Old 08-30-2016, 10:55 AM   #1
Coupler Latch
I have a 2016 30' International for about a year now. More often than not, when I hitch up my trailer, the holes on the coupler latch won't line up, so I can't get a latch pin through it. I know the latch is holdjing to the hitch ball because I can raise the trailer with the jack to the point where it will raise my tow vehicle. Has anyone else had this problem? I'm hoping there's an easy solution. Thanks in advance.
loberg is offline   Reply With Quote
Old 08-30-2016, 12:42 PM   #2
2005 19' Safari
ishpeming , Michigan
I have found a bit of grease on the ball and a bit of silicon spray on the coupler usually do the trick. Sometimes I have to smack the coupler and "nuge" it back and forth to line up. I would NEVER tow without a hitch pin through the hoes though. That is just my opinion........... and you know what free advice is worth.
amazingwoody is offline   Reply With Quote
Old 08-30-2016, 12:57 PM   #3
I appreciate the advice. I have had this problem several times. I have always, one way or another, gotten the holes to line up eventually. Unfortunately this past weekend I could not get it to line up & had to drive an hour without a pin in place. Nerve racking to say the least. I'll try what you said. Thanks.
Old 08-30-2016, 09:56 PM   #4
1979 23' Safari
Wayland , New York
next time try pulling the TV forward a tiny bit to pull the ball to the front of the hitch coupler socket. If the ball is resting pushed against the back side of the coupler pushing on the ball clamp it can prevent the ball clamp from being able to go down all the way. Also grease up inside the coupler itself can help it move smoothly.
Old 08-30-2016, 11:02 PM   #5
2012 28' International
Prince Edward County , Ontario
We have had it happen a few times. We raise the hitch and slightly move the truck and that has always worked.
Cyclist is offline   Reply With Quote
Old 08-31-2016, 05:14 AM   #6
2000 30' Excella
Toledo , Ohio
I raise the hitch until it lines up thats what my instructions say that came with the coupler rebuilt kit .
woodfox45 is offline   Reply With Quote
Old 08-31-2016, 06:38 AM   #7
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The holes don't line up because the coupler isn't completely aligned. Move the rig around, either by raising the front of the trailer, or pulling forward and back a few feet, until the holes line up.
Old 08-31-2016, 06:56 AM   #8
Gainesville , Florida
Yes, good advice. Works for me.
Old 08-31-2016, 08:19 AM   #9
2005 31' Classic
Pleasant Plains , Illinois
As mentioned, it's helpful to keep your ball and coupler slightly lubricated. For the few instances my pin holes didn't line up, I have pulled the tow vehicle slightly forward with some weight on the ball. I can normally snap my coupler in place by placing my truck in drive and quickly take my foot off the brake.
Greg & Mary
2005, 31 ft. Classic - 2008 Ford F250
WGreg is offline   Reply With Quote
Old 08-31-2016, 11:16 AM   #10
Is there one type of lubricant that is best for this application?
Old 08-31-2016, 11:29 AM   #11
1976 31' Sovereign
Oswego , Illinois
Smile
REESE has hitch ball lubricant that I use. Bill
Old 08-31-2016, 11:30 AM   #12
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
If holes do not line up you are actually not hooked, you will be able to often raise the hitch but you are not hooked. As other say move the TV a fraction or what I do is raise up, push the trailer a fraction while lowering down and it usually does the trick.
SAFE TRAVELS
Bud
Starting to Look (AGAIN) Number 5 Hopefully
USAF Training Instructor (TI) - 68-72
Old 08-31-2016, 11:55 AM   #13
2008 27' Safari FB SE
Long Beach , California
When there are two of us engaged in the hitching/unhitching process, this almost never happens. But, when I do it alone, it happens occasionally. The truck tends to move a bit after I put it in "PARK" and that throws off the perfect alignment with the coupler.
As others have said, it ends up being a slight forward/backward movement of the truck that usually solves the issue.
LBOskiBear is offline   Reply With Quote
Old 08-31-2016, 01:54 PM   #14
1974 25' Tradewind
Calgary , Alberta
When you think you have the perfect alignment (but before you put your transmission in PARK and let off the brakes), engage the emergency brake. That will keep the TV from moving after you let off the foot brake. As a secondary benefit, many rear brake auto-adjusters are engaged by the emergency brake mechanism, so that you're actually helping the rear brakes stay in proper tune.
Alumineer is offline   Reply With Quote
Old 08-31-2016, 02:52 PM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Generic brand Clear Moly available at any auto parts, marine store or wallyworld will do the job.
MICHAEL
Old 08-31-2016, 03:08 PM   #16
I used to do that keep it from moving. But, I thought I read somewhere that because I'm raising the truck so much to connect hitch and then the WD bars, that it wasn't a good idea to engage the parking brake.
If that's not accurate, I'd rather to reinstate the practice of engaging the parking brake. I'm usually in the habit of engaging it anytime I'm parked, regardless of whether it's a hill or flat. Just a habit I've always had.
Atwood coupler won't latch cwf Hitches, Couplers & Balls 6 08-07-2013 10:31 PM
coupler latch pin SPAN? (measurement please) Astroboy Hitches, Couplers & Balls 4 06-24-2010 11:11 PM
"coupler latch pin size" (help please) Astroboy Hitches, Couplers & Balls 9 06-22-2010 08:28 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 10:52 AM
Coupler latch when to replace? LI Pets Hitches, Couplers & Balls 6 10-10-2009 04:16 PM
