Old 06-01-2007, 01:55 PM   #1
at_wanderer's Avatar
Coupler Question
Does anyone know anything about this type of coupler? I am in the process of buying parts and steel for a new a-frame and would just like to get some feedback on this item. Would you recommend it? It looks like the collar would hold better in an emergency situation.
Brent
at_wanderer is offline   Reply With Quote
Old 06-01-2007, 02:49 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Possibly better than you need. Depends upon what you're towing.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-01-2007, 06:09 PM   #3
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
I rented three equipment trailers equipped with a similar hitch. Worked fine. Seems like they are bullet proof and they seemed to be painless to hook up. Someone out there has got to have more than a few hundred miles experiance with these
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 06-01-2007, 06:27 PM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
In my opinion
Originally Posted by at_wanderer
... It looks like the collar would hold better in an emergency situation.
Yes. Yes it will.
Having used similar couplers before, I agree that it is a superior coupler to what most travel trailers have. But, it requires more maintenance, in the order of periodic greasing, to keep it carefree. Even then it's release function can get balky.
Keep in mind that, with weight distribution bars installed, the coupler popping off the ball is extremely rare ... if not a non-existent situation.
Definitely go for that style of coupler if you tow without weight distribution.
Tom
Old 06-08-2007, 03:55 PM   #5
Sorry I didn't get back to this right away.
Thank you all for the info.
Tom,
I have decided to go with a more standard coupler based on your info and some advice from dealers. The only problem now is I can't seem to find the brand that I finally decided on. A call to the manufacturer this afternoon will hopefully give me some good results by Monday.
Thanks again.
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Atwood Question ALANSD Water Heaters, Filters & Pumps 2 04-14-2004 09:54 AM
Satelite TV Question hex Our Community 6 09-09-2002 09:11 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
