Old 03-13-2010, 02:14 PM   #1
1961 19' Globetrotter
1959 18' "Footer"
santa cruz , California
coupler replacement 53 FC
i'm looking for a good tongue coupler for a 53 FC. are there different tongue angles? any good links and good links for coupler purchase closer to CA the better -for shipping. looking for one that will look authentically 50's if at all posible. thanks!
greenrig is offline   Reply With Quote
Old 03-13-2010, 04:15 PM   #2
soldiermedic's Avatar
Florissant , USA
When I changed out my 53 FC's coupler, I went up to a 2 5/15" ball. The Atwood coupler I bought is nice and easy to use.
Hope it helps.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 03-13-2010, 07:33 PM   #3
1959 18' "Footer"
thanks, i'm guessing the A-frame angle is standard? do they torch cut the old one off or grind?
Old 03-13-2010, 08:11 PM   #4
Florissant , USA
Plasma cutter and refined it with a grinder.
Old 03-19-2010, 02:25 PM   #5
JFScheck's Avatar
Rockville , Maryland
Images: 33
Wow - guess those welds are pretty darn tough...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 03-19-2010, 06:06 PM   #6
Florissant , USA
Not necessarily, he's a professional welder and metal worker and it was the fastest way to so it
Old 03-19-2010, 06:47 PM   #7
Images: 59
Just a suggestion. When you set up the new coupler, be sure that it is square with the axles.
Don't assume it was square when the first one was put on; mine was off by about 3/8".
Coupler wear: what to do? allanrd General Repair Forum 4 05-07-2009 09:59 AM
Coupler Question at_wanderer Hitches, Couplers & Balls 4 06-08-2007 03:55 PM
Replacement Coupler For Tradewind CAPEHORN31 Hitches, Couplers & Balls 2 12-29-2006 08:35 PM
Thermal coupler help. rebel beck Furnaces, Heaters, Fireplaces & Air Conditioning 1 10-23-2005 12:12 PM
couldn't get coupler off the ball qqq Hitches, Couplers & Balls 20 10-02-2003 01:00 PM
