WiFi as WAN!!
Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 06-23-2019, 03:04 PM   #4
2019 22' Sport
Fairhaven , Massachusetts
It took me about 20 minutes to figure that out my first time out.
davincent is offline   Reply With Quote
Old 06-24-2019, 05:40 AM   #5
Murphy , Texas
Thanks for everyones help....this is my second Airstream and never had this issue before. After a lot of silicone spray, it seems to be working...things that make you go hmmmmm.
Old 06-24-2019, 09:27 AM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
On a brand new hitch, the parts have not yet worn it. There are rough edges here and there that keep things from sliding as easily as they will later on.
Old 06-24-2019, 09:50 AM   #7
2018 27' Globetrotter
Mesa , Arizona
hitching up
The answers above are 100% right. Don't back your TV too deep into the ball or it won't sit properly and won't latch. Back it up so you can still see a small part of the ball and then the trailer will slide nicely over it and latch properly. Hope this helps. It takes a few attempts to get it right but you'll perfect it soon.
dgutwein is offline   Reply With Quote
Old 06-24-2019, 11:59 AM   #8
2019 27' Flying Cloud
Yorba Linda , California
Hitch hard to latch
I had the same problem, the dealer to 20 min. to attach it. I found moving the trailer up and down with the jack worked.
soling917 is offline   Reply With Quote
Old 06-24-2019, 01:21 PM   #9
1981 31' Excella II
New Market , Alabama
You can be too far back and get the retainer jammed under the ball. There should be a nut underneath that allows you to adjust the grip it has on the ball. If too tight it may not close and too loose it an come off the ball.
Perry
Fresh Water Tank Low Pressure Problems-Won't allow on demand water heater to turn on dieselsnack Fresh Water Systems 2 08-21-2018 10:02 AM
Red Coconut - won't allow a "ProPride" accordionman On The Road... 13 12-31-2017 08:21 AM
Alignment of ball an coupler Harper Hitches, Couplers & Balls 6 06-10-2008 05:06 PM
Replace ball coupler on 22ft Safari Killo1 General Repair Forum 1 04-24-2008 02:27 PM
couldn't get coupler off the ball qqq Hitches, Couplers & Balls 20 10-02-2003 01:00 PM
