Old 12-31-2002, 06:18 AM   #1
1994 30' Excella
New Smyrna Beach , Florida
Question coupler lock
Not sure where this post should go- anyway here is the question I have.
Where can I find a coupler lock (the type that covers the entire area where to ball goes into for our trailer(assumeing most AS trailers have similar tongues-mine is a 2001 Bambi). I have seen some at Walmart and at a local RV dealer but both of these don't fit over my coupler. The coupler appears to have a very large lip that doesn't accommodate these particular locks. Does anyone know if a lock like this is available and/or can you recommend some other type that would provide good security.
Bob Caldwell
rcaldwel is offline   Reply With Quote
Old 12-31-2002, 09:06 AM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Coupler Lock
The same outfit that makes the WalMart lock makes different configurations of the lock. They do have one that will fit Airstreams, but they are hard to find. Nobody seems to stock them.
Some time back, I chased the appropriate lock down on the internet, but I didn;t buy one since I had already bought a different style of lock. Best I can advise is get the manufacturer's name from the one at WalMart and start searchiung the net.
John W. Irwin
WBCCI #9632
Old 12-31-2002, 01:32 PM   #3
JPAIRSTREAM's Avatar
1972 31' Sovereign
, Ohio
Images: 47
link to a coupler
link2
link 3
link 4
link 5
made for atwood couplers
link 7
Bob,
I hope these links help you out. The coupler on your trailer is a Atwood brand coupler,
JP
JPAIRSTREAM is offline   Reply With Quote
Old 01-09-2003, 09:53 PM   #4
2001 27' Safari
Springfield , Virginia
Guardian Coupler Lock
A perfect fit for the Airstream couplers is a lock made by Guardian Industries, 2719 Stagestand Road, Duncan, OK 73533. The model number is G-37. Good trailer supply stores carry these locks. Phone number for Guardian is 405 255-2699. The G-37 model is designed for the 2-5/16" rolled lip flange couplers found on the 2001 Airstreams.
Lew Brodsky
WBCCI 2585
Springfield, VA
lbrodsky is offline   Reply With Quote
Old 01-09-2003, 11:23 PM   #5
2002 34' Classic S/O
Irvine , California
Images: 11
I just bought one last month - Maaster Lock Co. Trailer Lock, # 35.
If you can't find one, call C&G Trailer Service in Bellflower, CA - They sold me mine. (562) 634-6286
Good Luck!
Phil in Irvine
WBCCI # 9759
2002 34 Slide Out Lounge
2005 Yukon XL, 3/4 ton, 4WD, 8.1 engine
pjtaia is offline   Reply With Quote
Old 01-10-2003, 07:23 AM   #6
wallybyam's Avatar
coupler lock
I had the same problem. What I wound up doing was to take a hitch ball, saw the threaded shaft off at the base of the ball and using a normal padlock, lock it in the hitch socket while storing. It would at least slow down a thief a little, and is much cheaper and available than the commercial variaty.
Bruce
wallybyam is offline   Reply With Quote
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Coupler lock recommendation davidlaxson Hitches, Couplers & Balls 19 02-21-2004 10:11 PM
MH door lock wb13798 Mechanics Corner - Engines, Transmission & More... 9 01-14-2004 11:05 PM
Fridge compartment lock Ladi Holovsky All Argosy Trailers 3 08-30-2003 11:37 AM
